sudden head gasket failure - or something else?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Michael Evans, Mar 2, 2024.
  1. Tombukt2
    12,950
    2,324
    I don't have the $300 or $250 manual set that may be next but then again maybe not who knows The section I read from the manual was what somebody else here copy down about the 5 hours after shut down and so on My pumps running just great It does exactly all of this but the car gets a code so I'm thinking it may be the temp sensor it's after 5 hours it turns on for a second to do exactly what does anybody know? My guess is to sample the temperature of the water that's in the CHS tank why 5 hours I don't know.
  2. Tombukt2
    12,950
    2,324
    Well they'll be plenty of reading going on very shortly. A young lady about 3,500 mi away from me heard through the grapevine from other sites that I needed the three manual set for the '09 Toyota Prius and all its supplements she will be sending them to me free of charge needless to say I will be giving her a generous tip and a good thank you so I will have the hard copy in my hand soon I hope so I can read and not have to worry about finding crap behind paywalls to think the 2009 manual in 2023 or 4 is behind the paywall still holy Jesus.
  3. Michael Evans
    Michael Evans New Member
    Takoma Park MD
    Just an update. Drove the car about 430 miles, mainly on electric, but gas engine coming on sometimes. Avoided any trips > 10 miles, but the engine did have some cold starts and warm up without any trouble or codes. This past Thursday, after 430 miles (maybe: ~200 with engine coming on?) drove to airport (30 miles), parked, returned Monday. Turned car on: check engine light. The error code that sticks is: P1151. Coolant level appeared normal. Oil looked normal. Drove car home gently 30 mi, but: up to 50-55mph. Engine sounded normal and warmed as normal to about 190F. Lots of other ephemeral error codes: B0613, B0608, B0600, B06A3, B3186, C3786, C2AB1, E3800, P1186, C1D86, C2286, CX2086, B065E, C2D86, B066D, C2A86, U1786, P0003, C2300, P0043, others going by very quickly. P1151 sticks. I think I hear the heat storage pump coming on startup and at shutdown: whirrrr. Checked next day: engine sounds normal. Oil looks normal, not milky. Engine shuts off at temperature abut 100F. Lots of codes even when engine shuts off while car is on (in driveway).
    Car is with mechanic again today. So question is: is there anything else to check before replacing the coolant heat storage tank? (This was a solution posted in another thread here, entitled "SOLVED P1151 Coolant Heat Storage Tank") I still can't see any damage or leakage from it, but I can't see the whole thing. Thanks in advance for any suggestions!
  4. Tombukt2
    12,950
    2,324
    5 hours after you park that generation 2 from a full warm up run that coolant heat storage tank pump should come on take a sample of water and shut off Is that happening only you will be able to tell so at 4 hours and 45 minutes after a shutdown walk out to the car sit on a milk crate next to where the fender liners removed and the heat storage tank is If you need to put your hand on the pump and verify that right at 5 hours the pump comes on? If that doesn't happen that's a clue The temp sensor that screwed into the side of the undamaged unmolested heat storage tank does it meet spec It's a pretty standard temperature sensor for Denso. Other than that there's nothing that really can happen to the coolant heat storage tank itself unless it's been pummeled in an accident there's nothing in it to just go bad so I have a car with this issue right now I'm thinking it's the pump I have not been able to go out and verify it that the fifth hour like I need to someone else drives the car it drives perfectly she just clears the code and moves on In the summer time this doesn't happen this is mostly a winter problem. I need to check the temp sensor also to make sure it's within the spec but if those two things are fine then I would think the computer that's controlling the pump maybe the issue but I'm thinking in my personal car that the other half is driving I'm thinking it's the pump itself I have two or three at the ready so I need to get out there and check it at the fifth hour see if it comes on in the morning when we start the car etc No one has done anything with it the car drives perfectly gets 48 mi to the gallon and win this CHS code pops up she has Bluetooth code clearing always on and she just clears it and keeps driving everything else with the car is spot on The only thing on on the dash is the tire light haven't had to change the tires yet to put the new sensors on this is the car we bought for $800 with brand new tires on it General something another the tires that is.
    Michael Evans likes this.
  5. Danno5060
    Danno5060 Active Member
    386
    198
    Wyoming
    I'm confused. The original post talked about coolant in the engine oil, yet somehow the thread is now talking about the inverter coolant system.
    Nobody has talked about the engine coolant pump, nor the tiny belt running the engine coolant pump. How did coolant get into the engine? Did someone cross-connect a coolant line to a crankcase ventilation line? Did someone try to add coolant in the wrong place, or take the thing canoeing through a puddle?
    #25 Danno5060, Apr 24, 2024
  6. dolj
    dolj Senior Member
    8,439
    4,288
    Wellington, New Zealand
    What code scanner gave you those codes? Most of them are not valid Gen 2 codes.
  7. Michael Evans
    Takoma Park MD
    @ Timbukt2, we are sending you an emergency shipment of punctuation :) I haven't tried the 5hr test - but if the car comes back from the mechanic, I can do this. Certainly my experience is similar in that I cleared this code back in May 2022, and it only came back in Feb 2024.
    Danno5060 likes this.
  8. Michael Evans
    Takoma Park MD
    @dolj, It's a Scanguage II from late 2014, set to read Prius codes. I wonder if that setting got lost somehow.
  9. Michael Evans
    Takoma Park MD
    @Danno5060 Hehe... I don't know how coolant got into the engine. What happened was: (1) I brought car to mechanic for regular oil change with check engine light on and the mechanic said the oil was full of coolant, must have been recently; suspected head gasket failure; (2) 3 more oil changes later, it wasn't. (3) 430 miles later, check engine light came on and the key error code seems to be: P1151. Oil color and level normal, coolant level normal. Mechanic claims its impossible that they put coolant in the oil port. Also says impossible that hoses are misconnected.
  10. Michael Evans
    Takoma Park MD
    Sorry for all the messages, but my mechanic says they think the heat storage tank is failing. An expensive replacement. They suggested checking that the software update related to this system was applied (I think it was. I will check records later today, or else check with Toyota by VIN records to confirm that.) Otherwise they say the car is driveable, but the cabin heat won't be so great. I am guessing emissions may be higher. My daughter was complaining that the heat wasn't working so well on some cold days in January - I wonder if this is indeed the source of the problem. But the check engine light was not on until February 2024. Last Thursday when I started the car, the ambient T was about 70F, car sitting in sun. I think the scangauge said that the engine T before engine kicked on was about 67F.
    Does any of that suggest anything else worth checking and/or replacing besides the tank itself?
  11. rjparker
    10,135
    6,298
    I agree. Holes in the block or hg that might connect a coolant passage to oil don’t just fix themselves. Either there never was coolant in the oil or somebody put it there and will never admit it. Maybe the op has an ex who doesn’t like him.
    On the other hand P1151 and other codes should be easy enough to fix with the repair manual sections.
    PDF
    #31 rjparker, Apr 24, 2024
    Michael Evans and Danno5060 like this.
  12. Michael Evans
    Takoma Park MD
    @rjparker, no angry ex :) Thank you for the tech documents!
    So it looks like possibilities could be: (1) CHS Tank is not holding heat as it should: bad insulation. (2) failed/ing Water Valve. (3) failed/ing Water Pump for Air Conditioner. (4) failed/failing CHS Water Pump. (5) failed/ing ECM. (6) failed/ing CHS Tank Outlet T Sensor. (7) blocked hose or conduit between any of the above. (8) some combination of the above.
    Have I missed anything possibly wrong?
    Can I rule out (2) and (7) because engine is warming up but not overheating, and there's no coolant loss?
    Can I rule out (4) and (5) and (6) because I can hear the CHS Water Pump operating (healthy-sounding whirr) on pressing brake at startup and at shutdown? And by trying @timbukt2's 5h listening test? For (5), if there's electronics involved, this is probably either good or bad, no in-between? Is there a straightforward way to test (6) I can actually reach and/or meter?
    For (1) I suppose I can try running the heater when the engine is cold, but after it has recently been hot? If the CHS Tank is not insulating, then there won't be any heat because the coolant in the tank got cold.
    Thank you again!
  13. Tombukt2
    12,950
    2,324
    It seems to me I don't have all the literature to read just yet It's on the way. At 5 hours after shutdown the computer calls up the pump samples what's in the CH tank and if I guess it doesn't like what it sees when you come out and start the car whenever that is it sets the code because it didn't like the temperature of the water it's all for whatever reason that I can't answer but I can tell you that I have plenty of heat storage tanks sitting right here I'm staring at three of them I see no way without it getting smacked in an accident that the coolant heat storage tank would just be void internally that would be like my metal water storage tank for my well which does not have a bladder in it All of a sudden be not holding water and no way to tell where it went highly unlikely you'll be able to stand in front of that tank and find a hole or something it'll have to be on the ground whatever was in the tank same here if you get a chance to see a tank out of the car you will see what I'm talking about You can blow in and out of the passages through the tank very boring stuff but that's that The tank is double walled I think it is kind of like a yeti cup little thicker wall probably but that's about it so between the temp sensor and the pump and the computer sampling something that it thinks it doesn't want to be seeing whether that temperature is too low or too high or I have no idea.
  14. rjparker
    10,135
    6,298
    The way I read the docs you have a bad storage tank unable to hold hot water for a length of time or there is an air lock caused by changing the coolant wrong. I suspect the air would be pushed through given a few cycles so that is less likely.
    I think Toyota has enough tests to code on the other parts of the system. I would probably buy a used tank if they are expensive.
  15. mr_guy_mann
    mr_guy_mann Senior Member
    4,045
    1,969
    NJ-USA
    I would use a capable scantool and see what the system does during a cold startup. Normally the ECM adjusts the 3-way coolant valve and runs the CHS pump for several seconds before starting the ICE.
    The CHS and ECT temperature sensors should go pretty high.
    Here's a graph of some data. Cold start on a 40° F morning. I turn the car to "ignition on" (not ready). I turn off the HVAC - climate system. Then connect the scantool and select ECM data for RPM, CHS temp, ECT, (and coolant valve position). THEN go ready and watch / record the data.
    I have fixed various problems with the CHS system, (CHS Temp sensor - wiring, incorrect hose routing, CHS pump - relay, 3-way valve) etc, but have never seen a bad tank. IMG_20221118_192203682.jpeg
  16. Michael Evans
    Takoma Park MD
    Thank you @rjparker and @mr_guy_mann ! I have a Panlong ELM 327 compliant OBD2/bluetooth scanner, and I can get the Car Scanner app, and try this test. I do see Ebay has lots of used CHS Tanks for sale for about $150. The bug is going to be the labor - sounds like it is a lot of labor. Mechanic estimate is: $2900 parts and labor. I don't think I am capable/have the tools. I'd ask my mechanic to install it but they are (reasonably) wary of customer-supplied parts and charge an hourly surplus to install them. I'd ask them to buy a used one from ebay and install it, but they are reasonably wary of that, too.
  17. mr_guy_mann
    4,045
    1,969
    NJ-USA
    You can try your adapter with CarScanner and see what the ECT (engine coolant temperature) does. You want to listen carefully for the CHS pump to run for 5 seconds or so before the ICE starts.
    All of the "free" scantool apps I have looked at do not have Prius specific engine data. So there will not be CHS temperature (water outlet in my previous capture), or coolant valve position.
    Here's a thread that reviews several apps and devices, including some that can scan all systems on a Gen 2 with codes and complete data.
    I would confirm that everything else works correctly (CHS pump, CHS temp sensor, coolant 3-way control valve, and proper hose routing) before thinking about the CHS tank.
    That said, it might take an hour or two to replace that tank.
    https://priuschat.com/index.php?posts/3290690
  18. Tombukt2
    12,950
    2,324
    CHS tank Will be a pretty easy job one of the easier jobs if you do a lot of work on your Prius break a couple of clips pull the fender line or back and do a couple of tens that hold the brackets in and the whole mess just falls on the floor Make sure you've unplugged your pump and your temp sensor so you don't jerk on the plugs and you're out of there going back in is just about as easy. If you're already missing your fender liner you're 10 minutes into the game or better so far I've replaced no tanks and I have about four of them sitting here unless they're wrecked visibly dented and damaged and they pretty much work It's a big yeti cup.
  19. rjparker
    10,135
    6,298
    Tomorrow I should have access to a gen2 and will try to scan the chs system with Car Scanner. I know gen3 hybrid points are well represented in that app. Techstream is the gold standard and allows control of most actuators, pumps and the like so is the go to for most of us when things get serious. The app is great for a quick look anywhere by grabbing the $30 Bluetooth out of the glove box and connecting the phone. Techstream is more of a pain requiring a PC and hardwired adapter.
    Because of the previous wreck and repairs there could be intermittent comm bus or wiring issues.
    The fact you get multiple codes including P0003 and P1115 is concerning. Plus your codes can go months or years before returning.
    I agree it would be better to see the coolant temp coming out of the tank after a cold start.
    #39 rjparker, Apr 25, 2024
  20. rjparker
    10,135
    6,298
    I checked a gen2 today with Car Scanner and found no points for the CHS system. One thing that is easy to notice is the pump runs immediately after shutting down with a warmed up engine.
    Attached are the PIDs Car Scanner has on a gen2. They include most hybrid data.
