Yet Another Tyre Replacement Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tideland Prius, Jan 4, 2007.
  1. Tideland Prius
    16,538
    Hey guys,
    alright, so I'm asking the PC community for help. Apparently I've hit a nail and it lodged itself on the sidewall of my rear right tyre (inside I guess since I can't see anything on the outside). Because of the location of the nail, I can't repair the tyre.
    I'm currently running on stock tyres with 40,679kms on them. They're wearing down evenly. When I got to the dealership for service this morning (unaware of the low tyre pressure), they told me the tyre was only running on 10psi of pressure (eek! And I was running at 80km/h at one point on the way to the dealer).
    Anyway, so their suggestion was to replace that one tyre with the GY Integrity which makes perfect sense, except that I wanted to get rid of the Integrity so I'm not exactly going to put another new one on and wait another 40K+ km of low grip and noisy tyres.
    The other option (which I'm also just as reluctant as it's expensive) is to replace all 4 tyres with a new set. 40,000km is fairly short and there's a decent amount of tread left and are wearing evenly.
    So, I've narrowed my choices down the following
    1. Nokian WR
    2. Goodyear Assurance ComforTred
    3. Michelin Energy MXV4 Plus
    I've asked a few members here about the WRs but I've read about bad experiences relating to tyre noise and dry pavement grip. The ComforTreds seem to be the way to go if I want a quiet ride (although they're apparently hard to find around here). The MXV4 Plus is a fairly decent set that's quiet and is an LRR but snow/ice is average.
    The bottom line is, I'd like to hear from your experiences if you own any of the 3 above-mentioned tyres and any pros/cons that you've noticed (probably helps to state the tyre pressure you run on and size) for the period that you've owned the tyres.
    Thanks in advance. I'll be carless until I can decide on a replacement.
    P.S. With regards to the first option. Would it be better if I find a used tyre with similar mileage and let all 4 tyres wear out? If so, where do you find used tyres? Would most places be run by shady people?
  2. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    ComforTreads for Me
    Snow isn't an issue here, but our heavy rains can be a driving challenge. The ComforTreads deliver a safe, quiet and smooth ride and claim an 80,000 mile service life. The only downside after 5,000 miles, is a 2 MPG drop. The Integritys are hard, loud and much worse than just about anything you'll replace them with; I got rid of mine at 15,000 miles and couldn't give them away.
    I ordered my ComforTreads from the Tire Rack and they were delivered in two days; my dealer mounted and balanced them for $52,
    I recommend investing in better tires, which means avoid the Integritys.
  3. Tideland Prius
    16,538
    Thanks.
    So both the Nokian and GY will result in a drop in mpg... I guess I'd rather lose some mpg for a significant gain in grip.
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Just out of curiousity, Tideland, may I ask why you're not considering the HydroEdge? It would seem well suited to your local climate - which, if I recall correctly, is darn close to mine. :)
    If you are still exploring the used option, I recall relatively recent threads here offering Integrities.
  5. Tideland Prius
    16,538
    <div class='quotetop'>QUOTE(hyo silver @ Jan 4 2007, 02:17 PM) [snapback]370985[/snapback]</div>
    Good question. I had a reason of which I cannot recall at the moment. I've seen tons of cars with HydroEdges around here (must've had a sale or something). Maybe it's a mileage thing? My dad's Camry uses the Energy MXV4 Plus which I use as the benchmark since it's quiet, efficient and fairly grippy in most situations (so-so in slushy conditions)
  6. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    The problem of one bad tire. I'm not a fan of buying a used tire, but that depends on your budget. With 40k kms on them, I don't know how much life your remaining 3 tires really have left on them, and if it were me, I'd just replace them all with something better. I usually only get 25k miles (40k kms approx) out of OEM tires, if that, and I just don't like Integrities that much anyway... I have 17K mi. on them now, and they are wearing well, though, looks like they could last a long time. Of the tires you listed, I've only had the Michelin MXV4s, and was very pleased with them. I don't see much snow or ice, but lots of rain, and the handling met my needs.
    Another option, if you can't afford to replace them all now, or you are like me and just quite can't bring yourself to basically throw away good tires, you could get 2 new tires and put them on the rear for now. Don't rotate them until you replace the fronts in the future, and then put the newer tires on the rear. In theory the 2 brand new tires should be Integrities to match what you have, but I'd go with 2 Michelins or whatever you want to ultimately end up with, and then go from there. This is not the recommended approach, mixing brands, but circumstances sometimes demanded something less than the ideal, which is 4 tires all alike, both in terms of brand, style and treadwear. Even on a FWD car, the best tires always go on the rear if you have to mix things up.
  7. nyprius
    nyprius Member
    385
    24
    Saratoga Springs, NY
    <div class='quotetop'>QUOTE(Tideland Prius @ Jan 4 2007, 03:21 AM) [snapback]370624[/snapback]</div>
    I did a lot of research on new tires and posted in here (http://priuschat.com/index.php?showtopic=21271&hl=).
    I suggest you replace all 4 Integrities, even if they have some tread left. The Integrity is a low quality tire. Replacing it will greatly improve handling.
    I also suggest you get 195 width tires, probably in a 195/60R15. 195 is the OEM size in Europe and Australia and the higher option size in the US and Japan. The 195 will improve safety, handling and looks.
    You might also consider the Tripletred. I think it's a better all around tire than any you mentioned.
  8. Tideland Prius
    16,538
    Hmm, thanks for the suggestions.
    Beryl, the main issue is cost. My Integritys are wearing down evenly at all four corners (rotated every 8,000kms). My dad's Camry had the MXV4 Plus and had them replaced around 70,000km. I don't know if the Integritys will actually last that long.
    Ideally, I'd like to replace all four tyres but at the moment, a set of 4 Nokians will set me back $720 OTD.
    nyprius,
    I'm aware of the Integrity issue hence my initial reaction towards changing all four tyres.
    OEM size on Touring models and European models is 195 but they're 16" not 15" but I see what you mean.
    TripleTreds come in 195/60R15 as the smallest size right? I'll see what I can do. GY tyres seem to be hard to find in my area. I'd probably have to do a cross-town trip to get a set lol.
    Any experience with the TTs?
  9. Vincent
    641
    31
    South Florida
    Tideland,
    My 4 ComforTreads cost $316 (US) delivered by Tire Rack. Delivery took 2 days and dealer mount and balance cost $52.
  10. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    Purchased TripleTreds this fall, great in the rain, only one snow event so far, very happy with the result.
  11. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(Tideland Prius @ Jan 5 2007, 02:30 AM) [snapback]371151[/snapback]</div>
    Tideland Prius,
    I've had TTs on my car for 10,000 miles and they're excellent. If you read through reviews on tirerack, epinions and 1010tires, you'll see TTs are given excellent reviews by nearly everyone that has them. CR rated them the number one all season tire too.
    However, the TT is an expensive tire. CTs aren't as good on dry and wet pavement, but they're nearly as good and cost less. The WR is a good tire in snow, but not so good all around. There are several good all season tires that would be a vast improvement over the Integrity. It's hard to go wrong if you pick any decent all season tire. They're all better than the Integity. Be careful with performance all season tires. They're often not as good on wet/snow pavement and have low/no mileage warranties. Overall, I think all season is better for the Prius than performance all season, for reasons stated in the post I mentioned above.
    I know the European and Touring models come in 16" rims, but that's irrelevant. The point I was making was about getting a wider tire. You can easily put them on your 15" OEM rims. If you look at the post I mentioned above you'll see the pro's and cons of going with a 195/60R15, 195/65R15 or 205/60R15. These are the best wider tire choices I think. I went with the 195/60 for many reasons stated in the post.
    Good luck!
  12. Tideland Prius
    16,538
    Thanks guys!
    Hmm.. so tyres are cheaper in the States <_<. Yeesh.
    nyprius, I wanted to get a set for my dad's Camry but as I've mentioned before, they seem to be hard to find in BC. Noise is an issue for me since the Prius has little sound insulation (you can clearly hear the water splash against the rear wheel well when you sit in the back seat as opposed to a muffled sound in my dad's Camry).
    That's one reason for leaning towards the CT... assuming I can find some.
    I won't be going for performance AS tyres. The most I'll do is "Touring" such as the MXV4 Plus.
  13. Frank Hudon
    Frank Hudon Senior Member
    4,147
    if your still looking for a used tire I know where there are some wrecked Prius. PM me for more info.
  14. Tideland Prius
    16,538
    oye.. Should've checked PC last night lol. I've already changed the my tyre Frank.
    I've changed the one tyre back to the Integrity. I'll probably settle with the CT as a compromise between the TT and WRs. I like the WRs but they seem to have some noise and dry road issue (which are obviously offset by the winter condition performance).
  15. Frank Hudon
    4,147
    wife absolutly loves the HE's that I put on her Prius. Said no slipping or sliding in the snow and this last dump didn't have the TRAC cut in. They were pretty cheap also, $628 installed balanced taxes in.
  16. Tideland Prius
    16,538
    wow, that's pretty good.
    Yeah, I've seen tons of cars here with the HEs... wonder if there was some sale lol.
