Guide to part numbers?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Brent Michael, Sep 11, 2024.
  1. Brent Michael
    Brent Michael New Member
    Tampa, FL
    2018 Prius
    Where can I find underbody part numbers? Dealer wants outrageous sum for replacing plastic slash guard that came loose, including $18 each for 11 fasteners!
    Is there an illustrated guide online?
  2. douglasjre
    douglasjre Senior Member
    2,090
    698
    Null, NL
    AutoParts.toyota.com
    Let us know what you find
    Brent Michael likes this.
  3. Brent Michael
    Tampa, FL
    2018 Prius
    Thank you - but not much luck so far! It's not very user-friendly!
  4. Mendel Leisk
    40,492
    Toyota USA’s parts site underwent a “revision” a year or two back, making it near-impossible to use.
    Amayama’s been my go-to, though of late they’ve switched to a different vehicle ID system, requires you to spec the technical vehicle code, typically starting with ZVW I believe. If you sort that out then it’s on to the part category maze. Still infinitely easier than the Toyota USA site. Usually better prices too, but that varies.
    will your dealership give you part nos, or is that closely guarded secret?
  5. CA Guy
    CA Guy Junior Member
    Three Touring
    $18 for a plastic fastener?
    What were they smoking?
  6. ChapmanF
    17,196
    I think it's a little like the old yarn where the guy is called to fix a complicated machine, looks it over, bonks it in one place with a hammer, it roars back to life, and he bills $1,000. The customer says "$1,000 to bonk with a hammer?! Send us an itemized invoice!" and he sends
    Bonk with hammer: $0.50
    Knowing where to bonk: $999.50
    In the case of a car dealer parts department, I think it breaks down sort of like
    Plastic fastener: $0.10
    Logistics system that tracks and warehouses a million different car parts nationwide and gets the one you need to the dealer by 10 am tomorrow: $17.90
  7. Brent Michael
    Tampa, FL
    2018 Prius
    I wish I knew, I could make a fortune!
  8. douglasjre
    2,090
    698
    Null, NL
    del
    #8 douglasjre, Sep 17, 2024
  9. douglasjre
    2,090
    698
    Null, NL
    :censored:
  10. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    #10 MAX2, Sep 17, 2024
  11. Brent Michael
    Tampa, FL
    2018 Prius
    Splash Sheild clips (1).jpg Unfortunately, wrong clips. I needed ones that look like this; I'm not sure if this is the exact clip, closest I could find so far.
    #11 Brent Michael, Sep 22, 2024
  12. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Perhaps these are the remaining clips of two parts? 90467-17027-C0, 90467-17026-A0
  13. Brent Michael
    Tampa, FL
    2018 Prius
    I believe those are the ones!
