Speed limiter
Discussion in 'Gen 5 Prius Technical Discussion' started by peternumber2, Aug 26, 2024.
  1. peternumber2
    peternumber2 Member
    119
    26
    Rome
    2023 Prius Prime
    Hi everyone.
    I tried to search for similar threads with no luck.
    I was wondering if anyone managed to disable the speed limiter. I realised my Prius prime is limited to 180 km/h, though it gets there with a surprising ease!
    Just out of curiosity, not sure if I would do it.
    Thanks
  2. KMO
    KMO Senior Member
    1,790
    580
    Finland
    2023 Prius Prime
    Is that 180 km/h actual or indicated? I believe it's documented somewhere that the real limit is 177km/h, and that would be due to hitting a 17000rpm limit on MG2 at 182km/h (with a 5km/h margin). Non plug-ins have a more arbitrary 180km/h limit. Plug-ins have a shorter final drive ratio, so their MG2 spins faster, so they're limited because of MG2 before hitting the general 180km/h limit.
    I've not heard of anyone managing to bypass the limiters in any generation.
  3. AndersOne
    AndersOne Active Member
    334
    193
    Europe
    2023 Prius Prime
    Thas interesting, I was wondering while I was able to hit 190kmh (indicated) with the HEV - the PHEV stopped around 180kmh so far.
    For someone that never had a sportscars its really wild though how effortless this accelerates to vmax - without the limiter I would not even notice sometimes.
    #3 AndersOne, Aug 26, 2024
  4. KMO
    KMO Senior Member
    1,790
    580
    Finland
    2023 Prius Prime
    All modern cars have far more power than they need for Vmax. It's a bit silly, tbh...
    The top speed difference from the specs is only supposed to be 3km/h, but maybe the MG2 177km/h limit is a bit harder than the general 180km/h somehow - maybe applied by different ECU logic.
    That 177km/h also could have been for 19" wheels. On the 17" wheels that would correspond to 174km/h, due to slightly smaller circumference.
    The 180km/h general limit might have been tweaked along with the speedo for different wheel sizes, but the MG2 limit would remain at the same rpm, representing slightly different speeds.
  5. Mendel Leisk
    40,239
    That a positive step. (y)
  6. Gokhan
    Gokhan Senior Member
    5,541
    2,174
    Paramount CA
    Why buy a Prius if you want to do 180 (rhetorical question).
    soft_r likes this.
  7. AndersOne
    334
    193
    Europe
    2023 Prius Prime
    Because 180 is fast enough and you dont need a faster car?
    Its not really a prius question though as most Toyota/Lexus Hybrids are kinda limited around 180.
    Edit: I would even go so far as to say the Prius fares better at high speeds compared to its hybrid siblings due to its flat shape.
    #7 AndersOne, Aug 28, 2024
    Trollbait likes this.
  8. Gokhan
    5,541
    2,174
    Paramount CA
    No, what I meant was that 180 is way too fast for a Prius and probably most Toyotas.
  9. AndersOne
    334
    193
    Europe
    2023 Prius Prime
    Why would you single out Prius or Toyotas? I can understand if you dont think people should generally not drive that fast but what do you have against fast driving Prius? The VW Golf that overtakes me with 200kmh has probably much less power - same with that old beaten up BMW.
    True the hybrid engine is not the most efficient at vmax but overall it still needs much less than other ICE cars (diesel excluded). TSS 3.0 works well up to vmax too - the only exception is the LCA (stops over ~140kmh) but that seems more like a useless gimmick anyway.
  10. Gokhan
    5,541
    2,174
    Paramount CA
    180 is too fast for most cars.
    Toyotas are designed to be driven slower than 160 km/h (100 mph). That is probably the case for most cars. Perhaps VW, being a German make, is designed for higher speeds. If I were planning to do 180 or higher on the left lane of an autobahn (I wouldn't), I would be driving a sporty car (BMW, Mustang, etc.). Toyotas are not sporty cars. VW Golf is. Sure, you can still do 180 or higher with most cars, including Toyotas, but that would be at your (and others') peril.
    Another concern is that SAE 0W-16 or SAE 0W-8 is too thin for sustained 180. If I were doing that, I would use SAE 5W-30.
  11. whitrzac
    whitrzac Junior Member
    46
    madison
    Spot the American city drivers, lol.
  12. AndersOne
    334
    193
    Europe
    2023 Prius Prime
    This reads more like a listt of car stereotypes. As for oil - I will ask Toyota next time but generally I would let them put whatever they seem fit and enjoy my 15 year warranty.
  13. Gokhan
    5,541
    2,174
    Paramount CA
    That is what Toyota tells for every model if you read the owner's manuals:
    “An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions.”
    #13 Gokhan, Aug 29, 2024
  14. peternumber2
    peternumber2 Member
    119
    26
    Rome
    2023 Prius Prime
    Thank you all for your replies. I didn't know the limit was the mg2 spinning too fast, then it's quite ulinkely that someone would modify the software limiter.
    My question arised since I noticed how quickly it gets to 180kmh, really remarkable.
    As long as the road is straight the Prius behaves very well even at high speed....if you need to corner.... well that's another story.
    Bye
  15. Mendel Leisk
    40,239
    You’re doing this on a public road?
    Danno5060 likes this.
  16. Trollbait
    12,240
    In Europe, where such speeds could be legal.
  17. Gokhan
    5,541
    2,174
    Paramount CA
    Only on some roads in Germany. He is in Italy, where the maximum speed limit is 130 km/h (81 mph).
    Speed limits by country—Wikipedia
  18. Trollbait
    12,240
    What? He can't drive to Germany, or take the Prius onto a track?
  19. ChapmanF
    16,957
    Absolutely not!
  20. Gokhan
    5,541
    2,174
    Paramount CA
    @Mendel Leisk's question was if he did 180 on public roads, not if he took his car to the track or drove for fifteen hours from Rome to München so that he could speed on a German autobahn.
    #20 Gokhan, Sep 1, 2024
