Inverter pump went off, replaced it replaced am2 fuse and now car wont go in drive
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Amnel Caban-Ortiz, Sep 4, 2024.
  1. Amnel Caban-Ortiz
    Amnel Caban-Ortiz New Member
    SC
    The car let me on the side of the road with a blown fuse am2. Replaced the coolant pump and am2 fuse and now car wont go on drive. Ready light never goes on, the fuse isnt blowing and the pump its working.
  2. Brian1954
    Brian1954 Senior Member
    1,704
    664
    South Central PA, USA
    Probably a different fuse has blown. You need to check all the fuses in the car.
  3. Amnel Caban-Ortiz
    SC
    I did check all of them and nothing. It has the big red triangle and only goes to neutral
  4. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    Let's do magic together.
    Turn off the car.
    Remove the negative terminal from the 12V battery.
    Read the prayer slowly.
    Connect the negative terminal to the 12V battery.
    Turn the car back on.
  5. Amnel Caban-Ortiz
    SC
    The magic didnt work
  6. Brian1954
    1,704
    664
    The red triangle light on the dash means you have trouble codes that need to be read with an OBD2 scan tool. If you are interested in purchasing a scan tool, read this thread: https://priuschat.com/index.php?posts/3290690
