Need help!! Red Triangle
Discussion in 'Gen 2 Prius Main Forum' started by JoonohTexas, Sep 12, 2024.
  1. JoonohTexas
    JoonohTexas New Member
    I scanned my 05 Prius,
    No code.
    I did bench test HV battery under load (7.5-7.6V)
    Checked fuses&ground.
    Inverter pump seems working , feels flow and see bubbles in reservoir tank.
    Checked oil level.
    but once I reset through my scanner
    It starts up and drive.
    One thing I realized when engine switches to electric motor, it threw Red triangle.(when vehicle start -> engine run-> stop-> electric motor run)
    Please help
  2. Brian1954
    Brian1954 Senior Member
    1,705
    665
    South Central PA, USA
    What scan tool or app did you use? Your scanner is not good enough to read the trouble codes that triggered the red triangle (master warning light). You need to use a better scan tool.
    rogerdpack likes this.
  3. Tombukt2
    12,015
    2,124
    Sounds like you may have the HV isolation fault which lots of scanners will not pick that up unless it's a very new scanner with all the codes in it for hybrid vehicles this wouldn't happen in a regular car I'm not saying that's the code you have but it sounds like that that's partially possibly going on so you need to scan tool that can read all the codes that a Prius can throw out your best deal for that is a thing called an AP200 It's the best $63 you'll spend to deal with this vehicle forget the vent shades and the funny shaped air fresheners by this tool It would be a smart move If not you're going to be playing guessing games and wasting lots of money way more than the $63 that this tool will cost you You should get on that right away so you're not peeing in the dark on your own foot possibly.
  4. JoonohTexas
    I am going to get me one right now
  5. JoonohTexas
    Hello everyone.
    I got scanner . I scanned it it was P0AA6.
    But total voltage was 214.6V.
    Now what does it look like…?
    But if I test Aux battery it self it says 12.76V which is good. But on my device when car is on, Aux battery is 11.6V??
    Does it mean not grounded well?
  6. JoonohTexas
    I haven’t check oil level, each cells, 12V battery.
    I have got P0AA6..
    But I noticed on my actual 12V is coming out 12.76V,
    On my scanner, it says 11.6V..?
    What is going on here?
    I will throw my scanner picture.
    I hope Prius Master can tell me where I need to check.
  7. ChapmanF
    17,186
    Good info. Now do a search on this forum for posts about P0AA6.
    Brian1954 likes this.
  8. Brian1954
    1,705
    665
    What scanner did you buy? Is it capable of showing the freeze frame data for P0AA6 code?
  9. JoonohTexas
    It’s Bluetooth one.
    It had freeze frame data.
    Haven’t used it
  10. Brian1954
    1,705
    665
    What is the manufacturer and model number of the Bluetooth scanner that you purchased?
    You need to look at the freeze frame data for the P0AA6 code to find the INF/detail code to help you find the location in the car where the problem is happening. This will help you in fixing the problem.
    There are many threads in this forum that pertain to the P0AA6 code. Do some searching and a lot of reading to become knowledgeable about this code.
    #10 Brian1954, Sep 14, 2024
  11. JoonohTexas
    Veepeak
    I can use Dr Prius or some others app also with this.
  12. Brian1954
    1,705
    665
    FYI, Dr Prius app and other apps are not capable of reading freeze frame data when used with the Veepeak Bluetooth adapter. To look at the freeze frame data, you need a better scan tool. Did you read the thread that I linked in post #2 ?
  13. Tombukt2
    12,015
    2,124
    The fastest thing you can do to get the quickest result you want at this point is to Google the YouTube video of the down and dirty isolation fault test this should bring you to a video of a guy with a test meter who is taking out the orange plug of the HV battery touching one of the silver bolts that hold that plug assembly into the battery frame and then using the other lead to touch one of the bolts that goes through the battery frame and to the frame of the car in DC volts that should start counting down to zero the minute the leads are touching like stated above it'll count down and stop it 90 volts 40 volts whatever it is If it doesn't make zero your battery is not isolated from the rest of the car boom your code and that's the long and the short of it You can go get a scanner and do INF codes and all that other stuff and that's a wonderful thing but while you're waiting for a scanner that can do all that you can get a cheap test meter that goes to DC volts Google that video do that test if that test stops like I said above you need to go no further no worry for the INF code more or less You just proved the INF code is going to be the one that talks about the HV battery because you're standing at the HV battery running the down and dirty test that ends that discussion pretty much or you can wait and go round and round for a scanner absolutely you can I personally cannot I can't wait for that nonsense I have a test meter I also have the proper scanners now but still this avoids the scanning need for the most part If this thing tells you that it can't count down you're finished Open the battery up and you'll find the leak then you fix it buy a new battery play whack-a-mole all of that good stuff good luck.
  14. Brian1954
    1,705
    665
    This will only work if the P0AA6 problem is in the HV battery pack. This will not help you If the problem is in the inverter or the air conditioner compressor or the high voltage cables that run between these components.
  15. Tombukt2
    12,015
    2,124
    Yes running the down and dirty test will tell you that it's right there at the battery won't it because everything else is turned off so if you're DC voltmeter can not count down to zero measuring from the battery to the frame of the car at the HV battery with the car off that's where that ends correct? So if it can't count down there your problem should be right there If it counts down to zero there and you still have the code obviously you need to be looking at the air conditioner and the other circuit which I think is usually the cables running from the battery up to the back of the inverter been a few people that have smoked those or something that's my point the down and dirty test will in fact tell you right then and there if it can't make it to zero that you should be looking right there where you're standing I believe that is correct so if it does count down to zero and beeps or whatever happens zero . Then I would think I'm good at this spot look in the other two common places.
  16. ChapmanF
    17,186
    You can also search priuschat for the way you could narrow down where in the car the problem is in a gen 1, which was before there were INF codes to do that for you. You can still kinda do that, if you haven't got a scan tool to read the INF codes.
  17. half_mil_goal
    half_mil_goal Junior Member
    Colorado
    Where did you buy the AP200 scan tool?
  18. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
  19. Tombukt2
    12,015
    2,124
    Any link anybody shares should get you right to it It's a little white looking apple thing that plugs into your OBD2 port right above your knee there and then this stupid thing connects to your phone via Bluetooth and then you've downloaded the Maxi AP200 app It's 109 MB Asian file that you need that all goes on your phone. And then it just works It's a great scanner it does some of the servicing that other scan tools couldn't do a few months ago and now quite a few of them are popping up that can do some of them but this can do quite a few The other tools that can do these things are 200 plus dollars generally speaking this is 63$ so quite a decent savings You can carry it with you You're not logging a 7-in tablet around etc.
  20. Brian1954
    1,705
    665
