Sodium Hybrid HV Battery
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Jul 4, 2024.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,152
    911
    The long wait is over folks, I am sure you may have heard about it earlier today.
    I will be using the V3 GT
    Pre-orders start 7/11/2024
    Use this link below
    Toyota hybrid battery upgrade pack– NexPower Energy
    If you have not seen the release video check it out here
    20240704_171730-1.jpeg 20240704_171803-1.jpeg 20240704_175520-1.jpeg 20240704_175514-1.jpeg 20240704_175530-1.jpeg 20240704_175612-1.jpeg 20240704_175619-1.jpeg
  2. Mr. F
    Mr. F Active Member
    387
    255
    Washington
  3. AzusaPrius
    2,152
    911
  4. alexymik
    alexymik Junior Member
    2015 Prius Plug-in
    Any plans or timeline for the Plug-In Battery to switch to sodium?
  5. AzusaPrius
    2,152
    911
    There are no plans for the plug-in it will remain with the NCM lithium.
  6. Radiospank
    Radiospank Member
    166
    77
    bro why is there shit always sold out.. like this isn't even advertised to the masses and its like some bespoke made to order shit.
  7. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    3 have been installed @ Hybrid Pit so far with success. Owners of them are really liking the bump in MPG and stability in the overall function of the power train since. (These have all been regular V3 models, not the GT since it is not available yet for public consumption for another month). Long term, we should all remain cautiously optimistic for the community at large's sake because this has great potential to be far greater than the Lithium option.
    With very little seat time with them, I can say they run really cool. Like on a 100 degree day, they peak at around 95 degrees at each of the 3 temp sensors and the one vehicle (2012) with a tired engine at 230k was still easily getting 50-52 mpg with A/C blasting and not taking it too easy on the test drive.
    Gen2_Accel likes this.
  8. ASRDogman
    ASRDogman Senior Member
    7,427
    3,867
    Get on the email list. Then when they come in you'll get an email. Then order it.
    That's what I did... Shipped the same day, got it in 3-4 days....
    Radiospank likes this.
  9. Rmay635703
    Rmay635703 Senior Member
    2,660
    1,682
    Somewhere in Wisconsin
    2013 Chevy Volt
    Sodium chemistry batteries are difficult to sort through and source for the hobbiest EV markets. Historically before diyelectriccar failed there were individuals in China that would organize a group buy to a us entity.
    Has anyone reached out to the 2 remaining entities on this front?
    If full specs exist along with cycle and temperature graphs there are still individuals with conversions that would take a risk on these. Guessing openinverter folks and one other forum for ebike/ motorcycles I can’t think of at the moment
  10. AzusaPrius
    2,152
    911
    @ASRDogman
    Oh yea I heard about that, hope you like it.
    You are welcome...
  11. ASRDogman
    7,427
    3,867
    "You are welcome.."
    For what? You have absolutely NOTHING to do with my decision to get it.
    Grit likes this.
  12. AzusaPrius
    2,152
    911
    Relax man I just said you are welcome, we both know you made that choice....lol
    Enjoy it that is all.
  13. ASRDogman
    7,427
    3,867
    You implied you had something to do with my decision.
    You certainly didn't. You are very careless in your decisions.
    I would say you hurt sales.
    "I" know, but you apparently don't.
  14. AzusaPrius
    2,152
    911
    Cool beans man have a good one and just enjoy it, great choice it is compared to others.
  15. Radiospank
    Radiospank Member
    166
    77
    question, i have voltage diff of .19 max between the battery modules. i got almost 180k but battery seems to be good still. should i upgrade or wait until the voltage diff is past .25?
  16. Rmay635703
    2,660
    1,682
    2013 Chevy Volt
    Personally if the car isn’t throwing codes I wouldn’t worry about it.
    If it is throwing codes and you have a grid charger discharger I would waste some of my time to keep an existing battery running as long as reasonable before getting another OEM NIMH battery.
    Anything not OEM is very much for tinkers and hobbyists who like to experiment, test and modify. If you just want a daily driver I would let others go first and report back after someone puts 50,000 miles plus on one of these new packs.
    Sodium is on the young bleeding edge and very exciting but all the early adopter risks apply
    Radiospank and Brian1954 like this.
  17. ASRDogman
    7,427
    3,867
    Using the Prolong system will likely extend the life of your battery pack.
    It worked for about 3 years for me.
    It's best to use it BEFORE you start having issues.
  18. V Sport Wagon
    375
    131
    Southern California
    Running the V3 GT now for 6 days, so far first impressions are up 5-6mpg over the Lithium V2.5. 56 mpg. It wants to coast in EV WAY longer on flat ground or in light traffic. When it gets to 80%+ charge it will run the engine efficiently to bleed some of the energy off if you keep charging it.
    Also the pack temps will actually start cooling down up to 6 degrees after a long spell in EV due to the design of the case and the copper sheets inside..very good heat dissipation. The power graph is much more linear, similar to the stock Nickel battery and I believe will be more robust for heavier users as well as hypermilers.
    If I am getting 56 mpg in a V...I can only image what a hatchback with a light throttle will get. All I know is poor Jack is swamped with orders and doing his best to get things sped up. If you've ordered one from any of the 3rd party sellers PLEASE..have patience!
  19. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    It's been three months for mine and about 10,000 miles on the battery. Coming from my previous pack which was a version 2 I've noticed the same thing regarding heat. The batteries definitely seem to run cooler than the previous pack. It could just be my butt dyno but I have had two different people say the car feels punchier in acceleration and "smoother" when it transitions to to gas motor from the electric. Overall, I'm really enjoying this pack.
    V Sport Wagon likes this.
  20. ASRDogman
    7,427
    3,867
    Sodium battery
