Rear Seat Fan Running Frequently
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rachel Lynn, Apr 23, 2024.
  1. Rachel Lynn
    Rachel Lynn Junior Member
    Nebraska
    2012 Toyota Prius - 94k
    The rear seat fan has been running a fair amount recently. I live in a 4 season climate so it has not been hot here recently 50s/60s mainly. I did have to replace the 12V battery last week as it wasn’t holding a proper charge and the car wasn’t starting every time. The 12V was installed back in 2016/2017 and had a 84 month warranty so it did its time. No starting issues since replacing the 12V, but I noticed the fan is still running frequently. Should I be concerned?
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,230
    824
    Monument, Colorado USA
    No, it's a good thing...cools your hybrid (traction) battery located under the rear seat!
    Be sure to service that little air filter that's there, too...and while you have the door open shine a light and inspect the round fan, make sure it's not clogged up. (I have dogs so I check the fan and filter often.)
    Rachel Lynn likes this.
  3. Mr. F
    Mr. F Active Member
    388
    256
    Washington
    The fan that draws in air from the vents near the rear passenger seat uses that air to cool the high voltage traction battery, not the smaller 12 volt battery. If you're hearing the fan running loud or often, it would simply be because the car has judged that the traction battery is too warm and needs to cool off, so it draws in cabin air and passes it through the battery pack. Hot weather could be one cause (I probably wouldn't judge 50-60 °F as hot, but 50-60 °C I would). Spirited driving could be another.
    I wouldn't worry about it too much, but it might help be worth your while to ensure that the vent (and the duct behind it) is free and relatively clear of debris.
    Rachel Lynn and ColoradoBoo like this.
  4. PriusCamper
    PriusCamper Senior Member
    12,685
    5,120
    Pacific Northwest, USA
    It doesn't have anything to do with the 12 volt.
    Your hybrid / high voltage battery might be running hot, which means you have a cell in the pack that is going to fail soon... To confirm buy one of these: Panlong OBD2 Scanner Bluetooth OBDII Diagnostic Tool Car Code Reader Turn Off... | eBay and use Dr. Prius app on your phone to monitor hybrid battery temperatures.
    Also, if you let us know what region in the US you live, someone on here might live close enough to you to help you save a ton of money!
  5. Rachel Lynn
    Nebraska
    Good to know, I don’t know if that air filter has ever been change? Also I’ll check out the fan, as same thing I’m guessing.
  6. bisco
    51,840
    definitely clean the fan
  7. Rachel Lynn
    Nebraska
    Any good videos on the easiest way to go about this?
  8. Rachel Lynn
    Nebraska
    I will buy one! Really hoping it’s not that, as I’m 36 weeks pregnant with my second kid, last thing I need is a bum hybrid battery, woof. I appreciate that, I’m in Nebraska.
  9. PriusCamper
    12,685
    5,120
    This is the best person we have for you in your region... He's a mobile mechanic based in Oklahoma and is a fast reply when it comes to helping people via messaging: Drew Griffin (skimmilkhybrid) • Instagram photos and videos
  10. bisco
    51,840
  11. Mendel Leisk
    41,315
    Another, video #21 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    comments on the video:
    1. I found it not necessary to pull out the rear seat, per the video: there’s one (12 mm socket size) bolt, just below fan intake grill, that you need to remove. Just push apart the seat bottom and back and it’s reachable.
    2. Forget if they do this, but anyway: fan can be cleaned without complete removal; q-tips work good for getting in between its fins.
  12. Rachel Lynn
    Nebraska
    Finally bought one of these, but it only wo
    Finally bought one of these, it’s only compatible with my husbands phone so I just went around the block… will that tell me very much or do I need to record in the Dr Prius app while driving
    Around longer distances? Can I tell battery health from just plugging it in?
  13. PriusCamper
    12,685
    5,120
    Periodically check "voltage difference" in Dr. Prius app... The higher that number gets the closer to a problem you'll get with battery pack.
  14. Rachel Lynn
    Nebraska
    Okay! I snagged these two screenshots back to back, so probably not good data, but is .04 and .06 low?
  15. PriusCamper
    12,685
    5,120
    Yes, very low... Like brand new pack low. But that changes under higher amps. For best results, your "Volt diff" will be stressed the most during high amp loads. So Try to grab your screenshot during hard acceleration or hard braking.
  16. Rachel Lynn
    Nebraska
    Will do thank you!
  17. Rachel Lynn
    Nebraska
    So here’s a few more pictures of accelerating and hard breaking if you don’t mind interpreting it?
  18. PriusCamper
    12,685
    5,120
    "Voltage diff" numbers are super low, like good as new kind of low...
  19. Brian1954
    Brian1954 Senior Member
    2,138
    828
    South Central PA, USA
    The three pictures of the Dr Prius app do not seem right. The 12v battery votage is showing a negative valve, and only 10 battery blocks are being shown. There should be 14 battery blocks.
  20. Rachel Lynn
    Nebraska
    Well hopefully I’m doing everything right then! The fan has still been running; but I haven’t had a chance to clean it or replace the filter.
