HV Battery code P3000-389
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by villageboar, Jun 5, 2024.
  1. villageboar
    villageboar New Member
    I have a 2008 Prius with 280K on the original HV battery. The 12V battery was replaced three years ago. My son used it regularly until he went to college this year and then it really didn’t get used much. The last time it moved was in mid-March; he drove it a lot then, including a 5 hour road trip. When I went to check on it recently, it was dark. No lights or response on the dash when I pressed the power button. I tried attaching a booster pack without luck and then I tried the standard jump start from the relay box. I don’t recall now what happened, but it didn’t start. I pulled the 36 month old Toyota battery (12V) and charged it at 2A for 10 hours, but the voltage didn’t hold at 12.4V for very long. I then tied in another 12V battery so that the onboard screen showed 12.6V. Basically, I get the red triangle and no READY light. I hooked up Techstream and pulled the codes. Once I reset the battery and deleted old codes, what remains is P3000 (with the 389 sub/INF code for Battery Control System/abnormal signal from battery ECU) and two, likely related, codes in the chassis under the ABS/VSC/TRAC system: C1259 (HV System Regenerative Malfunction) and C1310 (HV System Malfunction).
    When I reset the P3000 code the red triangle disappears momentarily before coming back ten seconds later and “Problem” being shown on the MFD screen along with a red hybrid battery light (main) battery icon on the MFD.
    So, there are indications pointing to a low voltage condition in the hybrid battery. I had planned to recondition the battery when that time came, but I’m wondering if I can do anything to “top it off” to get it running again so I can deal with it in the fall when I have more time to dedicate to it? I have read about the THS charger at the dealer buying an additional 2% over 10 mins, but that doesn’t sound like much. Can it be run several times? Is there anything I can test to see how far out of tolerances the battery is from getting a Ready light and starting? Any suggestions before yanking the hybrid battery? I'd love to run it for the summer and monitor the hybrid battery with Dr. Prius app for the future rebuild if possible. Thanks in advance for any thoughts.
  2. Tombukt2
    12,900
    2,316
    What kind of DC voltage do you have right now before the relays in the hybrid pack 210-205 190? Yeah there's a bunch of chargers around that can charge that thing at 300 DC volts at 2.4 amps something like that they're not too too costly but I'd be curious to know what you're resting pack voltage is just sitting there right now when you last were there.
  3. Brian1954
    Brian1954 Senior Member
    2,138
    828
    South Central PA, USA
    What were the "old" trouble codes that you deleted, and were they current codes? List them here, and you will get some advice on how to proceed troubleshooting the problem.
    dolj likes this.
  4. dolj
    dolj Senior Member
    8,428
    4,285
    Wellington, New Zealand
    This DTC is output if the Hybrid Vehicle battery is depleted or the Hybrid Vehicle control system has a malfunction.
    I'm going to go in the depleted battery direction. You should be able to see the battery voltage on the freeze frame data for this code (or the live data) to confirm.
    Brian1954 likes this.
  5. villageboar
    Tombukt2: I'd check the voltage but not sure where to do that. I suppose I can pull the seats and battery cover, but if there is an easier location . . . . Will Techstream show it anywhere? I was not able to locate the 14 battery packs in TS.
    The "old" trouble codes looked like they were stored from earlier issues, but here is the full list:
    P3000 Hybrid control Battery control system
    C1241 ABS/VSC/TRAC Low battery positive voltage or abnormally high battery positive voltage
    C1242 ABS/VSC/TRAC Open circuit in IG1/IG2 power source circuit
    C1259 ABS/VSC/TRAC HV System regenerative malfunction
    C1300 ABS/VSC/TRAC ABS ECU Malfunction
    C1310 ABS/VSC/TRAC HV System Malfunction
    C1378 ABS/VSC/TRAC Capacitor Communication Malfunction
    B1421 Air Conditioner Solar sensor circuit (passenger side)
    B1200 Gateway Body ECU communication stop
    B1207 Gateway Smart Key ECU Communication Stop
    B1271 Gateway Combination Meter ECU Communication Stop
  6. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    You can build yourself a "grid" charger to charge the HV bat. For less than $100. Using this "might" buy you the time you want. Then you can replace all the modules with factory new Panasonic modules and not waste your time "reconditioning"
    the HV bat. Of course in time you will have other costly unrelated repairs. These cars have an effective service life of 10 years and 150,000. But of course with inflation and lack of production ramp up after covid, many of us are trying to do what we can. But while doing so its prudent to acknowledge reality.
    Send me a private message if you want help sourcing items mentioned.
  7. Tombukt2
    12,900
    2,316
    And generation 3 might be the 10 years 150,000 mi I don't think that's necessarily for the generation too A lot of people knew these were going to go for a lot of mileage early on like some of the earlier well made Corollas very few things would take them out rust in certain states things like that but other than that they could potentially run forever I'm certainly would make great bug out cars and whatnot just very basic setup not much to foil or.make go bad
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    Are there any codes in the battery ecu? Usually if Hybrid vehicle control has P3000 there should be codes in the battery ecu as well.
    With Techstream you should be able to go into data for the battery or hybrid vehicle control and see block voltages and total HV source voltage.
  9. villageboar
    I'll double check the codes tomorrow, but I don't recall any in the Battery ECU. The original scan included a full health check run on all 16 ECUs. Here are shots of the original health checks (2) and the freeze frame data from the P3000-389 code (1).
    I have been looking at the grid charger route as a possible short term fix. Perhaps a few charge and discharge cycles would bring it back if this is the issue. I'll keep digging for the battery pack block voltages, but it certainly wasn't jumping out at me using Techstream ver. 15.0
    TS_health_ck pt2.jpg Hybrid data list.jpg TS_health_ck pt1.jpg P3000_freeze.jpg
  10. mr_guy_mann
    4,036
    1,965
    NJ-USA
    I didn't recall Toyota's naming of it, but the 2nd pic has "power resource VB - 200 V". So the HV battery is down to 200V.
    Battery ecu data would give block voltages.
  11. villageboar
    Well, that’s interesting because it was at 208V the day before on Tuesday. If each cell is 7.6 then the total voltage would be 212.8, so when it was 208 it was only 2% low, and at 200V, is only 5% low. Toyota says that each engine start will drop the battery SOC 1% if I recall correctly. It doesn’t seem like that would be low enough to conk it out for starting. The shop manual recommends turning the crankshaft to verify it is free in the troubleshooting for the P3000-389 code. I’ll keep digging, but does 200V sound low enough to throw this code?
  12. villageboar
    Went into the battery ECU and pulled the voltage data on the 14 blocks. All show a resistance of 0.019 ohms, but blocks 1 and 2 show voltages of 2.44V and 13.06v compared to the other twelve which are mostly around 15.00V (14.74v-15.00). Interesting that the end blocks are the lowest and the middle blocks the highest. I thought conventional wisdom was that the end blocks ran cooler and sustained higher voltages overall?
    Anyway, I guess the next step would be to pull blocks 1 and 2 and test the four units? I'm guessing 1 and 2 are both bad in block 1 and maybe only one is bad in block 2? I'm all ears to suggestions for getting the car running again. Good suppliers? Best practice before just shoving 3-4 new cells in the old battery?
  13. mr_guy_mann
    4,036
    1,965
    NJ-USA
    Yep, I think it does.
    Normally, the ecu is "happy" at around 60-75% State of Charge (225-235V). The dash gauge reads 1 bar at 40% (about 206V).
    At 200V (if the block voltages are even) then the SoC is just above 30%). Personally I've never seen a Prius that low, so can't advise exactly what the ecu would do.
  14. dolj
    dolj Senior Member
    8,428
    4,285
    Yes, it does and at that level, the car will not attempt to start the engine. The battery needs to be charged up to 210 V or more so one or more attempts can be made to start the engine.
  15. villageboar
    Given that the voltage is currently around 200, and then one of the blocks is showing 2 V, that adding a new block (two purchased cells) should push the voltage up to 213V. And replacing block two would bump that up even more. How likely do you think it would be that doing this might get the battery into ready mode so that the car could be running again? I realize the new cells are not going to match the old ones very well, but it would seem to me that if they just were running again that things would begin to equalize, even if the ECU threw a few codes along the way during this process.
    Perhaps running a grid charger to deep cycle the whole battery three times would help with this, although I don’t have one at the moment.
  16. Brian1954
    2,138
    828
    When the 12v battery is disconnected, all 14 battery blocks reset to the default value of 0.019 ohms until they are recalculated. I believe that is what you are seeing.
    The low voltages for the first two battery blocks might be a false reading. The Gen 2 Prius is known to have corrosion at the orange connector of the voltage sensing wire harness to the battery ECU due to water leaking into the trunk. When this occurs, false readings will be recorded by the battery ECU. You should confirm the voltages of those blocks by using a volt meter before assuming that you have bad battery modules.
    #16 Brian1954, Jun 7, 2024
  17. Carall
    Carall Active Member
    306
    102
    Harrisonburg, VA
    That corrosion at the orange connector of the voltage sensing wire harness to the battery ECU usually drains first 2 blocks (4 modules).
  18. villageboar
    Wow. This is fantastic information. Like having a pair of eyes where I cannot see. I’ll get back to the car on Monday and pull the battery so I can get more accurate measurements. Thanks for everyone’s insight.
  19. mr_guy_mann
    4,036
    1,965
    NJ-USA
    The battery ecu on a Gen2 does NOT equalize block voltages. I did a DIY refurb on the pack in my 2006 when I got it in 2020. The block to block voltage differences were about the same 50k later.
    The ecu looks at block to block voltage differences. As long as they stay within about 0.3V under all conditions, then there's no problem. If it goes above that for more than a few seconds then the ecu takes notice. The higher the difference, the less time before the ecu sets a code.
    Maybe yours will "just work". Maybe it codes immediately. Using a grid charger (& discharger) to cycle the entire pack should improve your chances of success.
  20. villageboar
    So, I pulled the 12V battery and the traction battery and disconnected the bus bars on the traction battery (which have a fair bit of corrosion on them). Incidentally, the voltage at the main terminals with the safety/service plug removed was still at 12V 30 minutes after pulling the plug. It was around 8 V after one hour. I was under the impression that the capacitors would fade after 5 minutes to 0 VDC so initially it had me scratching my head.
    I then checked the initial voltages of all 28 modules:
    Module # V
    1 0.30
    2 2.34
    3 6.33
    4 6.40
    5 7.40
    6 7.24
    7 7.37
    8 7.39
    9 7.40
    10 7.41
    11 7.39
    12 7.42
    13 7.42
    14 7.42
    15 7.41
    16 7.41
    17 7.42
    18 7.39
    19 7.41
    20 7.39
    21 7.41
    22 7.41
    23 7.39
    24 7.41
    25 7.39
    26 7.39
    27 7.37
    28 7.19
    It would seem that modules 1 and 2 are toast. There is evidence of liquid/electrolyte staining on the pan of the battery tray. Modules 3 and 4 seem very low, as well. All of the other modules are in the 7.37-7.42 range except modules 6 and 28 which are 7.24 and 7.19, respectively. So, if I had all the hobby battery charging equipment, it might make sense to buy 4-6 modules and then go through all the reconditioning and determine if enough of these modules can be deep cycled and then balanced and placed back into service. But, I don't have that equipment. Anyone care to weight in on a reasonable course of action at this point? I'd love to be able to resurrect the car to let my son drive it through the summer and then maybe spend a bit more time on the battery then. I also called Green Bean and they are two weeks out for replacement batteries in California. I don't have much faith in their batteries, but I do like that I can buy a battery with a transferable lifetime warranty for $1624 plus tax.
