Need Reading Glasses for Digital Rear View Mirror
Discussion in 'Gen 5 Prius Main Forum' started by PiperJ3, Mar 14, 2024.
  1. PiperJ3
    PiperJ3 New Member
    Ohio
    2024 Prius
    Limited AWD-e
    I just bought 2024 Prius AWD Limited with Digital Rear View Mirror and have discovered that it needs eye focus at close range unlike conventional mirror with focus at distance. I'm struggling to find driving glasses with bifocal split line high enough on lens so I don't have to tilt head up when looking at digital mirror. This is challenging.... I'm thinking about stick-on diopter lens so I can place split line higher on conventional glasses. Am I the only one having this problem? Has anyone found a better solution?
    Gokhan likes this.
  2. Leadfoot J. McCoalroller
    7,835
    7,301
    Pennsylvania
    2018 Prius c
    common problem with video rearviews.
    The focal distance is just the distance from your eye to the mirror, rather than the distance from the mirror plus the distance from mirror to following object.
    I don't have a video rearview mirror, but I prefer driving with single-vision lenses for a lot of reasons.
  3. sylvaing
    sylvaing Senior Member
    1,200
    506
    Hmm, never thought about that. That would be inconvenient for me. Something to think about when shopping for my next vehicle.
  4. Leadfoot J. McCoalroller
    7,835
    7,301
    Pennsylvania
    2018 Prius c
    It's the sort of thing that might work better if they left the mirror as-is, but instead replaced the rear window with a video display.
    ...don't worry, someone will be selling that before long.
  5. Zeromus
    Zeromus Active Member
    496
    261
    Ottawa Canada
    2024 Prius Prime
    SE
    FWIW I've read a lot about how many people get queasy/sick using digital rear views too. They're not natural and they can be off putting to a lot of people when used regularly. I've tried one once in another car, and I didn't like it. I think there are *some* situations where it could help - certainly. But I'd rather just use a regular mirror even if I had the digital one, I'd turn off the screen function most of the time. I'm pretty sure you can just use it as a regular mirror too right? Personally, if I did have it, I would only use it when stuffing the hatch up to the top since you still keep rear visibility that way.
    And if an always online since the age of 14 millennial nerd doesn't acclimate instantly to yet another screen available to him, then maybe they're just flawed tech. That or they're too far ahead of the curve and only iPad kids are gonna be so used to screens that its a seamless transition for the tech ;D
  6. Winston Smith
    Winston Smith Active Member
    257
    177
    OH
    2024 Prius
    LE AWD-e
    Presbyopia is so common in the historic target population for the Prius, and the distant instrument cluster seems such a smart accommodation for that problem, it seems a pretty serious miscalculation to include a feature that would frustrate everyone over 60.
    I have a plastic ruler that slightly magnifies the image of a page on which it is placed. I've also had a SeeAll rifle sight that uses magnification to fool the eye into focusing at a longer distance. I wonder whether magnification on the mirror itself might be a solution.
    I'd steer clear of magnification high on your glasses, like shooting bifocals. Sacrificing clarity at the same height needed to see other traffic is a rough trade.
  7. Hammersmith
    Hammersmith Senior Member
    1,966
    1,972
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    My solution is to just not use the digital mirror unless the back window is covered in something or I've got cargo in the back blocking it. Just flip the bottom lever to turn it into a regular mirror.
    #7 Hammersmith, Mar 14, 2024
  8. Mendel Leisk
    40,493
    Or did they just put it in the middle for a one-size-fits-all, with left and right side positioned steering wheel?
  9. ChapmanF
    17,197
    The midline placement could be explained that way (though I still think they have different clusters for LHD/RHD cars).
    But the placement as far forward under the windshield as they could get, with the use of mirrors to make the projected image more distant than that, was definitely to address the need for refocusing to check the gauges.
    And finally in the latest generations, they've given it all up for a conventional display in front of the driver's nose. Drivers just always thought it was weird and reviewers never looked up why and explained it.
  10. Mendel Leisk
    40,493
    Yeah a lot of their other models stuck with driver-central instrument clusters. First experienced the central version in an Echo (at car show); not sure if it goes back further than that. Seemed weird.
  11. Winston Smith
    257
    177
    OH
    2024 Prius
    LE AWD-e
    Putting the instrument cluster in the middle might simplify manufacture across markets, but I was referring to the current instrument cluster in front of the driver's position but set farther forward. That seems like an accommodation for those of us who don't see the dash clearly unless we are looking through the bifocal portion of our glasses.
  12. Paul Gregory
    Paul Gregory Senior Member
    1,390
    360
    Alberta
    2024 Prius Prime
    XSE
    I found my best results with regular progressive lenses.
    jdenenberg likes this.
  13. Leadfoot J. McCoalroller
    7,835
    7,301
    Pennsylvania
    2018 Prius c
    ...and considerably cheaper to execute than the reversed display with mirror and associated lenses used in the older ones.
    You can perceive the indicated angle or direction of an old dial speedometer needle even if you can't make out the numbers on the scale. But if you ever learned where important ones like 25, 45, 55 and 75 were then you wouldn't ever need to read that display again. A defocused glance at the needle could still inform you properly.
    Going to a strict digital display takes that away, so I can see why Toyota wanted to make something that suited a further focal field.
  14. Winston Smith
    257
    177
    OH
    2024 Prius
    LE AWD-e
    Thank you, Tideland.
    Indeed. A dial can be sensed with the most brief of glances whereas a digital speedometer needs to be read, a slower process. Digital instruments are a step backward, but we are likely to see them more frequently as the cost of dials remains static and the cost of screens decreases.
    An optimized speedometer is even more important in a CVT where one can't estimate vehicle speed by gear and engine speed. At least Toyota have avoided the greater sin of a buttonless interior like the one in the VW GTI.
  15. Trollbait
    12,320
    It isn't just for those of us with older eyes. It lets younger ones refocus faster on the dash, which leads to less time off the road.
  16. Winston Smith
    257
    177
    OH
    2024 Prius
    LE AWD-e
    I've read that before, but I don't understand why it would be so. I would imagine that any light source that could be projected directly at a driver could be bounced off a windscreen. Is managing the contrast against ambient light the problem? Do people with an astigmatism react poorly to them?
    I can see the small driver centered current instrument screen as being less easily washed out by bright sunlight than a HUD. Maybe even more important where the target are buyers new to the model, a cluster gives a driver an object to look to for information. You can't foist too many differences on people and have them accept it all; most will want a lot of continuity to feel comfortable.
  17. Leadfoot J. McCoalroller
    7,835
    7,301
    Pennsylvania
    2018 Prius c
    I hadn't gone so far as to consider the case of the HUD, I still consider that a niche.
    I was thinking of it in terms of the CCFL displays in the early models which weren't terribly luminous, and thus required a hood for shading to allow readability. The cost isn't just the display itself when it needs an elaborate package to use it in all conditions.
    Later they phased out the CCFLs for backlit LCD displays and in some cases OLED displays, all of which had much greater brightness, and needed less shading. Then the resolution got better so they weren't ugly or distracting even close-up.
    Winston Smith likes this.
  18. Winston Smith
    257
    177
    OH
    2024 Prius
    LE AWD-e
    Interesting. I didn't know why the current Prius cluster doesn't have a shade.
  19. Gokhan
    Gokhan Senior Member
    5,651
    2,228
    Paramount CA
    Why don't you turn it off?
  20. Approximate Pseudonym
    106
    55
    Colorado
    2024 Prius Prime
    XSE Premium
    Although I haven’t tested recently, I have excellent vision. I find the digital rear view camera jarring and disorienting when I first switch it on. My eyes expect to focus into the middle distance, like when I am looking out of the windshield or looking into any of the other physical mirrors.
    Once I leave it on for a while, it becomes more comfortable to use, since my eyes can easily focus that close. I am finding I only use it in poor weather so far, and would also use it if the rear view is blocked.
    Another minor problem I have with the digital mirror is that I can’t easily judge distances to cars, and I don’t think changing the zoom setting would help since it’s different from what I would expect. Maybe I will adjust, but it’s possible it will always feel wrong. The placement of the camera and angle of view are not ideal for visualizing exactly where cars are behind me. But it works adequately for its purpose, and actually shows a lot more of what’s behind me than the physical mirror.
    It’s a pretty nice design but I prefer the physical rear view mirror when I can use it.
