“Check hybrid system”
Discussion in 'Gen 3 Prius Main Forum' started by socal13, Aug 27, 2024.
  1. socal13
    socal13 livin in the foothills...
    267
    Altadena CA
    I went to Trader Joe’s this afternoon and when I started my car (2013 Persona, 65k miles) the message on the dash said “check hybrid system, pull over when safe” with several yellow lights lit up. Well, I drove home with a bit of non-smooth acceleration. What do you think the problem is?
    Thanks for your input.
    Doug
  2. ASRDogman
    ASRDogman Senior Member
    7,119
    3,719
    The problem is, you need to check the hybrid system.
    You need a code reader to check the codes.
    There are just too many things that could be wrong to start guessing.
  3. Tombukt2
    12,018
    2,124
    65K on a 13 Persona in Southern California probably an HV battery issue would be my guess I have the same car but that doesn't mean anything but that would be my guess if it's original battery it's well just right as far as the years go to be starting to mess up but then again some of them go to 400,000 miles before they mess up but usually those miles are within 12 or 13 years You're sitting it I don't know 10 or 11 now get a code reader read the codes that's the way to deal with these modern cars shooting in the parts Canon at them without even looking at the codes is quite costly
  4. ForestBeekeeper
    ForestBeekeeper Active Member
    765
    301
    Maine
    without knowing the codes, nobody has any clues.
    Danno5060 and Brian1954 like this.
  5. bisco
    51,029
    make sure the battery cooling fan is clean, and the intake grille is clear.
    also, check the fan motor connector for corrosion.
    socal13 likes this.
  6. socal13
    267
    Altadena CA
    Well, my mechanic read the codes and it is the hybrid battery. The warranty is 10 years and of course my car is 11 years old. I was told that low mileage and sitting a lot is worse for the battery than driving more miles. If I can get 10 more years on a new battery, that would be great!
    bisco and Brian1954 like this.
  7. bisco
    51,029
    no reason why it shouldn't. and you're at the perfect mileage to begin cleaning the egr circuit regularly,
    increasing coolant and oil change intervals, to help prevent the notorious blown head gasket problem.
    and more frequent brake fluid changes might help stave off the bad brake actuator, idk.
  8. socal13
    267
    Altadena CA
    I got my new hybrid battery through my mechanic who bought it from Toyota and installed for over $1k less than dealer quote.
    Next thing is to go to Hybridpit in Orange County for Egr service and exchange of all fluids! I’m determined to keep my rig running in tiptop condition.
    Thanks for the input. Prius chat is such a good resource for advice.
  9. ASRDogman
    7,119
    3,719
    Why didn't you get the hybrid battery through the hybrid pit? Or rather have them get it
    and put it in and then do all the other work?
    Maintainence will keep it going for a long time...
    Danno5060 likes this.
  10. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    Yea and you could have got a lithium or sodium battery from them.
    Also if you use my promo code "azusa" you can save 3% at hybridpit.com
    socal13 likes this.
  11. Mendel Leisk
    40,472
    I’m not so sure about that. At least based on what Toyota says in Owner’s Manual, in a nutshell that multiple month downtimes are hard on the battery, but other’n that…
    our ‘10 has about 3k less miles than yours, and when new, apparently sat at dealership (in a sheltered showroom shed), for about 15 months. So far no problems. Knock on wood.
  12. socal13
    267
    Altadena CA
    I would have gone to “the pit” for everything but I needed the car immediately. I’ll go soon when I have more time.
    ASRDogman likes this.
  13. ASRDogman
    7,119
    3,719
    Did you get a NEW battery? Or used/remanufactured?
  14. socal13
    267
    Altadena CA
    “Oem reman.” Per invoice
  15. bettergolf
    bettergolf Active Member
    474
    358
    Sanford NC
    reman=remanufactured. I had one on a 2006 that lasted me 3 years and the guy I sold it to was still good after a couple years...I've since lost touch. But they don't all fail 2-3 times a year as indicated on here a lot.
  16. amyjoelle
    amyjoelle Junior Member
    Oxnatd ,CA. 93033
    I am receiving the “ check hybrid system “ warning message too, but I Disconnected my battery to try and reset it so I have 0 codes on my snanner. It will only shift in to neutral. What can I do?
  17. Brian1954
    Brian1954 Senior Member
    1,705
    665
    South Central PA, USA
    Please use the thread that you created for your problem: https://priuschat.com/index.php?posts/3487713
