all warning lights on then off
Discussion in 'Gen 3 Prius Main Forum' started by jmann, Mar 25, 2024.
  1. jmann
    jmann Member
    201
    30
    Cleveland, OH
    Can someone suggest or point me to other discussions about the likely cause.
    All the warning lights turn on. I drive for a while. Then they turn off. I drive for a while, and the cycle repeats.
    Traction control, parking brake, ABS, circle with exclamation mark
    The TPMS sensor alarm was already on and headlight high beams were also already on in the picture)
    Note, the 12v accessory battery is bad and needs to be replaced. May be related, but probably not while the inverter is on.
    2012 Prius base model
  2. ASRDogman
    ASRDogman Senior Member
    7,542
    3,895
    Replace the 12v battery. Charge it for 4-8 hours so it have a full charge on it.
    The dealerships and auto parts stores do not keep the batteries charged up.
    A bad 12v battery caused all kinds of errors as the inverter tries to charge the 12v battery.
  3. Brian1954
    Brian1954 Senior Member
    2,144
    831
    South Central PA, USA
    Read the trouble codes with a Prius capable scanner when the warning lights are on. Then you will know what the problem is that the car is trying to tell you about.
  4. jmann
    jmann Member
    201
    30
    Cleveland, OH
    Did this at an auto store. No error codes in code history at all.
  5. ChapmanF
    18,073
    Read the codes while the warning lights are on. If you do not have a scan tool handy then, read the codes this way:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    That also works for those times when the only scan tool you have access to is one that tells you there aren't any codes.
    This method will not show codes that are only in history (need a working scan tool for that), but only codes that are current.
  6. Mendel Leisk
    41,327
    Do this first.
  7. jmann
    jmann Member
    201
    30
    Cleveland, OH
    Of course. Ordered one Walmart delivered same day but with the new stupid problem of Battery terminals wrong size (no screw terminals, etc. either). Anyway. I found that the battery in there was 10.5 years old! I will get a new one at Costco and report back.
  8. Brian1954
    2,144
    831
    Which Walmart battery did you order? Walmart does have one with the correct terminals for a Gen 3. Did you order the wrong one?
