Brake, VSC, ABS, ((!)) lights on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by swhalen06854, Nov 17, 2016.
  1. k barbieri
    k barbieri Junior Member
    Brooklyn, N.Y.
    Oh I’m approaching 30K. I know I know low mileage but in nyc while working we do not use our capers mah maybe that is it...
  2. k barbieri
    Brooklyn, N.Y.
    Yes that’s my thought bring it to my mechanic first then Toyota
  3. k barbieri
    Brooklyn, N.Y.
    Update.... brought to mechanic they put 2 different computers on car to clear . Unfortunately matter putting
    A black computer reader on all lights for brakes came on including parking brake, VSC, ABS, and the icon
    Could not be cleared.
    my 2008 is now in the hands of Bay Ridge Toyota here in Brookkyn NY....where I purchased it 10 years ago this month and approaching only 30,000 miles.
    Stay tuned. $125 plus tax just to look at it.’’’’’’’’’
  4. k barbieri
    Brooklyn, N.Y.
    So there is a wiring issue, front brakes and rotters(rusted),
    Then they found a leak in water pump and transmission oil to be replaced.
    I gav3 the oK in 10 years I’ve only replaced the brakes, some oil changes
    And tires so the $2000 this is going to cost....
  5. k barbieri
    Brooklyn, N.Y.
    Cost of the above $2000
  6. JD Bischof
    JD Bischof New Member
    Arizona
    Wanted to add to this thread in hopes it helps someone. Background:
    We've owned this 2005 Prius for approx 4 years now. Bought it with 180k on it. It now has 214k. No work had been done on it in the past few months. We've just been driving it. My son was driving it the other day and suddenly Brake, VSC and ABS lights all came on. He didn't run over anything. We could not correlate this to any causational event.
    I couldn't pull any codes using my OBDII app on my phone so ordered a Topdon Phoenix Lite 2. This enabled me to pull the codes. First pass it showed the following list of codes:
    C0371 Yaw Rate Sensor Output Signal
    C1241 Low Battery Positive Voltage or Abnormally High Battery Positive Voltage
    C1242 Open Circuit in IG1/IG2 Power Source Circuit
    C1256 ACCumulator Low Pressure
    C1271 Low Output Signal of Front Speed Sensor RH
    C1272 Low Output Signal of Front Speed Sensor LH
    C1273 Low Output Signal of Rear Speed Sensor RH
    C1274 Low Output Signal of Rear Speed Sensor LH
    C1275 Abnormal Change in Output Signal of Front Speed Sensor RH
    C1276 Abnormal Change in Output Signal of Front Speed Sensor LH
    C1277 Abnormal Change in Output Signal of Rear Speed Sensor RH
    C1278 Abnormal Change in Output Signal of Rear Speed Sensor LH
    C1281 Master Cylinder Pressure Sensor Output Signal is Faulty
    C1346 Stroke Sensor Zero Point Learning
    C1391 Abnormal Leak of ACC Pressure
    I cleared the codes and re-read them and was left with the following:
    After searching and reading, my suspicions led me to think that the issue was the Yaw Rate Sensor. I went to a local wrecking yard and pulled one from a wrecked Prius, paid $50 for it and brought it home. Voila!
    All the codes immediately cleared and the car is back to normal.
