Cracked Trunk Trim Piece - Not Warranty Covered?
Discussion in 'Gen 5 Prius Main Forum' started by Poseidon, Dec 5, 2023.
  1. BiomedO1
    3,418
    1,780
    SacTown, Ca
    What happened to 3 year 36K mile bumper to bumper warranty? Dealership claiming it's abuse or intentional damage? Lodge complaint with Toyota America corporate.
  2. Poseidon
    Poseidon New Member
    United States
    2023 Prius
    I missed their call on a Saturday while I was out, so I will be trying to get ahold of them ASAP to go over this. They haven't accused me of intentional damage yet, but "outside influence" seems to be their softer way of suggesting that. I'm going to try to make a case to the dealer's Customer Relations Manager, and to show her all the pictures/cases of this happening so far.
    What did your dealer say, and is there a service bulletin? Is there some documentation (anonymized or anything is fine too) that you can send my way? Trying to wrangle my dealer here but it doesn't seem they are aware of any program for this.
    Update: Called the Customer Relations Manager, she was surprised a "task case" for repair wasn't submitted to Toyota for this issue when I came the last two times for service. I'll be going in so that the dealer can take pictures of my car, so fingers cross Toyota Corporate approves my repair lol
    #62 Poseidon, Mar 11, 2024
  3. Downrange
    Downrange Active Member
    372
    209
    2024 Prius Prime
    SE
    Add our XLE AWD to the afflicted! Taking it up with dealer.
  4. Downrange
    372
    209
    2024 Prius Prime
    SE
    Wife took our XLE in today and dealer service refused to repair under warranty. If anyone has gotten Toyota to cover please contact me. We may need to organize here.
  5. Gokhan
    Gokhan Senior Member
    6,079
    2,409
    Paramount CA
    Do you know how it happened?
  6. Downrange
    372
    209
    2024 Prius Prime
    SE
    No idea. But she's very gentle with car doors and hatches.
    #66 Downrange, Mar 20, 2024
    Gokhan likes this.
  7. Gokhan
    6,079
    2,409
    Paramount CA
    From the looks of it, she took the car to a cross-country rally. ;)
    Downrange and sylvaing like this.
  8. Downrange
    372
    209
    2024 Prius Prime
    SE
    Maritime winters are haaarrddd....
    Gokhan likes this.
  9. Zeromus
    Zeromus Active Member
    546
    306
    Ottawa Canada
    2024 Prius Prime
    SE
    The whole part flexes. It's empty back there so cold temperatures, brittle plastic moment, and the wrong pressure in the wrong spot or a bad vibration....
    Maybe it's fine most of the time, but any issue with the plastic from manufacturing or imperfection that's possibly bad.
  10. Blackat
    Blackat Active Member
    447
    309
    Colorado
    2023 Prius
    Limited AWD-e
    Glad I have the auto open/close....
    Sucks this happens
  11. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Just noticed there doesn't seem to be a Toyota Emblem embedded in the trim piece like on mine. Do Canadian models have different trunk trims?
  12. purplePriii
    purplePriii Active Member
    275
    122
    The logo is above the brake light which isn't pictured. CAD and US models are the same except for some mild options in the trim levels like heated seats and the likes.
    HacksawMark likes this.
  13. Zeromus
    546
    306
    Ottawa Canada
    2024 Prius Prime
    SE
    Ultimately, if there is a flaw in the design/structure/manufacture, Toyota will address it. They tend to be very good about flaws that show up in production over time. It will be up to the owners to know though, either through looking it up or seeing a notification in the Toyota app, or their dealership telling them if a fix does show up beyond "replace", since this doesn't seem to be a safety issue. If it were a safety issue it would be under a recall.
    Heck it might even fall into an extended warranty situation like they have for things like oil consumption on 2AZ engines in the past. For an extended time people could take their affected VIN to the dealership, and they'd do an engine component replacement on piston rings or whatever it was, plus new head gasket for free for excessive oil consumption due to a less than ideal part in the original manufacturing run.
    The issue is going to be how dealerships handle this before any sort of TSB is released. But even then, in the past they'd reimburse folks for the work assuming it had been done at the dealership, paid for, receipts etc.
  14. Mendel Leisk
    41,205
    Maybe they’ve lowered the bar of late…
    don’t get me started, about examples.
  15. purplePriii
    275
    122
    Toyota Canada seems pretty pitiful and more out to actively screw their client base so I doubt about them doing the right thing. It took them being dragged to court to fix the Rav 4 hybrid cable for the back which was costing people 7k or so.
    Downrange and Zeromus like this.
  16. Downrange
    372
    209
    2024 Prius Prime
    SE
    Dealer refused to cover our crack under warranty. Surprise, not.
    Gokhan likes this.
  17. Gokhan
    6,079
    2,409
    Paramount CA
    Ah, perhaps you should have washed the car before taking it there. They might have suspected abuse and neglect.
  18. Downrange
    372
    209
    2024 Prius Prime
    SE
    We did! All that got deposited on the short drive to the dealer! :LOL:
    Gokhan likes this.
  19. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    After taking a closer look with my readers, it looks like contact damage. Depending on what your deductible is, may be insurance will cover it?
    Downrange likes this.
  20. Zeromus
    546
    306
    Ottawa Canada
    2024 Prius Prime
    SE
    The whole piece has a lot of flex to it. If anyone is brave enough you can give it a light squeeze and you'll find there's a lot of play/flex since its empty in behind there. At least, on my prime SE anyway.
    I've seen enough posts about this online to think that it may well crop up as a problem in the future for more people as the plastic ages and becomes more brittle and sensitive. Especially in colder climates where its easy for plastic trim to get brittle when its cold. One bad pressure point with your hands could crack it pretty easily in -30C for example.
