P3193 on a full tank
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by IdeamanDave, Feb 28, 2024.
  1. IdeamanDave
    IdeamanDave New Member
    Chicagoland
    I have a 2010 with 200k miles. It had been sitting for a couple weeks and when I went out to start it there was only one bar on gauge and it was flashing. Added a couple gallons for the hell of it, same thing. There was no leak or smell while it had been parked.
    51,899
    why does the title say full tank?
  3. ChapmanF
    18,153
    One bar and flashing means the gauge has forgotten how much fuel you have. Probably the 12 volt supply got too low (you may have had to jump the car?).
    As soon as it figures out the fuel level again, it will stop flashing and show the level.
    The ECM gives a P3193 code if it was going to give you a P3190 or P3191 and the fuel level reading was low at the time. As far as the ECM is concerned, a fuel level of unknown (because the gauge is still flashing and hasn't figured it out yet) is the same as 'low'. So if the engine tried to start while the gauge was still flashing, and didn't, that'll be a P3193.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,045
    1,969
    NJ-USA
    Maybe someone siphoned the gas out of your car? Maybe rodents chewed up the fuel tank wiring?
  5. IdeamanDave
    Chicagoland
    I had recently filled (see pic).
  6. bisco
    51,899
    the pic shows one bar. you added a couple of gallons, which may not be enough to register
  7. IdeamanDave
    Chicagoland
