Heater blowing cold
Discussion in 'Gen 3 Prius Technical Discussion' started by timnthomas85, Feb 24, 2022.
  1. ASRDogman
    ASRDogman Senior Member
    7,541
    3,894
    Did you flush out the radiator?
    How fast did you add coolant? You need to fill it very slowly, and with little amounts.
    Takes longer, but no trapped air.
    Bobbi81 likes this.
  2. Brian1954
    Brian1954 Senior Member
    2,140
    828
    South Central PA, USA
    Replacing the rotor/impeller would be my plan "A". Pull out your existing water pump and check how hard it is to rotate the impeller. If there is resistance to it being rotated, pull out the impeller and look at the white plastic that covers the magnet end. Do you see splits or swelling in the white plastic. If so, I would try just replacing the impeller. If not, I would replace the complete water pump (plan "B").
    Bobbi81 likes this.
  3. Bobbi81
    Bobbi81 Junior Member
    Hi again, Thanks for your advice. I ordered the rotor, but the original one was seized and didn't come out from the shaft; I replaced the whole water pump, and the problem was solved!!
    Danno5060 likes this.
  4. ASRDogman
    7,541
    3,894
    Did you remove the little "O" ring on the shaft to remove the empeller?
    At least you found the issue!.
  5. Bobbi81
    Yes, I did. But the rotor was just locked!
  6. Brian1954
    2,140
    828
    That does not surprise me since the previous owner put stop leak in the coolant.
    ASRDogman likes this.
  7. Bobbi81
    Now there is a small issue, my engine temperature won't go more than 136 f or 55 c usually in the city. I use to drive 5-6 hours a day and heater is really hot in med fan, and still a bit hot on high but normal temperature in normal mode is that.
  8. Bobbi81
    NewNow there is a small issue, my engine temperature won't go more than 136 f or 55 c usually in the city. I use to drive 5-6 hours a day and heater is really hot in med fan, and still a bit hot on high but normal temperature in normal mode is that.
  9. ASRDogman
    7,541
    3,894
    It had the fake stop leak. It clogs everything except the leak.
    So your radiator, heater core, thermostad, coolant pump, and every little
    passage for the head and more are clogged.
    Using white vinegar and water mix might clean it out.....
    Everyone that has gone through this has had a nightmare of a problem trying
    to get it all cleared out.
