Cleaning Bus Bars and Nuts
Discussion in 'Gen 2 Prius Technical Discussion' started by Kris_Parker, Mar 3, 2024.
  1. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Yep, another thread on how to clean bus bars and nuts.
    I cleaned my bus bars in muriatic acid, that helped to get rid of all corrosions and build-up. After that I used 1500 in order to polish them and my question, does polishing bus bars makes any difference? Maybe a better conductivity, less internal resistance?
    On the left side I cleaned it with acid only, on a right side I used 1500 in order to polish them. Now they look shiny, but is it worthy to spend time on doing that?
    If I'm not mistaken @PriusCamper suggest using rock tumbler for 24 hours with some water. Does anyone know which one to get, because I never used anything like that? Also does this rock tumbler polish them or just helps to get rid of the corrosion?
    Nuts: I still didn't figure out, on how to clean them. I tried to use Carb/choke &parts cleaner and there is no more corrosions but now they look weird. See the picture. Is it safe to use them on a battery or is it better to get a one ones? Speaking of buying a new nuts, does anyone has a link where a good nuts is can be purchased? Someone did recommended Hybrid Battery Bus Bars | ACENBAY, LLC this website, but I'm not sure if the nuts and the bus bars is good quality there. Anyone has an experience with this guy?
    P.S Finally, I can attach pictures.
  2. Tombukt2
    12,887
    2,315
    If they go in the rock tumbler that you get in the toy department you'll want to get some media mild abrasive. Generally I've tumbled dry personally If you have access you can also use a sandblaster with fine sand or a glass bead cabinet All of that methodology will clean the bus bars and or nuts quite well then if you done the blasting or the tumbling you need to rinse the nuts and the bus bars really well to make sure all the abrasive is out like with varsol or something and then that's it you're good to go there's no polishing needed You may want to use some kind of a spray as you reassemble that will help inhibit corrosion and the frosted nuts in the dark bus bars moving forward I do believe it can be done I'm trying to do it with the CRC red battery spray for connections so far it seems to be working so I leave it alone. It may be cheaper just to buy new bus bars and nuts they come in sets now I think and are fairly reasonable Heck even the Toyota bus bars in the bag with the orange holder and all that is I want to say 50 bucks I just bought one from a guy brand new for like $40 I can't post the pictures here but it's in a Toyota bag I have the part number
  3. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Thank you for comment! I'll try to learn more about rock tumbler since it can clean both bus bars and nuts. I guess you meant The CRC battery terminal protector, I'll try it.
    Tombukt2 likes this.
  4. Carall
    Carall Active Member
    306
    101
    Harrisonburg, VA
    As chemists say on the Internet, the higher the acid concentration, the worse it is for copper. The least harm to copper is from the acid of 5% vinegar.
    Now I use the tinning method. I used to heat the solder with a gas burner and now switched to a solder pot.
    I installed a weak battery in the Prius I've been driving for 8 months now. I have already changed 5 or 6 modules on this battery and there were 2 obviously bad ones when I installed it. I'm surprised this battery still works. When I remove it, we'll see the condition of the tinned bus bars.
  5. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Good evening, so muriatic acid doesn't really work? Based on the picture they do look terrible, did you used any battery terminal protector? Btw did you torqued all nuts to 48 inch pounds? I've read that if nuts is not torqued properly it may cause the corrosion.
    Never used a solder pot, how does it work? How much you spend for this one? Because I just googled and the prices varies from as small as 10$ to 300$ and higher.
  6. Tombukt2
    12,887
    2,315
    So you're going to tin all the copper bus bars . Sounds good You've got the timing all You can also buy bus bars that are made out of different materials hardened etc and just look on eBay and whatnot there's a few flavors so far my copper's done well with just the light spraying of the CRC battery red stuff protector whatever it is I spray it on the back before I offer the bus bars up to the studs put the nuts on torque all that down put a spray of the red stuff across that before I close the black covers and then look in on that maybe once a year just to look so far in the two batteries I've done this to things are looking really well compared to what I took out and what I see almost daily or a couple of times a week when I'm at tow lots and that junkyards this is one of the first things I look at on these batteries sometimes I look at 20 of them a week than they are pretty ugly looking inside working or not doesn't really matter.
  7. Carall
    306
    101
    Harrisonburg, VA
    I still use muriatic acid to quickly clean bus bars. Then I use #0000 steel wool from walmart paint department and then apply water based solder wax from home depot and tin them.
    I've tried a few terminal protectors but they didn't work under such conditions.
    I've tried cutting out new bus bars but they quickly oxidized. The factory uses some kind of special coating for their copper bus bars, but I couldn’t find it what they use. Brand new contacts from the factory last ~5 years. They may turn black, but on the module side at the point of contact they are still shiny.
    I tighten the nuts with a regular 1/4 ratchet.
    I bought solder pot from aliexpress for ~$20. It works. I've used it once so far.
    I’ve used it once so far and it seems to work well, but you need to do it outside, and it was cold outside and even a gas burner couldn’t heat up the solder well.
  8. Carall
    306
    101
    Harrisonburg, VA
    I guess you're taking about this stuff
    Google says CRC Battery Terminal Protect 7.5 oz (Part No. 05046) does not conduct electricity.
    The main goal is to keep contact areas clean.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    I usually use new wire harnesses for my batteries, but when doing inexpensive rebuilds, I always use muriatic acid. Muriatic acid does not dissolve copper, but it does a great job on anything else. It leaves the busbars with a coppery 'matte' type finish, which can be turned into a shiny copper finish in 2 seconds by merely using a wire wheel (i use one in a drill press).
    The oem nuts are just M5x0.8 flange nuts with a slightly larger flange. The ones available from places like MSC or McMaster-Car are plenty good enough and available in stainless steel and are very affordable (like $10-15).
    You can also bypass the busbar and wire tab drama by spending $60 to buy a new wire harness, which comes with all new busbars. Then all you need to clean are the busbars on the side of the battery without all the wires.
    Kris_Parker likes this.
  10. AzusaPrius
    AzusaPrius Senior Member
    2,170
    915
    The bus bar kits from AcenBay are very nice and work perfect.
    I have AcenBay bus bars on my lithium battery, you can also use promo code "azusa" to save some $$$
  11. Tombukt2
    12,887
    2,315
    The can I use is red but similar wording yeah I'm glad to know it doesn't conduct electricity I guess because the two batteries that I treated and all that would this stuff to protect the bus bars and what's under the orange and black covers is working perfectly The battery stays in the green almost all the time seemingly it's ridiculous actually and everything is a okay I haven't seen the magenta since these two batteries have been assembled but I'm also not one that runs a delivery service that spends all day in parking lots sitting around talking on the phone with the air conditioning on running my battery down I know a lot of guys and people who do this I'm not one I get out of the car and go into the air conditioning or whatever usually park in the shade because there's plenty of it where we go and do business things like that so I don't try to load my battery up just because I have one and it's a thing it's not a thing to me I'm not interested in running my battery all the way down into the red and all this sort of thing just because I can but I guess some people just do whatever they want I guess I don't know But so far everything's conducting electricity very well matter of fact I haven't even heard my battery fan come on in a while but I can command it on with tech and it works and it's all clean so it'll come home when necessary It's also not summer time yet I also don't run a lot of heat in the car even in the winter I like it to get about 68 in the car somewhere in that range because I have my outdoor clothes on so I don't want to be burning up. Then that 100° heat you're generating in the cabin from your body the heat of the passengers and all that That's going to cool your battery not so much.
  12. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    So the order would look like this: Disassembly all copper bus bars < Put them into muriatic acid to get rid of corrosion < Brush bus bars with #0000 steel wool in order to polish (clean) them < Then you use Water Soluble Solder Flux Paste on each of the bus bars < Tin them with the solder pot?
    If I got it right, you don't use a torque wrench at all? Just tighten them based on the 'feeling'? I did this on a few batteries because I simple didn't bothered myself with the torque specs and it seems everything is okay even after a few months. Right now I want to do this a little more professional and that's the reason why I try to find what would work the best. Yesterday, I got a simple torque wrench form harbor freight for 20$ (Pittsburgh pro torque wrench 20-200 in. lb.) but for some reason when I set it for 48 in. lb. it just breaks the module, something wrong with it, it does click, and I broke 3 modules already (all of them with a shorted cell).
  13. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    If you're breaking the module studs, it's going way beyond 48 inch pounds. My testing showed they snap around 110 (iirc, it's been a couple years).
    Also, the HF inch pound wrench doesn't really do a true click, more of a "break loose" on an adjustable resistance pivot. Sometimes it takes a bit of use to get adjusted to how it feels. When I purchased mine, I was pretty skeptical of HF and opened a dozen or so of them and picked the two that felt like they had the smoothest ratchet function. There's definitely a difference!! I had one 'calibrated' for 48 and one for 60. Both are still going strong.
  14. Tombukt2
    12,887
    2,315
    You want to be talking and retoring the nuts on the battery studs You do not just want to do this by feel even though I can I don't. This can be mission critical these studs are known to pull out of the plastic and all kinds of nonsense so if you're up for that and it doesn't matter then carry on I use an electric screwdriver literally the kind you twist and it starts to turn gyroscopically yeah to run the nuts up to touch and then I go back across and torque them down with a torque wrench and that's just what you probably should be doing so that you don't have to disassemble the mess again to undo a fubar.
  15. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    It's weird because I tried to go lower to 30 in. lb. and it still just breaks the module studs, in other words it's too strong. I got used to the idea that there should a click when you hit the right torque spec. I will probably return this torque wrench back and look for something better.
    Alright after some research (since website was down I had plenty of time) and tons of video review on different torque wrenches I understand that this kind of torque is not made for low specs like 50 in. lb. The accuracy drops below 100 in. lb. even if that a good torque, beside that I look at various wrenches and a lot of them share the same problems. The accuracy for low specs is bad, after 1000 cycle many of them fails in accuracy, the click doesn't present or it's very hard to hear it, they don't stop at the torque you choose and go beyond than that, so you should be careful. At this point I think going with torque screwdriver is the best decision, since they good on low specs and do not go beyond the torque you choose. Wheeler torque screwdriver seems to be the most accurate compare to others, also it does have a good accuracy even after 1000 uses. Here is a video if anyone interested: Best Torque Screwdriver?
  16. rjparker
    10,054
    6,221
    First realize 48 in/lb is only 4 ft/lbs. Very little torque. Second the HF reviews have several indicating buyers broke bolts using this wrench. Others state they never get a click when set under 50 in/lbs.
    Some HF tools are pure junk. I once bought an air compressor that could not build up enough pressure to inflate a tire. Back it went. I like their $3 multitool screwdriver but that is about it for cheap HF tools.
    Either spend some money on a quality in lb torque wrench or just snug them up decently.
    #16 rjparker, Mar 5, 2024
  17. Carall
    306
    101
    Harrisonburg, VA
    Yes, the order looks right. I use the same #0000 steel wool to clean everything else on hybrid battery.
    Just a little bit of paste is needed to make them moist or all the excess will burn in the solder, clogging it. It is better to do this outside or with a fan so that the smoke of the burning paste go outside. Right after dipping a bus bar in solder, I hit the pliers with which I hold the bus bar against a big hammer so that the excess solder comes off.
    After cleaning them with acid and steel wool, you should immediately tin them and not leave them till next day, otherwise they will darken and then it will be difficult to clean them so that they are suitable for tinning. I use lead free solder. I bought 1lb of lead free solder and I think it will be enough for at least 20 batteries.
    Lead Free Bar Solder for sale | eBay
    For me this is the most obtainable and working method. You can even plate them with silver or gold, but you will still have to clean them every few years.
    Yes, i just tighten them based on the 'feeling'.
  18. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    I agree on that. Most of the torque wrenchs is not going to work under 100 in. lb. correctly or accurately. That's why I'm looking into buying a torque screwdriver which is made for low torque.
    Well, after all you get what you paid for.
  19. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Thank you for detailed answer. Now I got at least 3 different methods on how to clean bus bars, I'll try all of them in the future and see which one is the best. Btw I'm really interested in how the tinned bus bars would look like, please keep me posted.
  20. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Just to clarify, does any wire wheel can be used or is there something specific I should be looking for?
    I looked at MSC, not sure if I'm looking at a wrong thing but, the flange nuts out of stainless steel is 87$ for 100 pieces. On McMaster-Car, I found two options "Metric 18-8 Stainless Steel Serrated Flange Locknuts" 12.09$ for 100 pieces, the other one is "Metric Super-Corrosion-Resistant 316 Stainless Steel Serrated Flange Locknuts" 10.86$ for 25 pieces. On Acenbay the price for Wide Flange Nuts is 11.97$ for 70 pieces. Based on that, either way it's 100 pieces for 12$ or 70 pieces for 12$ but they are made for HV batteries specifically (not sure if they work the same way as the website states).
