2007 doesn’t start up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kyle Parsons, Aug 16, 2024.
  1. Kyle Parsons
    Kyle Parsons New Member
    North Carolina
    I have an 07 Prius that has had a few issues recently. The first problem was the red triangle while driving which is the battery fan. Now I can’t get it to crank up. I have checked the blue 15a fuse the main link and tried boosting it off. What could I be missing? Thanks
  2. Kyle Parsons
    North Carolina
    **update
    I used a scan tool to clear codes but it still isn’t cranking. I had my booster box on it while trying
  3. PriusCamper
    PriusCamper Senior Member
    12,712
    5,137
    Pacific Northwest, USA
    Battery fan automatically turns on when you get a red triangle related to hybrid system... Warning lights mean error codes have been stored that will point to the problem. You can buy one of these to read and clear error codes using phone apps like Dr. Prius App and others: http://www.ebay.com/itm/265484403768
  4. Kyle Parsons
    North Carolina
    I cleared all the codes and it still didn’t start up. Will the car crank and run if the battery fan isn’t working?
    #4 Kyle Parsons, Aug 17, 2024
  5. bisco
    51,851
    you don't want to clear the codes, you want to read them. they will help direct you to the issue.
    it is possible that an internal short in the battery is interfering with the booster pack. are you sure the booster pack is good?
    Kyle Parsons and Brian1954 like this.
  6. Brian1954
    Brian1954 Senior Member
    2,167
    843
    South Central PA, USA
    Use a volt meter and measure what the voltage is for the 12v auxiliary battery.
    Kyle Parsons likes this.
  7. Kyle Parsons
    North Carolina
    I’m sure my booster is good but I will definitely use a voltmeter to check the 12 volt battery.
    when you say there could be an internal short in the battery, are you referring to the 12 volt battery?
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    You have a warning light which usually comes on when there's a fault with the hybrid drive system. The car uses the hybrid drive system to crank the engine at 1000 RPM in order to get it running. Now the engine won't crank over.
    Maybe there's a fault with the hybrid system that prevents it from cranking the engine.
    You need a capable scantool to check all systems for codes. Here's a thread that reviews several scantool apps and devices for smartphones.
    https://priuschat.com/index.php?posts/3290690
    Brian1954 likes this.
  9. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Is the "ready" sign on?
  10. Kyle Parsons
    North Carolina
  11. bisco
    51,851
    yes. take it out of the circuit and try jumping
  12. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Check fuses.
    Errors must be counted. Try the scanner for OBDII
    Now this is fortune telling.
  13. ChapmanF
    18,100
    "You will soon make a journey on foot"
  14. bisco
    51,851
    "polar bears walk backwards after dark"
