Yellow Plastic in Oil
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by collers9640, Feb 16, 2024.
  1. collers9640
    collers9640 Junior Member
    Charleston Sc
    Has anyone had the plastic from the Timing Chain slides/slippers or Damper break down and start to show up in their oil?
    I been trying to figure out what the particulars are in my oil and that the oil this I can think of.
  2. Mendel Leisk
    41,474
    How big are the particles? Post a picture? Any recent work?
    What's the miles and how long have you had it?
    douglasjre likes this.
  3. JC91006
    JC91006 Senior Member
    16,769
    8,567
    Maybe it's someone using a dirty funnel, got particles in there?
  4. Doug McC
    Doug McC Senior Member
    1,079
    418
    Midwest
    2022 Prius
    That is the most likely source.
  5. Tombukt2
    12,998
    2,330
    I think the timing chain slippers are black or else they're a white nylon I guess they would be sweet tea colored if they were soaked in oil But if they're black they won't take on anything obviously.
  6. JC91006
    16,769
    8,567
    Sometimes when you open a quart of oil, there is a safety ring that detaches from the cap. Maybe one of those rings, when the bottle is turned upside down during your pour, the ring fell in the engine.
  7. douglasjre
    douglasjre Senior Member
    2,181
    719
    Null, NL
    Chain guides are black
  8. BiomedO1
    3,636
    1,877
    SacTown, Ca
    If you still got the oil filter, cut it open and check in between the pleats to see how bad the contamination is.
