Toyota Dealer Parts Sale - 25% off until Feb 26, 2024
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Feb 24, 2024.
  1. priuslyfe
    priuslyfe Member
    233
    57
    what are some good parts to buy in anticipation of future needs? I know I likely need to buy a valve cover gasket because I likely have some leakage from the gasket around my spark plugs.
    Also thinking maybe to stock up on OEM oil filters?? however I was thinking about going with Wix via Amazon? Have always used Fram because I thought they were good (apparently not).
    T-shirts for Toyota's racing team? I do not know.
    LINK: Genuine Toyota Parts and Accessories: Official Online Store World Toyota
  2. PriusCamper
    PriusCamper Senior Member
    12,731
    5,148
    Pacific Northwest, USA
    There are no needs... Just stock up on synthetic 0W-20 motor oil and filters from non-Toyota sources... If you run across a battery pack or brake booster for super low price buy 'em. You might need those one day.
    priuslyfe likes this.
  3. priuslyfe
    priuslyfe Member
    233
    57
    what? I thought synthetic 5-20 or 30 wsa the recommended oil for Gen 2 Prius? I've always used the Costco or similar brands. Aren't Toyota filters the best oil filters?
    brake booster? I've never had a braking issue??
  4. bisco
    51,895
    inverter pump, brake booster, hybrid battery, 12v battery, water pump, belt,
  5. PriusCamper
    12,731
    5,148
    Gen3 Prius use 0W-20 and I've found Gen2 runs better with it as well... Toyota filters are no different than any other cheap filter. There's plenty of threads on here about that. In general, oil filters are only as good as how often you replace them.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,615
    771
    Southern California
    Does the Gen2 burn oil faster with the lower viscosity? Cars that burn OW-20 (and lower) oil are notorious for burning oil even when brand new.
