Prius Oil Use. No Longer Trying to Fix a Non-Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ebikeman, Jun 6, 2024.
  1. ebikeman
    ebikeman Member
    106
    Northwest
    I’ve seen so many treads on the oil burning issue on our Gen 2 Prius. I thought Toyota screwed up somewhere, maybe the low tension rings, or some design flaw.
    I was reading the manual and saw some interesting tings.
    1. I thought it was a flaw that we burn oil. The manual says the car is designed to do that. They designed a car with a motor and a battery to get good gas mileage. In order to accomplish this, they designed it use as much as 1.1 quart, every 600 miles. Back when our cars where new, oil was $1.99.
    2. The manual says the most time we use oil is when we use the re-gen feature. That can be to a certain extent, under the drivers control.
    I’m relatively new to Prius’s. I love that when we get up to speed, then have to slow down or stop for a light, other cars you wasted all the energy usedto get up to speed. Ours, we gain some back with re-gen.
    I admit I overuse the re-gen, because it’s new to me and I like it. I come home down a hill that’s about 4 miles. The hill is steep enough that I gain speed. I put the stick in “B” so I get max re-gen and it slows me down just enough to maintain 45mph. By the time I get to the bottom, the battery is green, flush to the top. I then go home on flat, another 4 miles on battery only getting “99.9” mpg.
    When I go up big mountains, the battery is low, coming down I use “B” to hold me back and get the battery full again. I do it even in traffic. I asked a person at the dealer who’s driven Prius for 10 years and he does the same thing. Driving down the road, light turns red, flicks it in “B” and slows down that way.
    I now found out that the most oil used is in re-gen. That means you can have two people use the same car, drive to point A and back, one burns more oil because they used re-gen more.
    When people post they use oil, what can they do to stop it?, change to higher weight oil? Put in an additive?
    The correct answer is, that’s the way the car is designed. It’s like asking, my old car has one battery, this one has two. What can I do to fix it? Get a different car, this one has two battery's.
    So may times, people are trying to “fix” a “problem” that is not a problem with these cars. There designed that way
    Finding this out in the manual has completely changed my attitude towards my car. Understanding we get re-gen, and the trade off is we use more oil, I now accept and am fine with putting in oil every couple weeks.
    Hay! My car burns oil, what can I do about it? That’s the way it was designed. Accept it, or sell it. If you don’t like it, sell it and get a different kind. That’s not cold, it’s reality.
    Hay! My old car had only one battery, this one has two. I don’t like that, what can I do? Sorry, this car has two battery's. If you only want one, sell it and get a different kind. This is designed to have two.
    Just wanted to pass this off to my fellow Prius drivers.
    51,897
    doesn't oil burning add to pollution? testing is only done on new vehicles.
  3. maleko
    maleko Member
    102
    36
    Central FL
    I give my Prius a healthy drink of oil every other day when refueling... I commute 80 miles per day most work days (40 mi each way):
    8-12 mins stop and go to the highway (45-70mph)
    24-36 mins on the highway (85-100mph)
    8-12 mins stop and go to destination (45-70mph)
    I notice the oil consumption to be worse more in line with the rpms than the speed necessarily. Also a clean fresh oil change seems to fare a little better as well.
    I would estimate my Prius drinks 1/5 of a quart per commute day, or approximately 1 quart per week for me. Been that way for nearly 10 years now.
  4. Tombukt2
    12,950
    2,324
    Never heard any of this We use oil during regen You read this somewhere and where would that be Just out of curiosity I'd like to peruse that article because I've got a generation to that doesn't use any oil and it has three bars on the screen all the time when I'm driving it the little cars for the regenerative braking. So I'm doing a lot of regenerating and using no oil per se I do have some generation twos that use oil but I don't think regeneration of the breaking has anything to do with it personally because the car that burns oil the worst does a lot of you know state highway and some interstate driving so it doesn't really get a chance to regenerate much and that car goes through some oil I believe it's just poor maintenance high mileage something but it's not common for the one NZ to do this but it might be for the Atkinson FXE thing that we're dealing with here but it certainly not in Yaris and Scion vehicles this I know
  5. Mendel Leisk
    41,406
    Either a clever troll, or dead serious? Either way, hoo boy…
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,045
    1,969
    NJ-USA
    My experience with many "good" cars over the decades is that using 1 qt (or less) in 3000 miles is fine.
    However, the car manufacturers set a much higher limit because they do not want to warranty any "oil consumption" problems. (It must be good to write the laws so that they benefit you and no one else).
    Realistically, there's not much to be done about oil consumption unless you want to commit to a piston re-ring job.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Apparently so.
    This post has some misunderstandings and your interpretation of oil use is incorrect. Along with your understanding of use of B mode.
    The engine is not designed to burn up to 1.1 quarts of oil every 600 miles.
    EVERY internal combustion engine ever built will have some "oil burn". It's just a fact of life, mechanics and oil lubrication systems. BUT, they also have a maximum specification for the amount of oil that can be burned before it is considered to be a warranty item or considered to be the point where engine wear may be considered as "unacceptable".
    Toyota has merely decided that 1 quart of oil disappearing in 600 miles is the trigger point for their engine warranty. Other manufacturers use other trigger points. If you take the car in for that claim they will inspect the car for leaks, perform an oil change and SEAL the engine with tamperproof seals. They will document exactly how much oil was added. They'll tell you to drive the car a specific distance, then come back for them to perform another oil change, where they'll get an exact measurement of how much oil is removed from the engine and compare to how much was added at the start of the test. If the "missing" oil is greater than the trigger point, then warranty is triggered.
    Brian1954 and maleko like this.
  8. rjparker
    10,135
    6,298
    Completely wrong. Many gen2s over 100,000 miles use way less than a half of a quart in 5,000 miles. All used practically no oil when new.
    Your hv battery will be full if you simply maintain a safe speed downhill with your brake pedal. Which also controls regen.
    When the hv battery is full going downhill the hybrid system will automatically go into full engine braking to reduce brake pad overheating.
    You can do a ring and valve seal job to fix it if you wanted to get the oil burning under control. Oil burning has downsides: clogging a very expensive catalytic converter, potentially running out and ruining the engine and costing money.
    #8 rjparker, Jun 7, 2024
  9. dolj
    dolj Senior Member
    8,439
    4,288
    Wellington, New Zealand
    These misunderstandings are not unusual for the new Priuser.
    Putting the stick in “B” to get max re-gen is actually untrue. You get less regen using B. Here's why; the use of B is designed to increase the amount of time it takes to fill the battery. It does this by decreasing the regenerating current and adding additional engine braking to net a greater braking force akin to downshifting in a manual transmission. It is implemented with long mountain descents in mind to allow the battery to fill slower while descending the mountain and maintaining decent control. One of the downsides of using B is that oil disappears quicker than usual. It is simply a matter of physics when using the engine as a vacuum pump. Neither good nor bad, it just is what it is.
    A 4-mile downhill does not qualify as a long mountain descent. you can leave it in D and do your descent using the brake pedal to increase re-gen to hold your speed. If the battery fills doing this then all re-gen will be cancelled and replaced fully with engine braking (controlled with the brake pedal).
    For reference, the longest climb/descent close to where I live is a climb from sea level to 555 m (1820 ft) and the descent from the top back to sea level is approx 11 km (6.8 miles) in one direction and 7.6 km (4.7 miles) in the other. Neither descent is long enough to use B.
    Never use B on the flat in this way, you are just robbing yourself. Initial let off the accelerator from 1000 to 1600 m (¾ - 1 mile) out from the lights followed by gentle brake pressure as you get closer will net you much more into the battery.
    You have used language like this throughout your post, and I get the impression that you think "putting the stick in B" is "using re-gen". This is a misunderstanding. Re-gen is used all the time and is integrated into the hybrid synergy drive system. Basically, anytime you see green arrows going towards the battery on the MFD battery graphic, you are regenerating electricity. You increase re-gen by applying the foot brake.
    I hope that helps.
    SFO, Brian1954 and maleko like this.
