3rd gen model year and oil consumption
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Nov 19, 2018.
  1. 2010~2013 with minimal oil consumption
    54 vote(s)
    47.0%
  2. 2010~2013 with moderate oil consumption
    17 vote(s)
    14.8%
  3. 2010~2013 with heavy oil consumption
    22 vote(s)
    19.1%
  4. 2014 with minimal oil consumption
    5 vote(s)
    4.3%
  5. 2014 with moderate oil consumption
    2 vote(s)
    1.7%
  6. 2014 with heavy oil consumption
    0 vote(s)
    0.0%
  7. 2015 with minimal oil consumption
    18 vote(s)
    15.7%
  8. 2015 with moderate oil consumption
    0 vote(s)
    0.0%
  9. 2015 with heavy oil consumption
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. kc410
    kc410 Active Member
    263
    252
    2010 Prius IV
    Don't know why I waited so long. Just added my vote(s):
    2010 253K Heavy
    2015 73K Minimal
  2. Andy Pants
    Andy Pants Member
    36
    28
    WIsconsin
    I've been lurking and researching so I have already checked out your links and they have been extremely helpful! Sure hope its not the head gasket but I guess the good thing is that if it is starting to go I will already be half way to replacing it with all the egr/intake removed. I also decided to do the water pump and thermostat since those have never been replaced.
    #102 Andy Pants, Mar 11, 2024
    Brian1954 and Mendel Leisk like this.
  3. bdc101
    bdc101 Member
    250
    89
    usa
    My 2010 has just shy of 265,000 miles today. The oil level hasn't moved since I replaced the head gasket and got it running 3 months and about 2,500 miles ago.
    ASRDogman and kc410 like this.
  4. douglasjre
    douglasjre Senior Member
    2,175
    717
    Null, NL
    I know 7 ways to diagnose a head gasket... but u always start all diagnostics w pulling codes. If MIL off pending will show histeresis of past 5 triggers. U need techstream.
  5. kamrul
    kamrul Junior Member
    99
    17
    Bangladesh
    Which one do you use the Gallon Jug (3.78 Liter) or multiple Quart Bottle (946 mL each) ?
    Because the owner's manual says to refill 4.4 qt. (4.2 L) with filter or 4.1 qt. (3.9 L) without filter.
  6. johnHRP
    johnHRP Active Member
    644
    186
    KA, DE
    Excel
    In my case it is 4L to the Max level with a filter change. Try 3.8 L first and you will be at the mid point.
  7. kamrul
    99
    17
    Bangladesh
    Would it be ok to fill up 3.78L with a new filter?
  8. johnHRP
    644
    186
    KA, DE
    Excel
    Yes, minimum is 3.5L, maximum is 4L. At least for my 3rd gen with catridge filter. if I put 4.2L, it is always 3-4 mm above the max line and I leave it alone and never cause issues either for less than 1L overfilled.
  9. Mendel Leisk
    41,375
    I drain the oil with the front raised quite high, which may assist with draining the last at the bottom of the pan. Also, I'll start it draining, then go inside for a while, let it drip. Anyway:
    After all that, I put a measured 4.2 litres (using a graduated pitcher). I don't even check it then, leave it a few days, drive the car, let it sit. Then, checking the oil first thing in the morning, level slab, it's about 3~4 mm below the top mark on dipstick.
    kamrul likes this.
  10. johnHRP
    644
    186
    KA, DE
    Excel
    That makes sense, I drained using a Jackstand that was just enough for my hand to remove the filter. I did not raise it too high from the right side (engine side) of the car. 4L is just close to the Max line.
  11. ASRDogman
    ASRDogman Senior Member
    7,561
    3,902
    It is not an exact measurement. Many factures involved. How much is completely drained.
    Is the car level?
    Just check the level afterward. It's always best to keep it near the full mark. But if it's half way
    it's still okay.
    kamrul likes this.
  12. Mendel Leisk
    41,375
    I've found right after refilling, even if you've run the engine a minute, filled the oil filter, it can read (erroneously) high. I've learned the hard way to just put in the usual, ignore it for a day or two before checking.
    kamrul likes this.
  13. kamrul
    99
    17
    Bangladesh
    Do you replace the oil filter every time you put new oil? Also for the new oil filter, do you soak it first with the oil before placing it?
  14. rjparker
    10,114
    6,277
    Some in the USA change the oil every five thousand miles but change the filter at ten thousand. Every time is best but the filters are rated for 10k miles. Your country may be different.
    Most do not oil the filter element.
    An upgrade can be the use of a spin on filter and bracket rather than the element.
    #114 rjparker, Jan 2, 2025
    douglasjre likes this.
  15. johnHRP
    644
    186
    KA, DE
    Excel
    I changed the oil every 5k miles but filter every 10k miles/1 year. Just because the filter takes more time to remove but damn cheap €4.
    I like the cartridge filter because I can always see the filter condition anytime I open it and the anti drain back and by pass valve is guaranteed right.
    CR94 likes this.
  16. ASRDogman
    7,561
    3,902
    Oil filter EVERY time. There's no point in changing the oil if you're not going to change the filter.
    Some do the filter and not the oil. Some oil and not filter.
    The BEST thing is to change both at the same time. Filter's are $5.
    An engine is $2000 and up. Plus $1500 and up for labor.
    I soaked it in oil, like I would do for the canister filters. But it was a mess installing it.
    It's side ways, so the oil will pour out. I tried once to soak it, then drained the oil out.
    It was still messy.
    The bearing have enough oil left on them to protect them for the 1-2 seconds there is no pressure.
    #116 ASRDogman, Jan 2, 2025
  17. Mendel Leisk
    41,375
    Yes to the first, and no to the second.
    FWIW, Honda recommends oil filter changes at every second oil change, alternate between oil change only and oil/filter change. Their dealerships tend to ignore that though.
    I did the aforementioned oil filter conversion, found the parts very reasonable through Amayama. There’s a few threads here on that, Google PriusChat spin-on oil filter conversion.
  18. johnHRP
    644
    186
    KA, DE
    Excel
    The oil in autopartstore in the USA like Autozone, O'Reilly, Napa, Advanced, etc. often offer 5Q oil+filter as a deal. I replaced the filter all the time when changing the oil but now I am getting lazier. The filter does not work that hard in Prius engine unlike heavy duty diesel. Not much particulate carbon or oxidized oil.
    However, the oil still often trap on the oil control rings that is too small and not enough tension to scrap them back.
    In combination with low tension piston rings, the oil standard in 2010s are also still API SM instead of SN or much better SP. If we can use European ACEA C5 standard or manufacturer standard like 508/509 or BMW LL-17, then go with it if the price are the same.
  19. douglasjre
    2,175
    717
    Null, NL
    What do you suppose it is that when I change the oil and the filter dumping 5 quarts in brings the oil level exactly to the full line?
  20. johnHRP
    644
    186
    KA, DE
    Excel
    I think 5Quarts is overfill but still OK. It is up to you. I usually starts with 4Q or 3.8L, It is right at the middle but I usually top it off till max line or about 4L, 4.3quarts. I only jack the car from the passanger side so I have space to open and fold the engine cover to drain the oil.
