Cruise Control Setting vs Speedometer Reading
Discussion in 'Gen 5 Prius Technical Discussion' started by Roy Peterson, Mar 1, 2024.
  1. Roy Peterson
    Roy Peterson Member
    92
    122
    Richland WA
    2024 Prius Prime
    Took delivery of my 2024 Prime XSE Premium and note an anomaly with both normal and adaptive cruise control. The speedometer reading is always 1 mile lower than what the cruse control speed setting is. For example, set 70 mph on cruise and speedometer reads 69 mph. I expect better from Toyota especially now that modern cars are digital and communicate thru a canbus network.
    Before going to dealer , anybody else have similar experiences? As stated, this anomaly occurs both normal and adaptive cruise and EV or HV modes.
    Cheers
  2. RandyPete
    RandyPete Active Member
    370
    150
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Yea, I noticed that also. But figure 1 mph is not that big a deal. Wonder if others have also noticed this. I also noticed that the speed limit sign turns to red when I am 1 MPH below the posed speed limit. That also seems odd, but not really a problem to me.
  3. vvillovv
    vvillovv Senior Member
    4,316
    1,495
    NY
    Can only imagine the conversation with the service writer and anyone else getting involved in the converstaion about DRCC mph setting showing as 1 mph less on the speedometer.
    Anyone with a Gen 4 notice this behavior?
  4. Hammersmith
    Hammersmith Senior Member
    1,893
    1,883
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I think it's a buffer to prevent the car from exceeding the set speed in certain cases. I've noticed the cruise control has about a 1mph "play". When starting to come down a hill, or when the headwind changes, or a lot of other factors, I see the speedo match the set speed. If the car defaulted to the actual set speed normally, that play could mean the car would exceed the set speed for periods of time. I figure Toyota is playing it safe(it is Toyota after all) and setting the default cruise speed on the low end of the range. I just always set the cruise to 2-3 mph above my desired real speed(since the speedo itself is 1-2mph fast).
    As for the speed limit sign going red, I'm pretty sure that's the result of different rounding systems. I think the speedo rounds the exact speed and the speed limit system doesn't. So say the speed limit is 60. The car is driving 60.2mph. The speedo rounds that to 60, but the speed limit system says everything over 60 turns the indicator red. If the car drops to 59.9999, the speedo stays at 60, but the red sign turns off. If the car increases to 60.50001, then the red sign stays on and the speedo flips to 61.
    Jason Mosiman and Jeff606 like this.
  5. vvillovv
    4,316
    1,495
    NY
    And how steep a downgrade before the speedo goes 2 or 3 mph over the set speed, or 2 or 3 mph under the set speed when climbing?
  6. Gokhan
    Gokhan Senior Member
    5,541
    2,182
    Paramount CA
    Yes, it is the same thing in my 2021 Prius Prime Limited. If you set it to, say, 70 mph, the speedometer speed will vary between 69–70 mph.
    Moreover, the actual speed is 2 mph less than the speedometer speed.
    BiomedO1 and vvillovv like this.
  7. Mendel Leisk
    40,260
  8. HacksawMark
    HacksawMark Active Member
    449
    317
    Oregon
    2023 Prius Prime
    XSE
    I turned mine off. It was an annoying distraction.
  9. BiomedO1
    2,593
    1,394
    SacTown, Ca
    It's operating the way it should. I believe there is a plus or minus 1-2 mph deviation to set-point. Watch your speedometer next time the roadway dips below grade at a crossing - I'll bet your speedometer will rise up to 71 mph - if it's a large enough dip. If the car is forced to maintain a set speed, exactly, I believe in most cases - you'll burn more fuel. The cars CPU doesn't know what's coming, incline, decline, wet pavement, so a "skate mode" designed to conserve energy. When the car's speed drops down to or at 1.5 mph below set-point, the ECU sends more power to the wheels. If the opposite occurs, you'll see the engine shut-off and the car will drop into charge mode, applies regenerative braking.
    IMHO; if it really bothers you that much - set CC to 71 mph to achieve your desired 70 mph. We're not robot and can think for ourselves.
    Hope this Helps....
    #9 BiomedO1, Mar 2, 2024
    Trollbait and Mendel Leisk like this.
  10. Roy Peterson
    Roy Peterson Member
    92
    122
    Richland WA
    2024 Prius Prime
    I retired from the commercial aviation engineering world. As such, my expectations may be a bit more extreme . That said, cruise control on my Ford and Subaru vehicles were right on. Set at 70 and speedometer reads 70.
    My posting was to learn if this was nature of the vehicle from others and not an anomaly with my car. I have been setting the CC 1 mile above what I want to cruise at and will get therapy to deal with possible OCD
    Thanks for the replies.
    Cheers
    BiomedO1 and Mendel Leisk like this.
  11. Gokhan
    5,541
    2,182
    Paramount CA
    That is because some people don't know anything about control theory. They don't realize that the feedback loop works according to the error signal, in this case about ±1 mph. Trying to make this error smaller can cause other problems, worsen fuel economy, etc.
    Control theory—Wikipedia
    #11 Gokhan, Mar 3, 2024
  12. Mendel Leisk
    40,260
    Reminds me of steering a ship.
    As an ordinary seaman on a DDE (Canadian destroyer escort), part of most every at-sea shift included a stint at steering. My first time , after several tense minutes trying to stay precisely on the bearing, the other guys shared some tips. Mainly, to loosen up, let it wander a bit. If it continues to drift, then nudge it back, give it time to react.
    They also gave an analogy: if you were flying over when someone was over-correcting while steering, you'd see the ship following a sawtooth-like course.
    #12 Mendel Leisk, Mar 3, 2024
    Gokhan likes this.
  13. Kenneth111
    Kenneth111 New Member
    London
    I haven't experienced the exact issue, but it's worth checking with the dealer. It could be a calibration discrepancy.
  14. Gokhan
    5,541
    2,182
    Paramount CA
    That is a very good example.
  15. N79PT
    N79PT Junior Member
    37
    Sonoma County
    2024 Prius Prime
    SE
    Mine operates as OP mentions.
    On a side note: on a recent 2400 mile road trip through mountainous areas of CA, AZ, and NM the cruise control speed did vary slightly but only by +/- 1 MPH on the inclines. I was amazed how accurate the system is and how powerful the ICE is.
    Gokhan likes this.
  16. vvillovv
    4,316
    1,495
    NY
    I drive on one stretch of hwy that dips for 1/3 mile with the steepest dip at the bottom followed by a kinda steep uphill for another 1/2 mile. If I set cruise at anywhere between 55 and 60 the cruise has to hold speed going down and always losses 2 or 3 mph going up the other side. If I set cruise at 62 mph or above, it has always held the speed it was going (61 mph or above) when I got going up the other side. Doesn't matter if it's set in DRCC or Classic Cruise.
  17. Approximate Pseudonym
    106
    55
    Colorado
    2024 Prius Prime
    XSE Premium
    I would be fine with a cruise control that kept a 5-6 mile per hour window (±2-3 mph) instead of the ±1 mph window that the Prius seems to keep.
    If anything, it’s not loose enough for me. I drive on varied terrain in Colorado where trying to maintain an exact speed is way more inefficient than letting the car approximately keep a target speed.
    In Volkswagens and Hondas, I’ve seen the same ±1 mph variation, so the Prius behavior seems acceptable for a cruise control system.
    Trollbait likes this.
  18. Trollbait
    12,247
    You might be able to adjust acceleration rate of the cruise control. In practice, the lowest rate might work out as a larger mph window.
    Approximate Pseudonym likes this.
