Trouble with seized fill/drain plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SilverTabby, Feb 22, 2024.
  1. Mendel Leisk
    40,467
    Just tell a dealership parts department what you need?
    SilverTabby likes this.
  2. JohnPrius3005
    JohnPrius3005 Active Member
    423
    234
    California and Hawaii
    Possibly many of us have learned that buying from any dealership parts dept. involves them selling you a bolt for $12.59 that was sourced from China for 7c. Now $12.59 may not break your wallet, but it sure feels bad when you know this. And many people will go to considerable lengths to avoid this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,343
    2,337
    Taylors, SC
    IMG_3934.JPG Any drain plug having an M18x1.5 thread pitch will work. On Amazon, you could purchase them in steel, aluminum and stainless steel.
    I prefer aluminum with neodymium magnets.
    #23 Georgina Rudkus, Feb 27, 2024
    mjoo, JohnPrius3005 and SilverTabby like this.
  4. ASRDogman
    ASRDogman Senior Member
    7,114
    3,713
    The drain for the inverter is on the radiator, works the same way. And plastic.
    If you striped that out, you'll be looking at a new radiator...
    The transmission ones are metal.
  5. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
    On the Gen 3 Prius, the inverter coolant drain is not on the radiator. It is on the bottom of the inverter. It uses exactly the same plug as those on the inverter drain and fill transaxle fluid ports.
    The Prius C has the inverter drain on the hose as does the Gen 4, both of which use the same type of yellow winged plastic plug with an O ring seal as the radiator,
    #25 Georgina Rudkus, Feb 28, 2024
  6. SilverTabby
    SilverTabby New Member
    US
    I was so confused about it because it's called oil drain plug.
    But this is exactly it! Thank you so much!!
    I called the parts department at the dealership, and the person verified that this one works.
    And it turns out that this drain plug also works for the fill and drain for the transmission fluid compartment.
    Thanks. Yes, I did eventually call the parts department. And they helped me to verify that the 90341-18016 part works.
    I was hesitant to call them without finding more because when I did a search with the various keywords: inverter, drain plug, coolant... the result that sounds like it the most was this Plug Kit, Inverter Drain MSRP for $40 USD (part number: 04899-47060). Unless the person really knows the parts, otherwise they'll probably pull up the same search results.
    Thanks. I was definitely putting off calling the parts department. :ROFLMAO: Some of their items are definitely much more than aftermarket counterparts (such as the oil filter wrench).
    However, I do want to say that some of their regular maintenance parts are actually very decently priced, like their oil filter 04152-YZZA6 ($5), engine oil drain plug gasket 90430-12031($1), engine air filter 17801-YZZ12 ($17). The drain plugs that I'm looking for this time 90341-18016 was about $3. The washer/gasket's part number is 90430-18008 / 90430-A0003 ($2).
    What I learned from one of TheCarCareNut's video was that there are original parts that are very expensive, but Toyota also makes the economic versions of the same items for cheaper (see how some of the parts have letters in it?).
    Also, some of the fluids (ATF for transmission & Super long life coolant) don't need to get changed that often. And they are probably cheaper than if it's done at the shops. So I think getting parts from the dealership is still something worth considering. Also, ordering on their website is cheaper than buying it in person (at least that's the case with the dealership close to me).
    I would have definitely seriously consider these aftermarket parts if the parts at the dealership were more expensive. Fortunately, this time, it was only $3. But it's definitely good to have options.
    The one I stripped was the metal one. I was having so much trouble with the transmission fill plug and inverter coolant drain plug I forgot I could change the engine coolant. This one is also on my list of to-dos, hopefully it won't be so stuck like the other ones.
    The Gen 3s plug uses a 10mm hex, but I vaguely remember other people mentioning that the Gen 2s uses a 24mm? So I'd assume they use different plugs.
  7. ASRDogman
    7,114
    3,713
    Brain fart on my part! :confused:o_O
  8. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
    These are steel M18x1.5 with 19mm hex heads and aluminum washers and will fit perfectly on the Gen 3 Prius transaxle. Nice thing is that they are only $8.49 on Amazon.
    X AUTOHAUX 5 Sets M18x1.5mm Metal Car Engine Oil Pan Drain Cap Screw Bolt Plug with Gasket
    I purchased a set myself and can assure anyone interested that they will fit.
    SilverTabby and Tombukt2 like this.
  9. Mendel Leisk
    40,467
    I use a Honda oil filter wrench (prefer to call it a socket, seems more to the point). In my experience Honda, Toyota and Mazda all have the same oil filter dimensions.
    the Honda oil filter socket is heavy gauge stamped steel. Back in the eighties their automotive division used a larger oil filter, and the current size was only used on their motorcycles. I had one of each oil filter sockets.
    maybe in the nineties they adopted the motorcycle oil filter into their cars. Anyway, still using that same (originally purchased for Honda motorcycle) oil filter socket, indestructible, currently on those 3 makes.
    you can likely get one through any Honda dealership, also available on Amazon.
    addendum: looks pricey on Amazon right now, believe this is it:
    Genuine Honda Oil Filter Wrench (65mm) - 07AAA-PLCA100
    part no indicated in above:
    07AAA-PLCA100
    again, local Honda dealership parts department is likely best bet for sourcing this.
    #29 Mendel Leisk, Feb 29, 2024
  10. Tombukt2
    12,009
    2,123
    ...these old plugs were used on all older toys like 70 80 w 5 trans rear diffs etc . Tool box have a few in they're too .that m18 was real popular.
  11. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    737
    Monument, Colorado USA
    Yep, those transmission drain/fill plugs can be a PITA to get to break free. In 2020, my daughter bought a used Sienna (2012) with 140,000 miles on it. After I looked it over, I debated NOT changing out the transmission fluid because, at that age/miles, sometimes changing out the fluid can do more harm than good. But it didn't took too burnt so I went ahead and did the service.
    Removing those drain/fill bolts did, probably, take about 130 ft/lbs and I didn't spray any penetration oil on there. When you put on the hex socket, give it a few wacks of the hammer which helps to seat it and, also, can jar the threads a bit which can help them break free.
    If it doesn't break free, go ahead and spray it with pen lube and let it sit for an hour or so. (I like good old bolt blaster.) I've done a LOT of cars and never had to drill one out or use heat on them....thank Goodness! Having replacement bolts, also, gives you confidence to go ahead and tug hard on the thing.
    SilverTabby and JohnPrius3005 like this.
  12. SilverTabby
    US
    Here's an update:
    This morning I put on penetration oil on the transmission fill and drain plugs and inverter coolant drain plug. Waited an hour, then put on some more. After half and hour or so, I went back to the car and tried to crank it open.
    This time I intentionally did not lift the rear right away so that there's more clearance under the car. The bolt was still on too tight, so I ended up using a jack to pop it open. I came across this method from this guy's youtube video (I can't link links yet, but here's the video id if anyone is interested: 3ochltBWUdE). I was very careful in positioning the ratchet. I also put a ramp under the jack, so that the jack would be pushing up at an angle. When the fill plug and drain plug eventually broke free, there was a loud popping sound. After that, I was able to turn the plugs by hand.
    As for the inverter coolant drain plug, I still couldn't get it out. I used this (Powerbuilt 240094 8 Piece Zeon Metric Hex Bit Socket Set - with use for Damaged Fasteners, Standard, Rusted, Rounded Bolts, Size from 3mm to 10mm), but it felt like I was just stripping the bolt more. So I stopped after several tries (+ many hammer taps). In hindsight, maybe it's suppose to work like that?? o_O Anyhow, I plan on getting some chisels and next time I'll try using a chisel method that I saw on Youtube.
    Could you please elaborate on what you mean by can jar the threads? (My search just pulled up mason jars :ROFLMAO:)
    On a separate note, I drained the engine coolant without much problem :D.
    Today was a very long and tiring day, but it felt like a small victory.
  13. Mendel Leisk
    40,467
    I’ve also heard “shock the threads”. This is what an impact wrench does, with a series of hammer-like, rapid-fire, counterclockwise twists on the bolt head. A physicist would maybe use the term inertia? You hit something so fast it’s surroundings stay in place, and that something is gone.
    I was trying to break loose exhaust bolts recently, and my cheapie, corded electric impact wrench finally did the trick. Had to hold it on a few seconds, and the rapid-fire impacts slowly got it turning.
    another trick would be to heat the surrounding metal, say with a propane plumbers torch, then quickly hit the bolt. The heat will expand the surrounding metal slightly. Though aluminum casing of the transaxle, filled with coolant, may make that a bust; too difficult to heat effectively.
  14. ChapmanF
    17,186
    There's also a kind of tool called a "seized fastener removal kit" that works with an air hammer.
    Where the familiar impact socket driver is applying high impact torque in the rotating direction, these seized-fastener tools just apply air-hammer impacts, couple thousand a minute, straight down on the fastener while you apply normal steady torque to turn it. I have found them to work really well, especially on smaller stuck fasteners where high impact torque would probably just break or strip them.
    Either way, it's the rapid blows shaking loose the threads that have stuck to each other, and the twisting torque that then unscrews the thing.
  15. SilverTabby
    US
    Thanks, I'll look into the electric impact wrench and the seized fastener removal kit with air hammer.
    I'll stay away from torch though, because I already applied penetrating oil on it, and those are quite flammable.
    Though I probably won't have time to work on it again till several weeks later.
  16. ColoradoBoo
    1,132
    737
    Glad you, at least, got that tranny plug off. I've, also, heard a "pop" sound as the sucker finally broke free!
    In my Gen 4 Prius, we just use two plastic drain cocks on the radiator (one is yellow and one is white) to drain the coolant from the radiator and traction system. The Car Care Nut, on YouTube does have a video of him breaking the drain bolt on the bottom and it look like it was quite stuck...he's a pretty strong guy so got it off, and did make a pop sound.
    Georgina Rudkus likes this.
  17. ColoradoBoo
    1,132
    737
    I thought of this thread this weekend as I had my son-in-laws old 2008 Rav4 getting her maintenance caught up. I noticed the front differential fluid had not been changed so I had a few qts of 75W-90 gear oil so decided to do the job. That 24mm fill plug was so tight I had to get out the big breaker bar and, even then, had to REALLY get brutal with it.....finally it popped free. (I was going to spray some Bolt Blaster pen oil on it, first, but I couldn't find the can...I need to clean out my garage.) The drain plug was, also, tight but it also popped off. Again, I doubt this job had ever been done...the magnet was pretty filled up with small metal debris and it seemed to take quite a bit more than what drained out.
  18. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
    Just replace the socket headed hex plugs with hex head plugs, and you'll never have future problems in removing them.
    ColoradoBoo likes this.
  19. ColoradoBoo
    1,132
    737
    Hey, THAT is an excellent idea!! My Tundra is due for her 3-year front/rear/transaxle fluid changes so I'll get those!!
  20. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
    $8.50 with aluminum gaskets on Amazon.
