1. Richelle Mansfield
    Richelle Mansfield New Member
    Eaton, IN, United States
    I recently changed the drums struts and wheel hubs on the rear of my 08 prius went to pull out of garage amd will not go into drive.
  2. JC91006
    JC91006 Senior Member
    16,762
    8,562
    Does the car go into READY and it just doesn't move?
  3. Brian1954
    Brian1954 Senior Member
    2,148
    832
    South Central PA, USA
    Are there any warning lights illuminated on the dash?
  4. PriusCamper
    PriusCamper Senior Member
    12,688
    5,134
    Pacific Northwest, USA
    Usually that means you got warning lights and those warning lights come with an error code stored in memory. You can use an OBD2 bluetooth reader and phone apps to read the codes. Or buy a Mini-VCI dongle that comes with a cracked version of Toyota Techstream software that you install on an old Windows computer.
  5. Tombukt2
    12,901
    2,317
    Parking brake still on?
    Danno5060 likes this.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    Hello and welcome to PriusChat!
    We need a little more information about what's going on with your car before we can offer advice.
    Did you replace the rear wheel cylinders with the brake work, and if so how did you bleed them?
    Does the car go to "ready" mode OK?
    Are there any warning lights lit up on the dash after doing the repairs?
    Do the brake - stop lights come on when you step on the pedal?
    FYI, your first 5 posts are moderated and can take some time before they show up on the forum.
    Richelle Mansfield likes this.
  7. Richelle Mansfield
    Yes it goes into ready Mode without red triangle but if I put it into drive it comes on
  8. Richelle Mansfield
    Nope parking brake will not garb it goes to floor and releases automatically
  9. Richelle Mansfield
    I did a check on it and no codes showed up
  10. PriusCamper
    12,688
    5,134
    Well, only red triangle that I know of that shows up without logging error codes is if you open the driver's door when car is in gear. So if it's not related to the door switch, then you need a better device to grab the error codes with.
  11. Tombukt2
    12,901
    2,317
    Yes it sounds like your scanner's very basic and we'll just grab basic p codes that sort of thing The Prius with its large number of internal computers and processing ability needs certain type of capable scanners to communicate with all those computers at one time these capable scanners are usually bi-directional that's important even other expensive bi-directional scanners some of them can't read the Prius completely even expensive one made by matco and snap-on unless they're the latest versions with all the updates paid for subscriptions and all that possibly so it can get very tricky and costly quickly.
  12. Brian1954
    2,148
    832
    #12 Brian1954, Feb 14, 2024
  13. JC91006
    16,762
    8,562
    If it goes to READY without the triangle, then the only other thing I can think of is if you had your door open while putting the car into Drive/Reverse. That would cause the triangle to come on.
