Rating a new 2024 Prius
Discussion in 'Gen 5 Prius Main Forum' started by jerryd, Jul 12, 2024.
  1. jerryd
    jerryd Junior Member
    53
    Florida USA
    Prius Forum,
    I have a 2018 Prius and I recently bought a 2024 Prius for my wife.
    We just took a 1500 mile trip with the 2024 and I drove.
    The cruise control worked great and the car almost drove itself.
    But, there are many features missing on the 24 that I have on my 18 and my wife had on her 2012 Prius C.
    1. There isn't a door lock on the passenger door knob.
    2. You have to unlock the doors to open the hatch.
    3. Most of the display features for MPG are gone.
    4. The heads up display is gone.
    5. If you don't enact Apple play the Toyota entertainment panel isn't much.
    6 There is no knob to change the radio station.
    7. Without Apple Play there is no built in GPS.
    8 There is no wireless iphone charger.
    9. The sound made for you to hook up the seat belt is very annoying. I know it's supposed to be annoying. Can I change it?
    10. The same sound is used for the intuitive parking assist. When I went through a car wash that sound blared the entire time. There should have a simple ON/OFF button on the steering wheel. I just turned it off.
    11. The heater and air conditioner settings are returned to default when you turn the car off. On my '18 it left all my settings as they were except the fan speed.
    12. The center console on my 18 is deep enough that I can keep a water bottle and some full sized books in it. The 24 is too shallow for any of that.
    13. The threaded inserts in the trunk for a net are gone.
    14. The wheels came with cheap plastic hub cap kind of things. The 18 came with okay looking hub caps and some fairly nice alloy wheels underneath.
    There may be ways to change some of these things in settings but I don't usually drive this car.
    Don't get me wrong, there are things about this car I like but I expect more from Toyota.
    Jerry Donaldson
    tomcornell, bisco and tovli like this.
  2. vvillovv
    vvillovv Senior Member
    4,315
    1,494
    NY
    So what's the verdict and rating scale for it?
    I'd venture to guess everything on your list has been covered here multiple times already.
  3. Mendel Leisk
    40,251
    Did your 2018 have a spare?
    Not sure what you mean in #1, the key lock; do you mean for the physical key? Our Gen 3 only has one on the driver's door, never used.
    I'd be missing our 3rd gen's JBL 6-disk CD player (Canadian Touring level), but appreciate that's been long gone.
    And the under-hatch-floor storage tray.
    And the second glove box. (didn't realize it existed for about the first 4 years of ownership...)
    And maybe, someday, toyota will break down and make decent door/hatch threshold protection pieces, standard:
    #3 Mendel Leisk, Jul 12, 2024
  4. Hammersmith
    Hammersmith Senior Member
    1,891
    1,882
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    From context, they have an LE/SE. So he means the 3-door keyless entry that comes on the upper trims. Half of his list would disappear if they had gone with an XLE/XSE. He appears to be comparing a mid/high-trim 2018(he mentions it has heads-up display) with a bottom trim 2024.
  5. reservoirblue
    reservoirblue Member
    70
    46
    Woodacre, CA
    2024 Prius Prime
    SE
    Nevermind.
    #5 reservoirblue, Jul 12, 2024
  6. bisco
    50,825
    decontenting is what toyota does best, along with most other mfg's
  7. Lantaral
    Lantaral Member
    65
    30
    US
    2024 Prius
    Most of those features are available in the higher trims. Though personally, don't find the higher trims to be worth the significant price premium, as the base model has the same performance, same safety systems, same advanced driver assist, and better MPG.
    Correct on item 3. The prior gens allowed easy access and tracking of MPG, the 5th gen appears to have removed that functionality entirely. Odd given how MPG is one of the Prius' traditional standout features.
    Incorrect on item 7. There is a built-in GPS navigation system, subscription required after the free trial.
    #7 Lantaral, Jul 12, 2024
    reservoirblue likes this.
  8. Zeromus
    Zeromus Active Member
    468
    240
    Ottawa Canada
    2024 Prius Prime
    SE
    Base models don't include the free trial for the full connected featureset that includes GPS and Traffic Jam Assist. But it has remote connect for remote start (no digital key afaik).
  9. Lantaral
    Lantaral Member
    65
    30
    US
    2024 Prius
    Interesting.
    Didn't realize there wasn't a free trial, have never tried to use the built-in nav.
    A self-defeating decision on Toyota's part not to include a trial. Wonder what the subscription attach rate is? Guessing a low single digit percentage overall, less on the base models.
  10. Trollbait
    12,244
    Navigation and connected services vary by market. While the nav is cloud based in the US, it is local to the car in Europe. Or at least an EU regulation makes it available without a subscription.
    As of today, only the Limited gets a trial subscription to the Drive Connect with the navigation in the US.
  11. Hammersmith
    1,891
    1,882
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    (just to avoid confusion...)
    All Primes also get the one year Drive Connect trial.
    no: LE, XLE
    yes: LTD, SE, XSE, XSE+
  12. Zeromus
    468
    240
    Ottawa Canada
    2024 Prius Prime
    SE
    Not in Canada, the SE prime doesn't get drive connect trial.
    We get other features the US SE skips though.
  13. JohnnyPR
    JohnnyPR Member
    96
    25
    Hinesville, GA
    Too bad the mpg features are removed in those new models.
  14. Hammersmith
    1,891
    1,882
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    What mpg features are you talking about that are now missing?
    You can set the display to give you a current mpg reading, or you can set it to give you one of three average readings: since a manual reset(Total), since you last filled up(Tank), or since you started the car(Trip).
    From what I can tell by reading the gen5 and gen4 owners manuals, they added one feature(tank average) and removed one(individual trip A/B averages).
    Preebee likes this.
  15. Lantaral
    Lantaral Member
    65
    30
    US
    2024 Prius
    In my earlier gen, each trip meter (A or B) had an MPG associated with it and could be displayed persistently. Resetting that trip was all that was needed to also reset the MPG for that trip.
    #15 Lantaral, Jul 15, 2024
  16. tomcornell
    tomcornell Junior Member
    SE FLA
    2018 Prius
    How does the Prius connect to the host? Via the driver's cell phone or is there a cellular radio built-in to the vehicle?
  17. Trollbait
    12,244
    I think every new car available today has a cellular radio.
    tomcornell likes this.
  18. Blackat
    Blackat Active Member
    388
    247
    Colorado
    2023 Prius
    Limited AWD-e
    Glad I got the LTD, TBH, it was my only choice. Very hapy with the car
    Preebee likes this.
  19. Surfbob
    Surfbob Junior Member
    Central California USA
    2024 Prius
    I read down your list and wondered if we were talking about the same car. Most of them don't apply to my 2024 LTD...door locks, hatch opens at press of a button if you have the smart key, heater/AC set temp and it holds indefinitely, etc. As far as the sound system, it works great wired or wirelessly with Android Auto on my Pixel8 (also charges fine wirelessly). I think the built-in systems on most cars are pretty worthless overall if you rely on them for entertainment or navigation, so I checked before buying that it would connect to Android Auto without me having to do anything but start the car, and it does. The built-in obsolescence of OEM systems is a money pit if you try to keep it current, and ages a car prematurely if you don't, and keep using it.
    Just pointing this out so others reading it don't think this is true of all 2024 models. I looked only at the LTD after years of seeing people with buyer's remorse after finding out some feature didn't come with their model. It's nice to discover something you didn't think you needed or wanted, and finding out it's something you like after all.
    But do check your settings, as you mentioned, because some of the things probably ARE in the options.
    reservoirblue, Blackat and _flop like this.
  20. reservoirblue
    70
    46
    Woodacre, CA
    2024 Prius Prime
    SE
    I have a 24 Prius Prime SE. Reading through the list above (jerryd), I believe some missing features mentioned don't apply to the Prime- albeit base model. Others I simply don't notice. What I do notice are my rare stops at the gas station unless I go on a road trip, and the impressive and smooth acceleration when it's needed, or just because...:D
    Preebee likes this.
