Cabin / Air Filter Combo
Discussion in 'Gen 5 Prius Main Forum' started by mannymendez25, Aug 1, 2024.
  1. mannymendez25
    mannymendez25 Member
    56
    32
    Miami
    2020 Prius
    I took my 2023 Limited today for the complimentary 15k mile service. The tech recommended a new Cabin / Air Filter combo @ $80.00. I know what an air filter is (goes in the engine compartment), and I know what a cabin filter is (typically behind the glove box), but never heard of a combo filter. Anyone have more information?
  2. mannymendez25
    56
    32
    Miami
    2020 Prius
    Wait a minute, are they selling the air filter and cabin filter together as a combo set?
  3. Juan Figueroa
    Juan Figueroa Junior Member
    Fort Lauderdale, FL
    2023 Prius
    If the job was recommended by toyota, should that be cover under the 2yrs 20,000 program?
    samsprius1 and bisco like this.
  4. hill
    8,581
    Either way, you can do it yourself for $30 bucks - online parts suppliers. Don't fall for that scam
    RandyPete and PriusCamper like this.
  5. bisco
    50,825
    yes, that was a dealer combo service special. unfortunately, the engine air filter isn't due until 30k, and either way, i have never found either filter very dirty, but that may depend on environment.
  6. Mendel Leisk
    40,251
    Yes:
    ^ This. Do it yourself, and only replace when it needs it.
  7. bisco
    50,825
    the air filter is a snap. the cabin filter is a bit more touch, at least on my gen 2 and 3. the design of the glovebox is very poor in my opinion.
    daisy555 likes this.
  8. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    346
    268
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Question: When you turned on your 2023 Limited for the first time of the day, did you have any brief moldy odor?
    mrlarrys likes this.
  9. vvillovv
    vvillovv Senior Member
    4,315
    1,494
    NY
  10. vvillovv
    4,315
    1,494
    NY
    @tovli getting rid of condensation that can build up in the HVAC system when using A/C or defrost in freezing weather while in ECO mode can sometimes be helped by switching to POWER mode so the HVAC stays on continuously instead of cycling like it does in ECO mode. Thanks @drash !
    tovli likes this.
  11. Hammersmith
    Hammersmith Senior Member
    1,891
    1,882
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    They're selling it as a combined service. With one exception, air filters should not be changed by date or milage, but by visual condition. Just a little bit of dust/dirt is just fine(it actually makes the filter work a bit better when it's a touch dirty). The vast majority of people either change them way too often(because it's easy money for the repair shop to recommend), or they never replace them even when they should.
    If you have even the remotest doubt, ask to see the filter. If it's significantly darkened from dirt or mold, let them replace it(or do it yourself). Otherwise, make a mental note to yourself that this dealer likes to recommend unneeded services.
    The one exception is if you decide to use the premium cabin air filter that contains activated charcoal(for odor control). If you go that route(and I do), you need to change the filter yearly because that's how long the activated charcoal portion lasts. The filter can still do its job filtering out dust and pollen for much longer than that, but the activated charcoal will be used up.
    BTW, here are the part numbers and prices for genuine Toyota air filters for the gen5. This is not an area where you need to stay genuine, though. Any decent quality paper filter of the proper size will do the job. I tend to buy them myself, do the engine filter when it's needed, and have the dealership install the cabin filter during my routine spring service.
    Part Number - MSRP - Lewis Price - Description
    17801-24040 - $30.99 - $19.54 - Engine Air Filter
    87139-YZZ83 - $21.99 - $15.47 - Cabin Air Filter (standard)
    87139-76020 - $52.99 - $36.79 - Cabin Air Filter (premium)
    vvillovv likes this.
  12. mannymendez25
    56
    32
    Miami
    2020 Prius
    Thats what I thought but the service advisor said these items are chargeable.
  13. mannymendez25
    56
    32
    Miami
    2020 Prius
    Thanks for all the great information. I will inspect the filters myself this weekend. I doubt they need to be changed after only driving 14k miles.
  14. PriusCamper
    PriusCamper Senior Member
    11,870
    4,814
    Pacific Northwest, USA
    When the Toyota Stealership tries to sell you something tell them you aren't ever giving another penny to them again and that you can buy a higher quality cabin air filter online for less than $20.
  15. BiomedO1
    2,584
    1,391
    SacTown, Ca
    I do mine every 20K miles; every other oil change and prefer the charcoal filters @ $15 pair or $11 for OEM equivalent filters.Combo Set Engine & Cabin Air Filter for Toyota Prius 2016 - 2022 17801-21060 | eBay
  16. Mendel Leisk
    40,251
    I changed both filters, reluctantly, around 95k kms. The engine filter in particular was barely dusty.
    we’re west coast North America, likely cleaner air.
  17. PriusCamper
    11,870
    4,814
    Yeah Pacfic Northwest is easy on engine air filters... Only time I've seen a dirty air filter is when the vehicle was from different part of the country.
    More to the point if your engine air filter doesn't look dirty after the amount of miles/km when it's supposed to be changed you're wasting your money if you change it.
  18. purplePriii
    purplePriii Active Member
    273
    119
    Not OP but I have the issue. Dealer claims it's not covered under warranty and filter is fine. I know Toyota sells a kit to clean out the system but it seems a bit of a pain/smells strong for a couple days.
    tovli likes this.
  19. Mendel Leisk
    40,251
    The brief moldy odor is… mold. Growing on the AC system’s in-dash radiator (technically called “evaporator”), which chills the cabin air. Just like a glass of ice water, water vapour in the air condenses on it.
    if you use AC regularly, continuously, you will get mold. Toyota, instead of designing a system that somehow sheds the water (arguably a tall order), or making the evaporator readily accessible*, will sell you some bottles of cleaner, that are of dubious efficacy.
    one workaround, is to use AC sparingly, and always shut it down, but leave the fan running, at least a mile before your destination.
    * what you’re in for, accessing evaporator:
    Replaced the AC evaporator this weekend - about at expected | PriusChat
  20. bisco
    50,825
    that's what i do. i run a/c manually, so i just shut it off and leave the fan on. eventually, you learn to time it right so the car isn't too hot by the time you get to your destination.
    if i forget, i just shut it off and wait a few minutes.
