10 K Service, less than impressed! dealership misery!
Discussion in 'Gen 5 Prius Main Forum' started by samsprius1, Apr 23, 2024.
  1. Gokhan
    Gokhan Senior Member
    5,635
    2,225
    Paramount CA
    Yes, I knew a service advisor who worked at a Toyota dealer near me—one I visited for service once actually—and the commissions he was making was incredible. He made at least $120k a year and didn't even work for 40 hours a week. He later started working for a Honda dealer. Dealers definitely overcharge for services unless it is done through a insurance company, who gets far better pricing.
    Regarding mechanics, that is true naturally. Nevertheless, overall management and mentality at the dealer also makes a big difference. Better management is also likely to hire better mechanics and train and manage them better.
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,131
    737
    Monument, Colorado USA
    I agree but I still go by "trust but verify" Even with an oil change, I'll check the work ASAP.
    My son-in-law used to be an Asst Manager at a big Walmart that had an automotive service department. He told me of numerous incidents where the guys doing oil changes screwed up $40,000 cars by doing stuff like forgetting to replace the oil drain plug or forgetting to put oil in the cars....those engines were toast! Then, a few months later, I asked him if they had any more cars killed and he said, "Nope, the Toyota dealership hired our worst guys!"
    Just something to think about when you drop off that car at Toyota!
    samsprius1 likes this.
  3. Gokhan
    5,635
    2,225
    Paramount CA
    Again, your experience will vary greatly from dealer to dealer, as they are franchises. Some have excellent service; some have bad service. You can't make a blanket statement either way.
    How do you verify an oil change? There are so many things that might have been done wrong or not done at all. The only way to be 100% sure is to do it yourself, but that's a lot of pain for most people: jack up the car, get your hands dirty, likely spills in the garage, recycle the oil, pay even more than at the dealer if you want to use TGMO, etc. Besides, you get free oil changes for the first two years. If I had a hydraulic lift in my garage, maybe, but otherwise, meh. And this is coming from someone who has done hundreds of oil changes in the past.
    #183 Gokhan, May 17, 2024
    GcinFl likes this.
  4. ColoradoBoo
    1,131
    737
    That's true but you can just pull the car over after Toyota gives it to you, turn off the engine and wait a few minutes (5 if you have a turbo), then pop the hood and check the oil level on the dipstick...just make sure it was filled and at the correct level.
    Merkey likes this.
  5. Mendel Leisk
    40,461
    I resolved to DIY future oil changes, while lying under a previous car, holding the backed-out drain bolt just in the hole, trickling out the almost-a-liter overfill. Had to stop because my arms started shaking/cramping.
    Merkey and Gokhan like this.
  6. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    I know I’ve heard this somewhere before, yes I’m going back to my big metropolitan dealer where I purchased cars before and never have had a problem, was challenging buying a car during Covid times as you well know, ended up with a deposit at four different dealers and this one franchise dealer is the one that called with the car that I wanted everything! I thought I would give it a shot with service on my vehicle! sometimes these smaller dealers are the best, I should’ve known the buying experience wasn’t that great! Car was delivered to me with almost 60 pounds of air in the tires I should have known!
  7. Mendel Leisk
    40,461
    That's part of the Pre-Delivery Inspection you paid for. :cautious:
  8. Gokhan
    5,635
    2,225
    Paramount CA
    Didn't you know that this wonderful contraption existed? It is for collecting used-oil analysis (UOA) samples from the dipstick tube, but you can also correct overfills with it.
    Quick-draw pump | Blackstone Laboratories
    #188 Gokhan, May 18, 2024
  9. Mendel Leisk
    40,461
    Phttt, makes it too easy, lol.
    Gokhan likes this.
  10. rjparker
    9,498
    5,815
    This is what I use. It can suck out the whole crankcase fill.
    Works good for lawn mowers as well.
    samsprius1 and Gokhan like this.
  11. soft_r
    soft_r Active Member
    159
    113
    Beverly Hills
    2024 Prius
    Buy Fumoto® Valve Online | Replace Oil Drain Plug
    Had one on my old car, made oil changes easy. Helps if you take the oil cap off before you go to drain. Is slightly slower than removing the bolt. When I start doing my own oil changes to the prius I'll install one again.
  12. NullDev
    NullDev Member
    112
    57
    Ohio
    2024 Prius Prime
    XSE
    I've used one on my last 4 Hondas and they really are handy. I will need to check the spacing around Prius drain bolt to see if it would require the extension fitting or if there is enough clearance for the valve to be attached directly.
  13. samsprius1
    720
    182
    2023 Prius
    Limited AWD-e
    You are so right, night and day! Just had my wife’s 2019 RAV4 hybrid in for a recall the roof rails are leaking on the 2019 and 2020s and Toyota is doing an extended warranty! Which is good for me because I am over 3years 36,000 miles! So I Took it to a another Toyota dealer where I have purchased vehicles before and they have multiple stores in our metropolitan area, What a difference Service advisor had been there for 25 years and he was top notch kept me posted car had to stay overnight, but that was fine. I want the job done right and so did they! So needless to say this where I’ll be taking my Gen5 from now on!
    Gokhan likes this.
  14. samsprius1
    720
    182
    2023 Prius
    Limited AWD-e
    I'm done with this dealership they will never get another penny of my money! I know it's a freee oil change but what else would they let slip by!!! like someone commented not all dealers rate the same!!
    PriusCamper likes this.
  15. JimLudden
    JimLudden Member
    83
    31
    Taos, NM
    2024 Prius Prime
    I had to take my '24 Prime SE to the dealer to program the new key fob. They now claim that they did a vehicle service and some maintenance inspection and secured the floor mats. NOT.
