What does this mean ?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Taxi/Limo, Feb 29, 2020.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    A fellow taxi driver had this message pop up on his dash
    Maintenance required for hybrid battery cooling parts at your dealer
    2016 150k miles approx
    Thanks
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    My first guess would be a dirty or malfunctioning battery fan.
  3. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    Or just a clogged filter...
    alanclarkeau and jerrymildred like this.
  4. Taxi/Limo
    524
    107
    What filter?
  5. Elektroingenieur
    2,515
    3,282
    Three Touring
    The HV battery uses forced-air cooling, and the air intake, on the front of the right rear seat, has a filter. In the Owner’s Manual (PDF) for model year 2017, see pages 573–574. (The 2016 editions mention the filter but lack the cleaning instructions.)
  6. Mendel Leisk
    41,315
    Probably filter and fan need cleaning. And the ductwork while you're in there.
    Toyota could use a bit more common sense in their warnings. Won't be happening tho.
    jerrymildred likes this.
  7. Elektroingenieur
    2,515
    3,282
    Three Touring
    “At your dealer” was changed to “See owner’s manual” for model years 2017 and later.
    Perhaps the designers didn’t anticipate frequent clogging of the intake with pet hair or other substances that could be removed effectively using a small cordless vacuum cleaner, as opposed to dust or dirt trapped in the filter itself, which requires disassembly to replace.
  8. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    I should probably take a look at mine. Haven't even taken a look at it ever. Anybody know the part number of that filter?
  9. Elektroingenieur
    2,515
    3,282
    Three Touring
    It’s G92DH-47070 for all fourth-generation Prius cars. See my February 2018 posting and this previous thread with pictures.
    (Prius Prime and Prius PHV use two filters, G92DH-47080 and G92DJ-47010.)
    amos, pjksr02 and alanclarkeau like this.
  10. Hilarysh77
    Hilarysh77 Junior Member
    Tennessee
    2016 Prius v wagon
    OK, I keep getting this message.... where is this thing I'm supposed to check out??
  11. Brian1954
    Brian1954 Senior Member
    2,140
    828
    South Central PA, USA
    Read about this message in the 2017 owners manual. See post #5 & 7 above.
  12. Doug McC
    Doug McC Senior Member
    1,079
    416
    Midwest
    2022 Prius
    The Car Care Nut has a YouTube video showing where it is at and how to access and clean it. Do not blow air in the vent, use a vacuum if it really needs cleaning. The little plastic screw is a bit of a pain, but not too bad.
