Is there a way to turn off the daylight running light while parked and in Ready mode?
Discussion in 'Prime Main Forum (2017-2022)' started by sylvaing, Jul 31, 2024.
  1. sylvaing
    sylvaing Senior Member
    1,210
    514
    When I clean the car, I like to listen to music and with the car in Ready mode, the daylight running light are on. On previous car, putting the handbrake turns them off but this doesn't work on the Prime. So, is there another way? Surely there is one otherwise people would throw a fit in a drive-in theater lol.
  2. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    I believe you can not do it in Canada. In the US you just turn the left stalk to DRL-OFF.
    FuelMiser likes this.
  3. sylvaing
    1,210
    514
    I guess no drive-in for us with the Prius then, unless I put in in Accessories and carry a booster :(
    Louis19 likes this.
  4. ForestBeekeeper
    ForestBeekeeper Active Member
    778
    307
    Maine
    I think the secret is to avoid using the 'READY'.
  5. sylvaing
    1,210
    514
    Which drains the puny 12V battery when not in Ready.
    Louis19 likes this.
  6. ForestBeekeeper
    778
    307
    Maine
    But if you want to avoid the running lights coming on. What else can you do short of pulling fuses?
  7. ChapmanF
    18,426
    Wasn't there a thing about the DRL only turning on when you release the parking brake after going READY?
    Maybe I imagined it.
    alanclarkeau likes this.
  8. KMO
    KMO Senior Member
    2,002
    728
    Finland
    2023 Prius Prime
    That is the case for the European G5. Only helps in daylight though, because at night you're then facing the automatic headlights, for which there's no OFF.
  9. sylvaing
    1,210
    514
    I guess nothing, but in all my previous cars before this one, putting the emergency brake on while parked turned off the running daylight.
  10. Mendel Leisk
    41,791
    Visual aid:
  11. sylvaing
    1,210
    514
    LOL, might as well go back to the speaker you hang off the side window :ROFLMAO:
    Louis19 and Mendel Leisk like this.
  12. Starship_Enterprius
    Starship_Enterprius Active Member
    331
    163
    Ottawa, Ontario
    2018 Prius Prime
    kinda late reply.
    Put on the parking brakes, turn off the car, then turn on again. That has always worked for all my cars including my 1st gen, my 3rd gen, and now my Prime.
    BiomedO1 likes this.
  13. BiomedO1
    3,978
    2,095
    SacTown, Ca
    Most cars I've been in, turns on the DRL when either the parking brakes are released or the car is placed into gear. If you park and don't reinitiate the system, the DRL won't turn-off.
    Starship_Enterprius likes this.
  14. sylvaing
    1,210
    514
    I'll wash the car this evening when the sun is lower. I'll give it a try. Thanks.
    Edit: Yep, it works :)
    It's my first car that I have to have the car off before the emergency brake are engaged for the daylight running lights to be off when the car is turned on. TIL.
    It was almost inconceivable that you couldn't turn them off outside of pulling a fuse.
    #14 sylvaing, Aug 13, 2024
