ABS Booster, accumulator, stroke simulator trouble
Discussion in 'Gen 3 Prius Technical Discussion' started by DentedKnight, Feb 12, 2024.
  1. DentedKnight
    DentedKnight New Member
    US NC
    I replaced the brake accumulator and I'm going through the Brake Bleed portion of the repair. I have an Autel MaxiCOM MK808BT Service Tablet. The problem I'm running into is what I believe is too much pressure on the Stroke simulator as it is reading .82 without any pressure applied to the brake pedal. The prius is reading this as constant brake pressure (rear tail lights on and when trying to go to IG-ON no ready, it starts the car as if I'm pressing the brake).
    What is the default standard V reading for the stroke simulator?
  2. Seymour1
    Seymour1 Member
    249
    29
    Did you replace the master cylinder? (Usually they recommend replacing both parts.) If so, check the adjustment of the rod that attaches to the brake petal.
  3. DentedKnight
    US NC
    The brake booster and cylinder was not replaced, the main issue is something is causing the brakes to stay on constantly. I know they recommend the booster too at the same time for internal leaks but, this seems to be a different animal. I appreciate the suggestion though. After I replaced the pump/accumulator the errors went away. I only got the issue when trying to complete the brake bleed process.
