For Sale 2023+ Prius Air Ride Suspension
Discussion in 'Private Sales' started by Fz6r, May 10, 2024.
  1. Fz6r
    Fz6r Junior Member
    Las Vegas
    2023 Prius
    Used 2023+ Prius Air Ride for sale. $2,800
    - Universal Air Suspension
    - Air Lift management system
    - 4 Gallon Tank
    - 2 Via Air Compressors
    Everything you need to install air ride on the 2023+ Prius. Used for ~ 5k miles.
    IMG_2324.jpeg IMG_2326.jpeg IMG_2327.jpeg IMG_2328.jpeg IMG_2330.jpeg IMG_2331.jpeg
    Will also include trunk foam liner so that you don’t have to cut into your existing foam.
    in Las Vegas. Can ship at buyers expense
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,691
    392
    2013 Prius Plug-in
    whats max height over factory height?
  3. Fz6r
    Fz6r Junior Member
    Las Vegas
    2023 Prius
    Universal Air says 7" of travel. It's definitely able to go quite a bit higher than stock.
    It's $2500 + tax just for the bags, plus another $2k plus tax for the management when buying new. If you are interested in the kit, buying mine will save you over $1k.
  4. black_jmyntrn
    1,691
    392
    2013 Prius Plug-in
    ive been trying to find the total height increase available above stock. once I find that out ill know if I am in or not.
  5. Fz6r
    Fz6r Junior Member
    Las Vegas
    2023 Prius
    You may have to contact them to ask them. I imagine the answer varies depending on what you set the height to when installing. Based on their site, it would be whatever the height you have set as the base height with bags aired out + 7"
  6. Fz6r
    Fz6r Junior Member
    Las Vegas
    2023 Prius
    Willing to separate suspension from
    Management.
    Universal Air front and rear suspension - $1400
    Airlift management and components - $1400
