New to me prius maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Halo9809, Jul 1, 2024.
  1. Halo9809
    Halo9809 Junior Member
    Swansboro
    Hey everyone, I just bought a 2014 Prius Four with 200k miles on it. I plan to keep this car for a long time. It currently is averaging about 37-39 mpg depending on my driving. I
    have a couple of questions to those with more experience than I do, I have a good budget to work with for preventative maintenance and would like to know what to have done. Ideally, I would really like to get about 10 years or more out of this car.
    I have already had the brake booster replaced as it was needed when I bought the car and the reason I bought is due to the great deal I got because of the brake booster/accumulator.
    I would like to try to get MPG back in the high 40s to low 50s if possible. What recommendations does everyone have for me? It has new brakes/rotors all the way around also. I have read some of the forums but in generally they are spaced out as issue to issue forms. I have some of the maintenance history but not all, it seems in general it was well maintained.
  2. bkman
    bkman Junior Member
    64
    Greater Seattle Area, WA
    Does this one have a new head gasket? How frequently oil was changed based on maintenance history (5K or 10K intervals)?
  3. Halo9809
    Swansboro
    It does not have a new head gasket, oil changes done approx every 5-7.5k miles
  4. Mendel Leisk
    40,476
    You know its service history? Private sale or?
    keep an eye on the engine coolant level in the reservoir.
  5. Halo9809
    Swansboro
    For the most part yes, from what I can see on the carfax it has been well serviced.
  6. Eddie25
    Eddie25 Active Member
    483
    203
    MI
    Make sure you are regularly checking the oil.
    Replace transmission fluid.
    Replace engine coolant and inverter coolant.
    Entire EGR system cleaning service including the intake manifold.
    Spark plugs? Take note that these are a VERY commonly counterfeit item, but the OEM's can easily go well over 200K.
    Mentally prepare for the head gasket to blow within the next 50k miles.
    Get yourself a OBD2 bluetooth dongle so you can monitor codes, temps, battery health, etc.
  7. Mendel Leisk
    40,476
    With 200k miles, and so far no mention of EGR cleaning, there's a decent chance it's got a stop-leak product in the coolant, to hold the head gasket together.
    Again, private seller, dealership, or?
    ^ Always worthwhile, but considering you're at 200K, maybe just something to study up on, and concentrate on head gasket assesment:
    #7 Mendel Leisk, Jul 1, 2024
  8. Halo9809
    Swansboro
    Private dealership, thanks for the recommendations so far. Is it worth it to just go ahead and have the head gasket replaced?
  9. Mendel Leisk
    40,476
    I would do nothing for a while. Odds are good there’s a stop-leak product in the coolant. This will effectively arrest head gasket leaks, for a while, which will make diagnosis of head gasket leaks nigh impossible. For a few months.
    it tends to wear off, and leaking head gasket symptoms return, typically coolant leaking into cylinders, usually starting with cylinder one (at passenger side of engine). Symptom is typically engine shaking on cold starts, after sitting overnight.
    if and when that occurs, a boroscope inspection of the cylinders will show coolant pooling atop piston, and unusually clean piston top. First thing in morning would be best time to inspect.
    head gasket replacement, followed by full EGR and intake manifold (it has EGR passages), and you may be good. There’s still a chance a piston arm has slightly bent, the damper between engine and transaxle and engine has incurred damage, and/or cylinder walls have scuffing.
    truth be told, it’d be prudent to just drive it a few months, and if symptoms arise, consider just selling at a loss, with full disclosure.
    there’s an outside chance you’ve got the miracle 3rd Gen, but I wouldn’t count on it.
    did the dealership make any mention of head gasket?
    one thing you could take a peek at, to determine EGR degree of carbon-clogging: the pipe between EGR valve and intake manifold. It’s covered in video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
  10. Mendel Leisk
    40,476
    Another thing: 3rd gens till partway through 2014 have “low tension” piston rings, which have proven extra suceptible to oil consumption . Your 2014 may or may not have these; would be good to know, a factor when deciding on a course. There is VIN at which the change occurred. @rjparker has the latest info on the VIN change.
  11. rjparker
    9,515
    5,823
    Each factory has its own sequence number when the revised pistons and rings were used.
  12. Eddie25
    483
    203
    MI
    If you could get it done well and for a good price I'd say yes, but it'd be expensive to the point where you should just wait and hope you get lucky, but prepare yourself. Maybe even look around if there are hybrid specialty places near you that do 3rd gen HG's because ultimately it's not that big of a job for someone who does it often, but they'd probably laugh if you said you wanted it done preemptively.
  13. rjparker
    9,515
    5,823
    Does this mean a small used car dealer? Or a Craigslist/Facebook seller?
    How much oil does the engine burn in 5,000 miles?
    Has the engine ever made a loud rattle sound when starting?
  14. Halo9809
    Swansboro
    Small used car dealer.
    I have not driven it enough to know yet to be honest.
    No, it has not made any rattling sounds when starting.
    I also did test the battery with the Dr. Prius app and it shows it to be at 50% capacity. Would this be the cause of the low fuel mileage? plan on dropping it off sometime in the next week or two when I get the chance with a trusted mechanic of mine to do the full EGR cleaning.
  15. bisco
    51,031
    The battery may be part of the problem, but have the mechanic go through all the ordinary bits of the car.
    Engine, brakes, tyres, filters, and etc
  16. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    All these comments sound very negative.
    You may have got one that was not driven hard and taken care of.
    I would put a bottle of Cataclean in.
    Then try the BG hybrid kit.
    Have your egr system and intake manifold cleaned out completely.
    Make sure to see it all clean and done.
    Clean or get new MAF & MAP sensors.
    Get new upstream A/F & downstream o2 sensors.
    New spark plugs/ignition coils, maybe fuel injector cleaning.
    Then disconnect the 12v battery for 10 minutes, after everything I said is done, you should see a minimum of 47mpg
    Toss in a new air filter for good measure.
  17. rjparker
    9,515
    5,823
    Yes a worn out hv battery will cause poor mileage.
    A mechanic has to be experienced in Toyota hybrids or will often misdiagnose. It does not matter if they are great in conventional cars.
  18. Trafficat
    Trafficat Junior Member
    60
    New Reno, Nukevada, Merica
    I have a 2012 Prius with a similar mileage to the OP with an unknown history, and am planning an EGR clean, but not planning a head gasket replacement. Should the head gasket be replaced even if there are no symptoms of trouble?
  19. Mendel Leisk
    40,476
    I would first check just the pipe between EGR valve and intake manifold, first, to get some idea of the rest of the EGR system. See video #16 here:
    I wouldn’t replace head gasket until you’ve got symptoms, typically harsh shake at cold-starts after sitting overnight (coolant leaks into cylinder overnight).
    FWIW, if you’ve just acquired it, with 200k there’s a good chance a recently bought 3rd Gen has HG failure, possibly masked by stop leak.
    Trafficat likes this.
  20. ASRDogman
    ASRDogman Senior Member
    7,123
    3,721
    "IF" you wanted to do the head gasket BEFORE it fails, that's okay.
    That was my plan. I had planned on doing it the next weekend. But it had that
    knock twice, then the coolant level went down slightly.... But it's done...
