2016 prius coolant issue
Discussion in 'Gen 4 Prius Main Forum' started by Sharnold, May 20, 2024.
  1. Sharnold
    Sharnold Active Member
    379
    119
    Alabama
    2016 prius 170k miles client says overheated with white smoke coming out of the exhaust.
    Coolant and check engine MIL on dash.
    I scanned the car it had only one main P code P148F.
    After checking the oil ( no coolant mixture ) and the cylinders ( they was dry ).
    Tried using TIS to activate water pump and it would error out and fail.
    I pulled the water pump.
    It would not turn by hand.
    Replaced the water pump and the thermostat and plugs.
    Now there is no codes no rough idle but at 190⁰ the exhaust smokes terribly and there's no heat in the cabin nor does the system build pressure.
    The car runs smooth as silk.
    My ideology is the catalytic converter is busted leaking coolant into the exhaust system.
    Any other ideas would be appreciated.
    FuelMiser likes this.
  2. BiomedO1
    1,426
    779
    SacTown, Ca
    Yes, That would be my guess. Bypass the exhaust gas heat exchanger to see if your coolant levels stabilize. If it does, problem solved. 2016 and early 2017's has been know to have this issue, but at 170K - your probably outside TSB/OEM warranty on this.
  3. Sharnold
    379
    119
    Alabama
    With it still overheating I think it's just dumping into the exhaust and can't circulate the coolant correctly
  4. bisco
    49,328
  5. Sharnold
    379
    119
    Alabama
    Unfortunately after I looped the system off the catalytic converter although it would build pressure and the heater core is circulating now it still overheats and the coolant reservoir tank is bubbling afterwards and the system looses pressure rather quickly so we all know what that means..........
    #5 Sharnold, May 26, 2024
  6. bisco
    49,328
  7. Sharnold
    379
    119
    Alabama
    Yeah my guess is either the water pump failed and found the weakest spot which was the heat exchanger and the engine went low on coolant and overheated.
    The car lost all coolant through the exhaust causing water pump failure and it overheated.
    Either and or there's still no oil water mixture and the coolant will get to 250⁰ withing a 2 mile drive and it's still running smoothly.
    I think exhaust gas is circulating into the coolant system super heating it
  8. jerrymildred
    jerrymildred Senior Member
    11,508
    14,108
    Tampa, FL
    That would be my 1st guess. There are tests for exhaust gas in the coolant.
  9. Sharnold
    379
    119
    Alabama
    Not the head gasket, so let's try to think about this logically. I replaced the water pump, thermostat, bypassed the catalytic converter that was leaking but im still overheating.
    Waterpump is coming on running TIS on active test.
    The cooling fans run fine but do shut off in park.
    I can't see any flow in the coolant reservoir but the lines do build pressure.
    But also loose pressure relatively fast.
    When it's doing properly the lower lines are stiff and hot
    When it's malfunctioning they get stiff but feel cool.
    The upper smaller lines on the radiator, radiator pipe to reservoir get hot everytime.
    Sometimes there's gurgling and flow bubbles coming off the small lines on that side of the reservoir will fill and empty on its own squeezing the larger hoses or by itself running ( the side with the bleeder Allen screw )
    I'm at my witts end.
    Bad new thermostat............ or?
    #9 Sharnold, May 31, 2024
  10. Brian1954
    Brian1954 Active Member
    771
    293
    South Central PA, USA
    Did you buy OEM parts for the water pump and thermostat?
  11. Sharnold
    379
    119
    Alabama
    Pump yes thermostat no
    Pump failure would prompt a TIS fault and not run automatically or on active test.
  12. Sharnold
    379
    119
    Alabama
    Replaced water pump and thermostat one more time still a no go.
    If I run water pump using TIS while driving the car set at 3000 it will stay cool
    If I let it do it's own thing is when it's overheating.
    Also checked and changed relays and fuses
    So I'm still not understanding wth is going on here
  13. Brian1954
    771
    293
    What does Techstream show the pump is running at when the car is overheating. There should be two speeds listed. One for actual pump speed and a second one for requested pump speed.
  14. Sharnold
    379
    119
    Alabama
    It only registers the full 3k when you choose the 3k option
    If you turn off your active test it sits at idle
  15. Brian1954
    771
    293
    Let me explain a little better what I was trying to ask you. You should be able to see live data in Techstream. I have not done it personally, but there should be a live data screen where you can view the actual engine coolant pump speed and also the speed that the ECU is requesting that the pump run at. So you can compare the requested speed versus the actual speed. This is not in the active test screen.
    Sharnold likes this.
  16. Sharnold
    379
    119
    Alabama
    I gotcha now
    I know how to access that easily
  17. rjparker
    7,888
    4,662
    How is exhaust gas still getting into the coolant? Did you bypass the exhaust heat exchanger at the exchanger? If not maybe the bypass is not right.
    Why is the water pump only running good under Techstream control? Bypassed temp sensor? Air is the system at the sensor or sensors?
    #17 rjparker, Jun 4, 2024
    jerrymildred likes this.
  18. Sharnold
    379
    119
    Alabama
    Bypass is correct
    Waterpump is running correctly after running live data.
    Still doing it
    I've done everything to bleed the air out of the system, including unbolting the reservoir and sticking it on top of the block squeezing hoses ETC.
    So am I having an issue with a selector valve malfunctioning, or is one of the temp sensors malfunctioning causing something to go amiss down the line.
    No leaks, no air getting pulled in.
    The heat is not working every time. And that whats throwing me off.
    #18 Sharnold, Jun 4, 2024
  19. rjparker
    7,888
    4,662
    Only overheats in traffic or when driving slow? Do radiator fans come on?
  20. Sharnold
    379
    119
    Alabama
    Fast or slow it overheats even in maintenance mode
    The fans cut on and off in maintenance mode and with driving they are on but in park will shut off
    If I pull from the garage and coolant temp is 165⁰ it'll hit 200⁰ within 2 miles and continue upwards to 230s with normal driving
    And of course the MIL will illuminate at 243⁰
