Help me find a site listing station gas blends
Discussion in 'Gen 2 Prius Main Forum' started by MarinJohn, Dec 27, 2006.
  1. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    I can't find a comparison anywhere. I would prefer to buy better mileage non ethanol gas.
  2. daniel
    14,487
    1,519
    Spokane, WA
    My impression is that gas is gas. No real difference other than octane and (where applicable) percentage of ethanol. Both should be clearly marked on the pump. I think in MN gas must have 15% ethanol by law. In Fargo I only knew a couple of stations that sold ethanol, which I prefered, for environmental reasons. I would be surprised if CA didn't require the numbers to be on the pump as well. So if it does not say ethanol, the percentage should be zero. But then, I don't live in CA so I'm just assuming.
  3. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    <div class='quotetop'>QUOTE(daniel @ Dec 27 2006, 01:48 AM) [snapback]367055[/snapback]</div>
    It's quite frustrating, though, to try to find a pump without ethanol (should that be desired) when the only source is the sticker on the pump. I would also like to find non-ethanol gas, but I haven't even been able to find if Arizona requires E10 or not. My suspision is that OP's Califonia, with its major environmental reputation, does not have any stations without ethanol.
  4. daniel
    14,487
    1,519
    Spokane, WA
    Okay. Someone from CA please tell us: Do most stations in CA sell only ethanol-blended gas? Is it required by law? According to john1701a, ethanol blend is both better for your car and better for the environment. I presume he's been pretty thorough with his research, since he's so thorough in documenting his Prius stats. True, there's slightly less energy in ethanol than in gasoline. But 10% ethanol contributes 10% less carbon to the atmosphere. (I.e., 100% ethanol is carbon-neutral.) That should outweigh the reduced high-mpg bragging rights for an environmentalist.
  5. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(daniel @ Dec 27 2006, 10:04 AM) [snapback]367133[/snapback]</div>
    I don't think the Jury is in on that one yet. The full 'costs' of Ethanol are still being sorted out.
  6. MarinJohn
    3,945
    304
    I'll have to double check, but I don't believe CA pumps are required to post ethanol content as I asked the Arco owner if his gas had it and he didn't know, and his pumps didn't list anything.
  7. allargon
    allargon Member
    113
    Austin, TX
    <div class='quotetop'>QUOTE(MarinJohn @ Dec 26 2006, 11:01 PM) [snapback]367034[/snapback]</div>
    I lived in the Bay Area from 1997 to 2004. They used MTBE for most of that time. However, when I left I believe they switched completely to ethanol. MTBE gets better mileage, but it's murder (literally) on the environment. Leaded gasoline burned more efficiently than MTBE or ethanol. You could always run that to get better mileage! :p
  8. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(daniel @ Dec 27 2006, 12:48 AM) [snapback]367055[/snapback]</div>
    Other than the gas/ethanol ratio and octane, apparently the type and amount of additives in the blend do make a difference.
    See toptiergas.com
  9. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(daniel @ Dec 26 2006, 09:48 PM) [snapback]367055[/snapback]</div>
    I don't believe that's the case. I haven't had a chance to read these in detail, but I stumbled across these while looking around for an answer.
    http://www.epa.gov/otaq/boutique-task-force.htm
    http://www.epa.gov/otaq/boutique/resources...finalreport.pdf
    http://www.gao.gov/cgi-bin/getrpt?GAO-05-421
    From the PDF at the last URL, it says "Although there is no consensus on the total number of special gasoline blends used in the United States, we found that, in addition to conventional gasoline, at least 11 fundamentally distinct special gasoline blends were used during the summer of 2004 in parts of 34 states and covering approximately one-sixth of all the counties in the United States. In the summer of 2001—the last year for which we had data—special gasoline blends accounted for slightly more than half of the total gasoline volume consumed in the United States, with the rest accounted for by conventional gasoline. When different octane grades and other factors are considered, there were at least 45 different blends of gasoline produced and handled by pipelines in the United States during the entirety of 2004. Special gasoline blends are often used in isolated pockets because these blends have generally been adopted in large metropolitan areas in response to severe air quality problems, while surrounding areas have generally continued to use conventional gasoline."
    edit: I also stumbled across this map http://www.exxon.com/USA-English/Files/US%...ap%20100102.pdf, this FAQ http://www.exxon.com/USA-English/GFM/Produ...asoline_FAQ.asp and http://www.energy.ca.gov/gasoline/types_of_gasoline.html.
    Fixed up URLs.
