Is Michelin energy savers still the top tires?
Discussion in 'Gen 2 Prius Main Forum' started by ToyotaGal, Sep 7, 2024.
  1. ToyotaGal
    ToyotaGal Member
    212
    89
    Millis, ma
    Hi all,
    I got my 08 touring in January. It came with okayama tires .
    In May, I thought my wheel Bearings were going and the mechanic said drives front. I fixed it. Not much chance in noise.
    In June I was visiting my friend and I took it to her mechanic cause the noise was getting louder. He said passenger wheel bearing. When he was in the middle of the job he said the axel bearing needed to be done as well. I think that was the additional work.
    Noise is much better loudest on the highway.
    Mycombo meter started to act up so I took it to the local hybrid specialist (awesome place) asked him to fix the combo meter and figure out the noise.
    He said it was rear tire was bubbling. Or something like that (russian so there is a small language barrier)
    I took it to a mechanic in that area and asked his opinion. He came back with transmission bearing drivers side and told me to call a transmission guy.
    The transmission gut said over the phone, he has never seen one go bad in a prius in over 25 years.
    Went to another mechanic he said all 4 tires need to be changed worst one is the same tire the hybrid people said to change. Tread is good just old and bubbling.
    Went to a tire shop. They told me I have the wrong size tire on the car 205 instead of 195 and wanted to sell me a name I never herd of.
    I came here and looked up tires. All threads seem to be old but Michelin seem to be the way to go.
    I plan on going to a tire shop not saying anything and see what they think of my tires but after reading the tire threads I think I is the tires and Yokohamas are probably loud tires.
    I bought the car with 89 thousand on it and currently it has 116 thousand on it.
    Which tires do you recommend?
  2. Tombukt2
    12,941
    2,322
    In that part of Massachusetts I would say pick your battles wisely You have a near 20-year-old car I don't think you need the latest 100,000 mile we're out warranty tires. Usually I don't get but about 65,000 out of those and at that $65,000 the tires are gray and ugly and look so bad it's ridiculous I just cut back to $45,000 mi tires so that they stay black their whole life and all of that nothing better looking than a set of Michelin defenders with 70,000 mi on them that look like they're turning white looks like the colored tire commercials from the '80s remember the yellow pirellis and all that that didn't go on cars they were in advertisement I wouldn't overthink my tires too much the cheaper the better on the Prius I buy $49 tires from a couple of manufacturers as I have four cars and it works out really well $250 for a set of tires is a far cry from 5 or 600 just for the tires then you have in your state $40 a wheel to mountain balance and throw the old ones out or more now you have $1,200 of tires on your car look at that as a $1,200 set of new shoes on your feet yeah pretty ridiculous unless of course.
  3. bisco
    51,895
    They are very good, but can be hard to come by.
    Nothing wrong with 205’s, but it’s a personal decision.
    There are plenty of threads here with tyre reviews and advice.
    Sounds like you’re getting a lot of conflicting advice, which is par for the course in automotive maintenance unfortunately
  4. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I would go with the Michelin Cross Climates or Nokian WRg5 tires. That way you will have traction when bad weather hits. Both are Low Rolling Resistance tires and will perform well.
    ToyotaGal likes this.
  5. highmilesgarage
    highmilesgarage Active Member
    473
    175
    Kansas City
    just get the cheapest tires from Walmart (which I did), Michelins are way overrated for a Prius, I however have Michelins on my trucks/SUVs and they're worth it.
  6. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    Michelins are not overrated at all. I have about 40k on my Energy Saver A/S and they are about 1/2 tread left still. They aren't the most silent tire but aren't bad. Highly recommend for MPG.
  7. BiomedO1
    3,565
    1,847
    SacTown, Ca
    I just got these on my car:
    https://www.walmart.com/ip/Armstrong-Blu-Trac-PC-205-65R15-99H-XL-A-S-All-Season-Tire-Fits-2006-07-Honda-Accord-LX-2005-Honda-Accord-EX/604858441?classType=REGULAR&from=/search
    The OEM tires are 195/65R15, your getting another 0.5 inch ride height with those oversized tires. That's probably good since your in snow country. The tire above is equivalent to the Michelins, on paper according to the specifications. It's also thicker and can handle more weight and abuse. My 2021 Prime doesn't have a spare and I've already had a few nails in the old OEM tires. Speaking about spare, you need to check the condition of yours and if you have all your tools to replace it. Sometimes people will remove them before trading in the car - and if no-one checks - you end up stranded.
    Regarding the noise: find better mechanics!!!! A wheel bearing issue is easy to check, just by lifting the questionable wheel off the ground. the half-shafts (axles) are also easy to test and do a visual inspection - no guessing involved. Tire bubbles and abnormal wear is mostly a visual inspection - there's a bunch of YouTube videos, if your interested.
    Good Luck...
    I think mine was around $310 all-in for all 4.
  8. pasadena_commut
    pasadena_commut Senior Member
    2,614
    771
    Southern California
    This sounds like it is mostly the "let's take this female to the cleaners because she cannot possibly know what we are talking about" routine. It is unfortunately still very common, which is why the "take a guy with you to the mechanics" is not bad advice for women, unless you have long experience with the mechanic and know they don't do this.
    What did they even mean by "bubbling"? Is that MA region speak for bulges? Bulges usually result from a tire hitting a hard edge at speed, normally a pothole or curb, which causes internal damage allowing the outer rubber to separate, air gets in between, and the unsupported rubber inflates outward like an aneurysm. Tires that show that sort of damage should be replaced. Shocks strong enough to damage a tire can also throw the alignment off too, so always have the alignment checked when replacing tires in that situation. Maybe I shouldn't even qualify that, just have the alignment checked when replacing a set of tires. (Not usually necessary if one tire was wrecked by something like a big screw through the sidewall.)
    205 instead of 195 (stock) is usually fine, although it affects the speedometer and odometer readings slightly.
    Palo Alto Speedometer: Speedometer Calculator
    On some models of car it might cause the tire to rub on the fender or the fender liner, especially when turning. That would make noise and would eventually screw up the tires (more so for a metal fender than for a plastic fender liner).
  9. ToyotaGal
    ToyotaGal Member
    212
    89
    Millis, ma
    I spend most of the year in fl. The car doesn't see snow unless I have to come up for something.
  10. ToyotaGal
    ToyotaGal Member
    212
    89
    Millis, ma
    Yes I have never had this much conflict. I took the car to one of my regular customers. ( I audit business and his has station is on my list.
    He drove it and said the cat eye was rubbing against the cat. ( it has done that before but caused a vibration when I turned on the car)
    And the tires are wearing down unevenly which is causing the second noise.
    He told me to bring it back during the week and to put on factory settings tires.
  11. ToyotaGal
    ToyotaGal Member
    212
    89
    Millis, ma
    I live in fl during the cold months. I do have a spare and all the equipment to change a tire. I got a flat a month after I got the car and the path just fell off . I went to the junk yard and was able to match the tire. It has the best tread between all the tires.
  12. Tombukt2
    12,941
    2,322
    I'm putting 215 65 15 tires on my 1.7-in lifted Prius tomorrow morning those are 26-in OD assemblies You're 205s are only 25.4 so that should be a no problem fit at all I would think but with a warrant suspension some rubbing could occur with new shocks and struts probably not especially if you go with the single rate springs that you can get now on a lot of the struts for this model
  13. ToyotaGal
    ToyotaGal Member
    212
    89
    Millis, ma
    Just a update. I ended up buying Falken tires with 80k miles . Not back tires and the car is driving like new again.
    I got a good price of 539.00 installed with an alignment and free tire rotation every 5k miles at Mavis tires a national change which is important cause I drive up and down the eastern seaboard.
  14. Tombukt2
    12,941
    2,322
    Well that's wonderful I'm riding on tires that cost about $49 a pop and get changed every 45,000 mi and rarely rotated oh well.
  15. ToyotaGal
    ToyotaGal Member
    212
    89
    Millis, ma
    Yeah if I put 45k tires on my car I would be changing them at least every 6 months. Lol
    My ravy died in May and I haven't found a replacement car yet. Maybe a lexus older suv hybrid. It needs to tow a 16ft boat.
  16. Tombukt2
    12,941
    2,322
    Well you're driving like I used to 25 years ago I used to put 50,000 miles on a car and oh about 5 months and somewhere in Western Massachusetts I don't know where millis is but what are you running your boat back and forth to misquamicut Don't know but I never see anywhere near 60 or 80,000 mi out of the michelins and if I get close to that they're down to the treadwear indicators and they are gray not black.
  17. ToyotaGal
    ToyotaGal Member
    212
    89
    Millis, ma
    Millis is near foxboro so boston suburbs.
    The boat is in fl. I want to take it back to mass once a year for the summer.
    I bought falkin tires claiming 80k miles. Not bad tires so far.
  18. Tombukt2
    12,941
    2,322
    Falken I hope it's spelled. With an I would be fakes or such. This company been around since the late 80,s I believe
  19. Tombukt2
    12,941
    2,322
    Regardless I'm imagining this is a sailboat so your trailer and sailboat 16 ft whatever it is Weigh what
  20. Tombukt2
    12,941
    2,322
    That must be a gruesome drive Florida generation 2 with a 16-ft something being towed behind it All mine with a plastic aluminum 8 ft trailer with a small zero turn in it would be as bad to me I can't imagine eight more feet of length but I guess it's all and whatever how I can't imagine I wouldn't have the patience for that today and certainly when I was younger definitely not.
