Prius died after I parked. Intermittent power. Able to start after 3 hours.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Charlie Marley, Apr 6, 2024.
  1. Charlie Marley
    Charlie Marley New Member
    Good evening. I have a Prius 2011 - Four Model. After driving the car normally, I pulled into a parking spot and turned off the engine. When I tried locking the car, it wouldn't lock. I went back inside the car and tried to turn it on. The car did not turn on. However, my inside lights were on, but very dim. I tried starting the car multiple times until all power was lost. Nothing was on the car except fo rthe Check Engine light dimly lit and faintly blinking.
    I used a 12V battery jump starter kit to jump start the battery via the fuse block in the engine compartment. It did not work. I called a friend and was willing to wait for him to jump start the vehicle. During the wait, I attempted to turn the power on. Nothing worked, but some of the indicator lights turned on at times. For example, the Power light was showing red. Then, it would turn off. But when I try to push the button again, no lights. At one point, the car was so dead that I was unable to use the power locks. I had to step outside and had to lock the car using the manual key.
    At around the 1 hour mark, while sitting in the car. I hear the CD player churning. The car turns on by itself and all the dashboard lights are showing. The head unit display was showing a progress bar. It said something like Sytem Powering on.. I didn't do anything. It just did it by itself. The interior lights came on again and it was will lit and not dim. However, when I tried turning on the car, the power died again. Similar situation. Nothing turned on.
    At around the 2 hour mark, a similar event occurred. This time it looked like the car was working normally. However, when I turned on the engine. It would not turn. Fortunately, the dashboard lights were still on as well as the interior lights. I left it alone.
    At close to the 3 hour mark, the dashboard lights were still on. I decided to turn on the engine again. This time it worked. I was albe to drive the car home. Here I am sharing my story and trying to find out what happened and address the issue before it comes back.
  2. Tombukt2
    13,259
    2,394
    First of all you're treating the car like a Chevrolet truck It doesn't have a starter there's no key there's no cranking to turn the car on You push a button It's quite a bit different All the dimming lights and business going on is a definite clue as others will chime in shortly You want to find out why lights are going dim Do you have bad connections is the 12 volt years old in the 12 volt space where that battery goes Is it full of water take a look with your eyes If so there's a place to start usually most things involving Prius acting not correctly involve power as an electrical power like the 12 volt switches and buttons and computers do not like inconsistent voltage they will dim click rattle all of that sort of thing so you might want to check there All these behaviors are you're observing are actually quite normal for failing or not proper voltage getting to systems so you may want to start with the very basics like the 12 volt battery and that sort of thing once that situated lights generally don't go dim and things like that until the thing has been sitting there on unattended and not running and the 12 volt starts to lose power that should take at least an hour just sitting there not starting not running nothing.
  3. Mendel Leisk
    41,804
    Start by checking 12 volt battery voltage. How old’s the battery?
    Brian1954 likes this.
  4. Charlie Marley
    I bought the car used. I suspect the battery is still the original. I'm going to remove it and take it to AutoZone for testing. I did the self service check last night. The battery voltage was showing 11.5V without turning on the engine.
  5. Charlie Marley
    I drive the car daily. I just took it for service last week. No issues. It was only yesterday that I first encountered it. So I didn't notice any symptoms to begin with.
  6. Mendel Leisk
    41,804
    Checked with the car completely off, with a volt meter. That’s not good.
  7. Charlie Marley
    Attached is the battery that I pulled out of the Prius. I took it to Autozone. They said the battery was bad. So I bought this:
    Duralast Platinum AGM
    Battery Technology Absorbed Glass Mat (AGM)
    Amp Hour 41Ah
    Height 8.94in
    BCI Group Size 51
    Reserve Capacity 45min
    I took me a while to install because I closed the trunk after I took out the original battery. Since I was unable to open it, I had to reconfigure the backseat area and installed the battery from the inside. So far so good. Everything seems to be working.
  8. ASRDogman
    ASRDogman Senior Member
    7,747
    3,964
    It's likely the 12v battery is dieing....
    if it's a Toyota battery, you should be able to see the battery date on it.
    It's unlikely it's the original battery, seeing the car is 12 years old.
    If you have a battery charger of 4.5 amps or less, attach it to the battery and let it charge
    for at least 8 hours. Wait about 30 minutes and check the voltage. If it's still at the 11 volts,
    it's dead. Purchace a new Toyota battery, then charge for 8 hours, before installing it.
    No store or dealership will charge the batteries, they just sell them.
  9. Tombukt2
    13,259
    2,394
    You really need 12 volts on a 12 volt battery 11.8 on down or under 12. Is not a good sign of any of it now when you boot the car up and the charging circuit starts and you measure like 13.6 to 14.5 you know it's getting voltage from the inverter but I guess it can't keep that charge because after you turn it off for a while it goes down to this 11 business and that's below 12 volts that makes it not good.
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    OP post #7 with attached battery picture shows a label upper left corner with the manufacturer date 12/18. This little 12V battery, even though AGM, usually only lasts 4-6 years. If you have a charger conditioner, like this one, you may extend that to as much as 6-8 years. Also in post #7, your owner's manual has information on how to open the back hatch when the 12V is dead. There is a little square pop-off cover on the inside bottom center of the hatch door. Remove that and there is a looped cable that you pull to release the lock. Much easier than maneuvering over the back seat with that heavy little battery.
  11. ASRDogman
    7,747
    3,964
    Had you taken it to Toyota, you would have gotten a discount because it is
    still under warranty.
    If you had used a 12v battery attached to the connector in the fuse box under the hood,
    you would have been able to unlock the car and open the trunk.... (y):whistle:
    Autozone doesn't know how to check the battery for the Prius.
    Did you charge the battery? That would be a very good thing to do.
    The inverter charges very slowly and you'll have to drive the car for 2-3 hours straight for
    it to be fully charged. Driving for 20-30 minutes is barely enough to keep it charged.
    I'm glad you got it going and it was simple.
  12. Mendel Leisk
    41,804
    I don't see why that would be.
