Can you set turn signals to 4 blinks with light press?
Discussion in 'Gen 5 Prius Technical Discussion' started by Jon Watkins, Sep 21, 2024.
  1. Jon Watkins
    Jon Watkins Active Member
    131
    114
    Bluffton SC
    2024 Prius
    24 LE. Picked the car up Tuesday and it gives 3 turn signal blinks with light turn signal press. I’d like it to blink the turn signals 4 times with a light press. My 17 came with 3 blinks and I had to have the dealership hook it to their service computer to change it to 4 blinks. I can’t find anything about doing this in the 24 LE manual? Does anyone know how, or if, I can change this?
  2. KMO
    KMO Senior Member
    1,835
    607
    Finland
    2023 Prius Prime
    It can be changed the same way, despite being missed in the manual.
  3. Jon Watkins
    131
    114
    Bluffton SC
    2024 Prius
    Do you know what it’s called in the computer? When I had it changed on my 17 I had to talk the tech through it because he was clueless.
  4. Hammersmith
    Hammersmith Senior Member
    2,074
    2,064
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Customize Meter/Gauge System
    Lane Change Flashing Times Adjust
    Can be set to: Off, 3, 4, 5, 6 ,7
    dolphinsil and soft_r like this.
  5. soft_r
    soft_r Active Member
    160
    117
    Beverly Hills
    2024 Prius
    Super useful, gonna get them to disable it in mine because when I cancel my turn signal manually sometimes i overdo it and trigger the temp flash. Makes it look like I don't know if I wanna go left or right lol
  6. Jon Watkins
    131
    114
    Bluffton SC
    2024 Prius
    thanks!
  7. Roy Peterson
    Roy Peterson Member
    94
    124
    Richland WA
    2024 Prius Prime
    My scan tool allows me to customize this feature. I set mine at 5. Plus you can change the flasher volume. I set mine to max since I have hearing loss and don’t always wear my hearing aids
    Cheers
  8. RRxing
    RRxing Senior Member
    2,533
    1,807
    NEPA
    Carista allows you to change this and many other functions (changed my Venza to 5 flashes.) No dealer visit required.
    soft_r likes this.
  9. Jon Watkins
    131
    114
    Bluffton SC
    2024 Prius
    When I had oil changed at 1k miles the dealer changed it from 4 to 6 blinks which is just right.
    dolphinsil likes this.
  10. Paul Gregory
    Paul Gregory Senior Member
    1,673
    418
    Alberta
    2024 Prius Prime
    XSE
    I prefer 3 blinks myself.
