No power to inverter coolant fan
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raela, Aug 14, 2024.
  1. Raela
    Raela New Member
    Cuba kansas
    Trying to figure out what the problem is here. I was in an accident where I smashed in the radiator and AC condenser on a chunk of concrete. Radiator lost all of its fluids. I got a new radiator and replaced it. Did not replace the AC condensor bc I couldn't afford to get it. After replacing the radiator burped the system and took off down the road to see what it would do. The coolant light came on three times stopped the car and refilled it. I figured that would be it. I was about 20 mi away from where we replaced the radiator.. at this point the check hybrid system light comes on and the car shuts itself off. I checked the inverter coolant lines and squeezed them in case it hadn't burped yet. Started the car up and drove about 2 miles. Couldn't get the car to go any further than 2 miles after that at a time. After doing that twice I parked it and went to get a dolly and towed at home.
    Once home I ran the codes on the OBD scanner. I can't remember exactly what they were, but the codes led me to the inverter coolant fan. I replaced the fan. But the new fan didn't work. Out of curiosity I took the old fan and hooked it to a 12 volt battery. just to find that the old fan worked just fine.
    Okay so maybe it's wiring. Nope. We've checked all the wiring and the harnesses and there is power going all the way through the line. Also checked all of the fuse boxes and every fuse and the relays. They are all working as they should.
    The best I can figure is it's a computer problem. So I got the software and the plug to diagnosis problem properly and hopefully reset the computer. Unfortunately the software is not compatible with anything I own or anything anyone else I know owns. So until I can find a laptop that works with the software from Amazon, I can't reset the computer.
    Also worth noting in this saga, is that no mechanic around here wants to touch working on a Prius. I probably have more knowledge about working on a Prius from screwing with this one and my previous one than any of the mechanics in this area have and the ones I have called wouldn't take up the challenge to try to work on it for me. They're all booked up as it is and the last thing they need is to try and mess with my car when I can't afford to pay them for it past a few hundred dollars.
    I've searched every corner of the internet and read every link Prius chat had with a similar issue in any way. I've checked Facebook. I've checked everywhere and I have found one or two instances of people who had this problem but they did not list the resolution to the problem once they figured out or if they ever did find the solution. I don't know.
    So I'm completely at a loss here. What I'm wondering is has anyone else ever had a problem similar to this? And do you think it would be possible to override the computer shutdown of the inverter coolant fan with a toggle switch or hardwiring it into another fuse in the fuse box to forcibly kick the inverter coolant fan on when the car turns on? Any idea on if this would screw up the computer further or if this could possibly work? I've been without a car for 3 months and I've lost my job because I couldn't get to work and I need my car back. So I'm about to try the toggle switch. I'm just terrified I'll mess it up even more. But I would still be without a car either way so I'm willing to give it a shot. I'm desperately hoping someone out there can give me advice on the situation. Thank you in advance for any and all help you can provide because I'm at my wit's end with it!
  2. PriusCamper
    PriusCamper Senior Member
    12,741
    5,153
    Pacific Northwest, USA
    It makes sense that some kind of sensor or relay got damaged in the accident. Or maybe something related to the condenser? Or maybe just air in the system still?
    But at this point I think you've gone above and beyond the call of duty and I'd get in touch with this mobile Prius mechanic based out of Oklahoma: Drew Griffin (skimmilkhybrid) 405-696-9828
    He'll probably give you a great price on a used condenser install too so then once he's done you just take it to an AC auto specialist to put in the precise weight of refrigerant and oil.
  3. Tombukt2
    12,957
    2,325
    The inverter cooling fan these are the two fans that are behind the radiator that cool the nonsense not anything really to do with the inverter It's just that you're inverter radiator happens to be above the ice radiator so the fan covers both cores. So what you have is you don't even have cooling for your radiator then right? The car is overheating so you need to get the two radiator fans working that also cools your condenser for your air conditioning so your main fans aren't working You don't have a separate fan system for your inverter only these would be your complete fan assys. I was confused trying to figure out what the heck an inverter fan is. My two gen three's here have none of that just the main fans right behind the radiator and they work and they're connected to relays and plugs and one of them is actually been in the front end collision and didn't have any damage to that but still so something's not connected right or something I doubt it's the computer it is remotely possible but don't see a lot of that going on It's extremely rare as you've noted by not finding anything about it anywhere on the net so it's pretty rare for one of these cars to have a complete oddball problem that no one else has ever had generally speaking.
  4. Raela
    Raela New Member
    Cuba kansas
    The inverter coolant fan is completely separate from the radiator and the radiator fans. It sits below all of that and is only accessible from under the car next to the drivers side tire.
    And although I would love to call any mechanic, my negative bank balance suggests that unless they feel like a charity case, they aren't going to be too apt to work on my car. As for the condensor, although it is part of the coolant system with the radiator, since the inverter coolant fan is a separate system, I didn't figure that would be something that could b part of the problem. But I'll do some digging and see what I can find online for info on that possibility.
  5. Raela
    Raela New Member
    Cuba kansas
    Also, a new issue ha been noticed. I seem to have developed a power drain somewhere. During this process of fixing the car my battery had gone completely dead and I assumed it was because I had left the dome light on. So we replaced the battery with a different one but now the new battery is dead and I know I didn't leave a dome light on this time. I'm sure it relates to the problem I'm having somehow but for the life of me I have no idea how
  6. Tombukt2
    12,957
    2,325
    Post some pictures of your car You're obviously federal spec car you're somewhere in Kansas. So there's always that this looks like you're in the generation 3 forum I have two of these cars out front I'll go look in just a little bit after I take the kid to work that doesn't sound right but I guess it could be I haven't spent that much time taking the generation 3 apart and I have one that has been hit in the front end that only had a problem with the turn signal flashing on the right side so you must have taken a harder hit and not sure what's happened something to do with this inverter cooling fan it's running all the time and draining your battery okay well it's coming up on winter time now You won't even need the inverter cooling fan all winter unless you're trying to run a hundred miles an hour down the highway everyday which in Kansas I would kind of doubt but you may be trying to run those speeds on back roads but even in the cool of winter in Kansas you should be able to get close to it without having much issues I would hope because I can do it here in North Carolina I've driven without a inverter cooling pump for a whole winter in North Carolina USA so I'm not sure what you have going on I'll get you something's draining your battery absolutely so you hook up a meter to the battery terminals or one to the battery positive into the frame of the car and start disconnecting things one by one and see what makes the milliamps drop or whatever you'll find it It's somewhere around all the damage pictures would be real good
  7. ChapmanF
    18,159
    You're saying this about a 2011, gen 3 Prius?
    Can you refer us to where you got that idea?
  8. Brian1954
    Brian1954 Senior Member
    2,193
    862
    South Central PA, USA
    I think what the OP is calling the "inverter coolant fan" is actually the inverter coolant pump. That is the only thing that would make sense to me.
    #8 Brian1954, Aug 29, 2024
  9. Brian1954
    2,193
    862
    @Raela , do you have the old "inverter coolant fan" that you took out of the car? If so, can you please take a picture of it and upload it?
