Just need to vent...
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Jul 6, 2022.
  1. fuzzy1
    10,332
    I have accumulated more first-hand failure experience now than 40 years ago, and have a better idea what to watch for.
  2. Mendel Leisk
    40,245
    Not shy to admit, my main issue is lifting tires back on. I've adapted: have the wheel "just" clear, no more than an inch. Roll the wheel/tire up, as close as practical, and oriented to suit studs. Tuck my toes under the wheel (around 4:30 and 7:30) and lift, while guiding onto the studs with my hands.
    John321 likes this.
  3. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Luckily for me the 15 inch Prius wheels are not too heavy. My wife's Subaru wheels are a bit heavier. At 81 I can still handle the job and should for the next few years.
    JeffD
  4. Mendel Leisk
    40,245
    Pretty much everybody-proof, but they didn’t see me coming. Cap says press-and-turn. Tried that till I just about injured myself. Then out to the garage, try vise and pliers: no dice. Two surgeries and a repeated application of pliers: it’s opened.
    ^one more hurdle, locking band has to be removed; it has deformations locking against sim on bottom edge of cap. IMG_5037.jpeg
    ^ telling, that even now pliers required to get it unscrewing.
    #1844 Mendel Leisk, Jul 24, 2024
    Merkey likes this.
  5. ETC(SS)
    6,842
    I call those "Adult-proof" containers......
  6. Mendel Leisk
    40,245
    Had a similar cap on a tin of acetone; except it was mercifully easy to dissect.
  7. hill
    8,580
    Worked with a lot of teak oil in shipyards many years ago - & have some teak furniture as well. As that stuff begins to thicken / coagulate inside those caps - it becomes impossible to remove, due to the cap's safety feature & the oil turning to a form of glue. But for its cost - it's almost worth throwing out.
    #1847 hill, Jul 24, 2024
  8. Mr.Vanvandenburg
    1,311
    534
    2020 Prius Prime
    I worked with a man much older than me. He could take an apple in his hands and twist it into two perfect halves. Seemingly with little effort. I’ve tried and nothing happens.
    Now I am getting even weaker. Sometimes I use diagonal wire cutters to snip at the caps.
  9. Mendel Leisk
    40,245
    Scenario: elderly man, sprawled on floor, dead, his unopened, childproof heart med bottle beside him.
    I sometimes have to break out the oil filter pliers, for spaghetti sauce jars.
    That bottle of peppermint essesnce oil though, was a non-starter. Your apple splitter guy could maybe wrench the neck right off it, but the cap was not going anywhere.
  10. ColoradoCrow
    ColoradoCrow Senior Member
    1,057
    436
    Leawood, KS
    I
    Yes. Getting weaker is a PITA as well as less flexibility getting into and out of a car. I now choose to sit up as much as possible to make seeing driving easier. One thing that helps men is to link light exercise to daily activities. When you wash your hair do squats, when you brush your teeth stretch your hamstrings....and do 25 counter pushups before and after...then rinse.;)
  11. ColoradoBoo
    ColoradoBoo Senior Member
    1,110
    728
    Monument, Colorado USA
    I have three herniated disk so I can not longer handle the bigger wheels (like in my Tundra) but I can, still, manage those on our Prius. I just sit right down near the tire hub and roll the tire onto my lap and place it on...seems to work pretty good. I've, also, seen folks use shovels to lift them up for installation but you need quite a bit of room for that.
    Concerning the spare tire issue, I added one to my AWD Prius and will do the same with my wife's Corolla AWD Hybrid comes in....it's been on order since the first week in May and, still, no build date, much less a transit date. My salesmen said, at this point, we'll probably just end up with a 2025 so hoping there's no big changes on colors or options or, most of all, that MSRP....we'll see.
  12. hill
    8,580
    one things for certain, when we die it's because something or multiple aspects of stuff wore out. Will it be my kidneys? the brain? the immune system? who knows. At one time there was nary a jar that was ever even given any consideration. Gone are the days - 15 reps at 225Lbs prior to heavy lifting or 100 mile bike rides or mile swims. Now - just mowing the lawn is a midnight recipe for leg cramps.
    #1852 hill, Jul 24, 2024
  13. Mr.Vanvandenburg
    1,311
    534
    2020 Prius Prime
  14. fuzzy1
    10,332
    I thought that patients, especially the elderly, could ask for non-child-resistant bottles.
    My dad's prescription bottles (before his prescriptions were moved to patient pill-paks) had reversible caps: child-resistant if put on one way, regular easy screw-on when flipped over.
  15. jdenenberg
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I often use bad words when struggling against the "Packaging Police". You often cannot open a consumer package without a tool. Just this morning I opened a plastic tub of coffee and after struggling with the foil "safety seal" (it had a useless tab to open it), took out a sharp knife to defeat the seal.
    JeffD
    #1855 jdenenberg, Jul 25, 2024
    Merkey and bisco like this.
  16. ETC(SS)
    6,842
    I remember those reversible lids fondly, but I haven't seen them in a while.
    Fortunately I'm only on vitamins and supplements for now with maybe a Sudafed or an OTC pain/swelling pill for those >20,000 step days.
    After wrestling them out of their adult-proof containers, I place them in a M,T,W... pill box.
  17. AzWxGuy
    AzWxGuy Weather Guy
    1,022
    515
    Tucson, AZ
    2021 Prius
    Fitbit steps? I get 10 to 15,000 a day. Can't imagine 20K.
  18. fuzzy1
    10,332
    I guess I shouldn't tell you about our hiking days where the spouse's Fitbit exceeded 40k. ;)
    I obtained one only recently, and haven't used it much (need to get around to calling Customer Support about battery life and other problems), so don't yet have my own 35k-step badge, merely 30k. Probably would have had a great number if I had worn it on our long bicycle ride this week, where we biked my spouse's age (in miles) for her first time since the Pandemic. (The first digit of her age is a 7). Extrapolating from other rides, I'm guessing that my longest rides, the Seattle to Portland event in one day, could have been approaching 80k. Am seeing ultra-marthoners mentioning 120-150k in a day, and running is much higher impact than pedaling.
    #1858 fuzzy1, Jul 27, 2024
  19. ETC(SS)
    6,842
    Most of my days are a more age-appropriate 10-15k.
    I used to have a Fitbit but owing to my working on ladders a lot and because of my failings as a father and a husband - all of the ladies in my life including two inadequate sons-in law use dumb-people-phones.
    SO.....I now use apple products - keeping my old Droids for IOT and other tech-geek things outside the walled garden.
    25k days are mowing with a push mower.
    A little more throttle intensive than just strolling but maybe not as much as jogging.
    I like the cut better than just mowing down brush with one of my two riding mowers - one of which is down for maintenance, and other of which is only for suburban/cfo use.
    #1859 ETC(SS), Jul 28, 2024
  20. ColoradoBoo
    1,110
    728
