2023 Prime lowering choices.
Discussion in 'Gen 5 Prius Accessories and Modifications' started by PriusPrimetime, May 1, 2024.
  1. PriusPrimetime
    71
    59
    FL
    2023 Prius Prime
    XSE
    I'v put about 10k miles on my 2023 Prime and have decided it needs to be lowered a little bit. Every car I've ever driven has had springs installed, Eibach/Dinan or similar.
    Need advice on which springs. Not interested in coilovers.
    Do people typically go RSR? Having hard time finding other options.
  2. PhoS
    PhoS Active Member
    255
    209
    Nowhere
    2023 Prius
    Limited AWD-e
    You're not going to find a lot of info here. The few of us that have done it are all on RSR. I've seen some other manufacturers offering springs like Tein for example but I haven't seen anyone who has them post anything.
  3. RollingPanda
    RollingPanda New Member
    24
    Fort Worth Texas
    2025 Prius
    Limited AWD-e
    How has the ride on rsr lowering springs compared to stock?
  4. PhoS
    PhoS Active Member
    255
    209
    Nowhere
    2023 Prius
    Limited AWD-e
    They feel a little bit more supportive than stock. The ride is sporty but not bouncy or jarring. They're a good match for the car and the stock shocks. For aftermarket I would even say they are softer side compared to most.
  5. RollingPanda
    24
    Fort Worth Texas
    2025 Prius
    Limited AWD-e
    I also seen eibach makes springs for our generation prius. The eibach pro springs also gives about 1 inch drop as well.
    Our prius have been out for a few years now. I would assume there would be more aftermarket product out.
  6. RollingPanda
    24
    Fort Worth Texas
    2025 Prius
    Limited AWD-e
    Dis you reuse your stock strut/dampers with the rsr lowering springs?
  7. PhoS
    PhoS Active Member
    255
    209
    Nowhere
    2023 Prius
    Limited AWD-e
  8. RollingPanda
    24
    Fort Worth Texas
    2025 Prius
    Limited AWD-e
    Ok...I was looking for some aftermarket koni/bilstien/kyb and there weren't any available.
    Was it an easy install?
    #8 RollingPanda, Mar 30, 2025
