Where to get a New Gen 4 Panasonic Module snapped battery post Gen 2 Batt rebuild
Discussion in 'Gen 2 Prius Main Forum' started by Gentoo, Jan 12, 2024.
  1. Gentoo
    Gentoo Junior Member
    28
    NY
    Good Evening ~ I snapped a post using a Harbor Freight Torque wrench set to 48 inch lbs what's done is done. From what I understand trying to rebuild the post is a bad idea . Swapped modules from a 35k mile 2020 into my Oldie but goodie? Gen 2
    How would I aquire a module that would best match this rebuilt pack that is entirely harvested from a 2020? I have no conceivable way of "balancing" the pack that's why I opted for a total module replacement from a much newer pack. I am in the NY metro area.
  2. Gentoo
    28
    NY
    @TMR-JWAP are you able to add a new post to a module?
  3. PriusCamper
    PriusCamper Senior Member
    12,685
    5,120
    Pacific Northwest, USA
    Project Lithium modules are designed for ease of repair in mind and it'd be an easy fix. But Toyota modules are the opposite of that.
    Creating further difficulty is used Gen4 modules are hard to find and new ones are only sold as complete packs. Perhaps you can sell your Gen4 modules to a Prius C owner who only requires 20 modules rather than 28 and then you'd be the rarest of rare people who has brand new individual Gen4 modules for sale. I'm sure you could charge alot for them and might even be able to recover all of your costs so you can buy another set of 28 modules for your Gen2.
    Which brings up the question, where have you found brand new Gen4 packs for sale, without having to provide a gen4 core to get your deposit back? I'm sure lots of people would be interested in that option.
  4. Gentoo
    28
    NY
    The salvage yard had a recently wrecked 2020 Prius (Nimh modules) with only 35k miles on the odometer I bought the Traction battery from that wreck and opened that pack to recover the modules pulled 28 modules out and put them in my Gen 2 pack.
    #4 Gentoo, Jan 12, 2024
  5. PriusCamper
    12,685
    5,120
    Oh good, that's way easier to deal with... You just gotta find another deal like that and then post on here to find people with Prius C who will help you finance it.
    PS: your torque settings on your impact driver are messed up.
  6. Tombukt2
    12,901
    2,316
    Yeah on reinstallation on a stud that's already had a bolt on it I'd probably knock five to seven inch pounds off of that number just because and then you don't want anything on the stud or the nut that's going to make those torque specs slip lubricant etc It's tricky business that metal going into plastic. You might talk to any of the good quality battery rebuilders like the hybrid doctor he's online and has a physical place of business up in Fairfax VA people like that My battery guy will have one or two modules ready for me balanced and ready to go He's doing 28 or 36 at a time so I can call him today and go pick one up or three up at lunch time if I want can I guarantee they're from a Gen 4 probably not but what he's going to hand me is already balanced to whatever it is $5,500 milliamps and whatever the voltage you're supposed to be I never have to second-guess this guy If I was to get a bad module from him and all this and that there have leaking HV voltage to the frame or any of that nonsense I usually find the offending module or two call him and meet him somewhere and pick them up He's handed me six modules over the few months I've been messing with this one or two other cars not an issue actually he's done me very well.
  7. Gentoo
    28
    NY
    For completeness sake posting image of the broken post.
  8. Gentoo
    28
    NY
    Ultimately I ordered a module from 2nd Life Batteries.com in Oregon, The Module was at 7.98 Volts discharged it down to 7.5 to match the voltage of the other packs. And hopefully that is the end of the Red Triangle for a long time, thank you all for your help!
  9. Gentoo
    28
    NY
    Well it was a long four months but it seems like the replacement module is no longer playing nice in the box I now have another Red triangle of death with P3000 and P3011 battery block 1 becomes weak. I can only assume that is due to the replacement module not being able to keep up with the rest of the pack. I think the module is from 2017 While the rest of the pack is from 2020. Anyone have ideas of what to do next? I was getting an average of 48 mpg
  10. Brian1954
    Brian1954 Senior Member
    2,138
    828
    South Central PA, USA
    Use the Dr Prius app to take a look at the HV battery block voltages.
  11. Gentoo
    28
    NY
    Uploading voltages it #1 was in the red at one point. Cleared the code 3 times it returned in seconds
  12. Gentoo
    28
    NY
    Thank you I posted the dr. Prius
  13. Brian1954
    2,138
    828
    You need to take screenshots of the Dr Prius with high charging (regenerative braking) and discharging (hard acceleration) amperage when you are driving the car. Then post the screenshots.
    Gentoo likes this.
  14. Tombukt2
    12,901
    2,316
    My battery guy charges me like 550 to swap out a generation two setup It's the best 550 I spend on one of these cars he does great work and all of that anything goes wrong with the battery he'll either come and replace it bring me modules or whatever I want to do so there's always that he's got the equipment to run I think 58 or 60 modules at a time so when you're set up to run like that you know you can make things happen reasonably quick so I think that's the way to go with the refurbed battery business rather than sitting in my basement with hobby chargers and then if I don't do that in the car is worthy of it I buy a real battery from Toyota finding on sale buy it online do all the nonsense and then I know I'm good for close to 10 years if I wreck the car or something happens I make sure I take it with me
    Gentoo likes this.
  15. Gentoo
    28
    NY
    Will do, basically when I rebuilt the pack back in January I snapped the post of one of the modules in Block 1, I ordered a replacement from 2nd life requesting that they were Gen 4 I believe he sells them as the "Lexus GS 450 Cell with a 2017 or 2018 date code" The code seems to coincide with the "replacement" cell I added to the pack. Thank you for your help I will post the shots tomorrow as soon as I can take them
    Brian1954 likes this.
  16. Gentoo
    28
    NY
    Looks like something is up with block one, I'd have to suspect it's the replacement module that is not the same as the rest of the pack. That is surprising considering it's only a year or two older than the rest of the pack and 2nd life has very expensive equipment and ensured that it was at full capacity. Where do I go from here? I don't want to have to continually keep slapping new modules into Block one, how do I dig myself out of this. Secondlife told me to check the busbars (they were cleaned and made shiny) and to check the sensor wire going to ECU but I am consistently getting the error in block one (which I Purposely made block one for easy replacement Incase the replacement module failed. Thank you for your help.
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    One of the two modules in block 1 has failed. 1.0-1.5V drop under load pretty much confirms that. Could be the replacement, or not.
    It's up to you what you do next. Maybe going into the pack again will buy some time. Maybe it fails again. That's the potential price for a "cheap" repair.
    I went DIY when I first got my 2006. Took over a month to cycle all modules with hobby chargers, but it was "good" for 50k miles.
    The next time it hiccupped, I put a new OE pack in.
    Gentoo likes this.
  18. Gentoo
    28
    NY
    This definitely was not a cheap repair as the modules were harvested from a wreck, but I get your point, my unfortunate mistake of snapping one of the original posts to the module that paired with the rest caused this issue. So I guess my question once again is, is there anyone who sells quality gen 4 battery modules with 2019-2022 date codes that haven't seen abuse. I would hate to have to buy another low mileage wreck and do a full replacement, and then sell these modules individually minus the low voltage module which I will bring to E-Scrap. I can clearly see that the other blocks are performing as expected. I just need a high quality replacement.
  19. Tombukt2
    12,901
    2,316
    Apparently there's nobody here selling them and I don't know why they would be here they would be hoarding them for their car next project whatever like car people do You need to be getting online and talking to big big big auto salvage operations like the ones down in Conyers Georgia they are big If you ever see some of these places well we won't even go into that anyway That's the place is you're going to need to be talking to to find these 2019 to 2022 wrecks and then there's a lot of people in line before you that are all vying and trying to buy this same crap to resell to us I know people in my area that go around to LKQ and just rip break actuators and MFD displays out of generation twos to put them on eBay for exorbitant prices but I don't even think anybody ever pays or buys but they're doing that with so much of this stuff You know they can make a few bucks to keep up their other habits or whatever they got going on but that's how petty this stuff is it really is really petty I know guys that'll go out and go to LKQ and other smaller operations and just destroy things while they're out on the yard just so nobody else can get them yeah I'm telling you man it's like that real nice person hats.
    dolj and Gentoo like this.
  20. Brian1954
    2,138
    828
    The first thing to do is check the voltage sensing wire harness that connects to the battery ECU. Check the connector for any corrosion. This is a very common problem on a gen 2 Prius. If that checks out okay, then you need to determine which module in block #1 is bad. Is the bad module the one that you purchased? If so, contact the seller and request a free replacement.
    Gentoo likes this.
