Donut Spare for Prime, With Picture
Discussion in 'Gen 5 Prius Main Forum' started by ken2023, Mar 7, 2024.
  1. ken2023
    ken2023 Member
    70
    53
    new jersey
    2023 Prius Prime
    XSE Premium
    Wheel 42611-21280, $73.97
    Tire, T145/90D-16 YOKOHAMA Y870B SL, $97.20
    Mounting: $15
    Total: $186.17
    Trunk fit is fine for me, pretty rare that I would have enough cargo that I couldn't accommodate it, biggest load is with groceries and can still dump stuff in the middle. Thanks for the parts info @Hammersmith . 10K miles on it and no flats or bubbles so far, have hit some decent potholes, but I'm taking a long trip shortly. Tire plugs & pliers, other tools stashed under the deck.
    Gokhan, Yvrdriver, bisco and 2 others like this.
  2. Zeromus
    Zeromus Active Member
    471
    241
    Ottawa Canada
    2024 Prius Prime
    SE
    Thanks for the photo! I am considering getting a donut myself for any long trips we take, I am not really concerned for local trips at all. It's easy for me to address issues if local since I'm in a large city. My only worry on space now is whether I can accommodate *luggage* rather than normal every day stuff with the tire in there. We have small kids so there's lots to take with us when we go on longer trips.
    Then again, I've never had a flat on the side of the road due to road conditions. Only thing I've ever had was a blowout when I was young and stupid and didn't know anything about making sure there aren't bulging spots on old tires. And well, a donut doesn't help when you have a blowout, there's way worse going on at that point lol.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,322
    2,324
    Taylors, SC
    With Gen 3 Prius models that came with a spare, Toyota provided a web strap with a cam buckle to secure at flatted tire to the trunk using the tie down points.
    I'd get these equivalent strap from Walmart;
    Hyper Tough, 13 ft x 1 in Cam Buckle Lashing Strap Tie Down, 200 lbs., 2 Pack
    $5.48
  4. vvillovv
    vvillovv Senior Member
    4,316
    1,495
    NY
    Check that there is a way to secure the straps, in Gen 4 Prime, to secure straps, interior panels need to be removed before finding any way to secure straps.
    A plastic bag or cover for the flat or full sized spare wedged between the passenger side front seat and the back seat - recommended by @Salamander_King seemed to me to be the easiest, safest way to secure a tire in the Prime.
    Gen 5 Prime ( without AWD ) may have unused space in the spare well for the donut. like the Gen 5 regular Prius has.
    #4 vvillovv, Mar 7, 2024
  5. Mendel Leisk
    40,259
    Scissor jack and lug nut wrench also missing with 5th gen?
    GcinFl and RandyPete like this.
  6. Zeromus
    471
    241
    Ottawa Canada
    2024 Prius Prime
    SE
    There are hook spots for a spider wrap thing that's sta card in canada to secure loose items in the trunk available and exposed. So hooks won't be an issue.
    And Mendel, no Jack or tools provided.
  7. vvillovv
    4,316
    1,495
    NY
    You might want to check the specs on how much weight those hooks are rated to hold. If they're at all the Gen 4 hooks, they wouldn't hold even the donut during a hard brake much less an accident.
  8. bisco
    50,829
    don't store anything back there
  9. ken2023
    ken2023 Member
    70
    53
    new jersey
    2023 Prius Prime
    XSE Premium
    There are four "cargo hooks" in the trunk that are intended for tying down cargo. They are pretty solid D-rings, but not specified for any particular maximum weight, but are adequate to hold down a wheel. The area under the deck has more than enough space for a scissor jack, reflector.
    vvillovv likes this.
  10. RandyPete
    RandyPete Active Member
    370
    150
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Any Part numbers for those toyota tools ?
  11. Hammersmith
    Hammersmith Senior Member
    1,893
    1,883
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Must not comment that the part numbers are listed half a dozen times in the OEM spare tire thread.
    I'm sorry, what was that?
    MSRP - Lewis - Part Number - Official Name - Description
    $238.85 - $165.14 - 09105-52030 - Box Set, Jack - includes just the tools
    $130.56 - $ 90.26 - 09105-47020 - Box Set, Jack - includes the tools and a small bag for the jack handle and lug wrench
    $532.24 - $367.98 - 09105-47030 - Box Set, Jack - includes the tools and a large bag for everything
    Before you ask, no, I have no idea why the crazy pricing.
    RandyPete and vvillovv like this.
  12. RandyPete
    370
    150
    2024 Prius Prime
    XSE
    Thank You.
    I'll try the 09105-47020 for my 24 PP XSE. Hope it works.
  13. Georgina Rudkus
    3,322
    2,324
    Taylors, SC
    My dad's friend made these that fit a generic scissors jack with a flat top like a generic Big Red or Tonda sold for $20-30 on Amazon.
    It's a perfect fit on all Toyota pinch welds. All you'd need to do to adapt the jack is to drill one small 5/16 inch hole of the jack's top center.
  14. RandyPete
    370
    150
    2024 Prius Prime
    XSE
    Jack up both wheel/tires at the same time ?
  15. Georgina Rudkus
    3,322
    2,324
    Taylors, SC
    Yes, that's the $23 1-1/2 Torin Big Red jack sold on Amazon, with my dad's friend's pinch weld adapter.
    Walmart sells the same Torin jack under the Hyper Tough store brand for $28 nationwide.
    Currently, my favorite is the 2 ton silver colored Tonda scissors jack selling for $20 on Amazon.
    Beware! Most OEM jacks are very high quality. That's why they demand a higher price than the ones sold cheap.
    I have carefully examined and personally tested the ones that I noted and found them to be close to OEM quality and are larger and even sturdier and more stable than some OEM's.
    #15 Georgina Rudkus, Mar 7, 2024
    GcinFl likes this.
