Faults PO420 (catalyst system efficiency below threshold) .
Discussion in 'Gen 3 Prius Main Forum' started by dgm1214, Sep 15, 2024.
  1. dgm1214
    dgm1214 Junior Member
    Wellman, iowa
    This popped up after replacing both oxygen sensors, on a 2013 with 177k miles. Prior error was related to faulty downstream oxygen sensor, and found wires from connector damaged. Did this work myself with sensors off Amazon, about $40 each.
    Wondering if I did something wrong ?
    Thanks !
  2. dgm1214
    Wellman, iowa
    Update, reset codes again, and after 50 miles NO codes popped up. Will test drive tomorrow too.
  3. bisco
    52,178
    good luck!
  4. dgm1214
    Wellman, iowa
    Update2. Drove only about 5 miles today before engine light appeared. Same 2 codes as before
    1) P0420 catalyst system efficiency below threshold Bank 1
    2) vehicle has no faults
    wondering why it says ‘no faults’ when it reported a P0420.
    Not sure if I should drive it on a trip, 700 miles one way into Canada, or not.
    Thanks for suggestions.
    #4 dgm1214, Sep 16, 2024
  5. bisco
    52,178
    were the new sensors oem?
  6. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    How did you read the errors from the machine? Program? Scanner?
    The error of low efficiency of the catalyst is most often critical for the environment and sensitive sense of smell.
    The exhaust pipe smells like donkey urine.
    The car continues to drive without any problems.
  7. AzusaPrius
    AzusaPrius Senior Member
    2,217
    929
    Try a bottle of Cataclean that stuff works.
    Also using your car while this code is on is not good for the ICE as it can cause back pressure and ruin your engine.
    If it is original OEM cat then it is time and most likely it is bad as they do not last more than 7-10 years.
  8. Eddie25
    Eddie25 Active Member
    497
    209
    MI
    You generally never want to get important engine management parts like o2 sensors from Amazon.
    I'd be skeptical that the original code was for sure related to a faulty downstream sensor. What code, and how did you come to that conclusion? Could it have JUST been the damaged connector? If feasible, put the old sensors back in with a repaired connector and see what happens.
  9. dgm1214
    Wellman, iowa
    Update
    After getting engine light and finding PO138 (bad downstream sensor) on this 2013 with 180k miles, I changed downstream sensor and then received a PO420 (catalytic converter error). So I changed the upstream sensor, and the catalytic converter. Still got the PO420 code. Cleaned EGR and cooler, intake manifold, pcv. No change. Also, the car has never used oil that I could tell, and radiator fluid alway full, and tonight I got 59.9 mpg on a 40 mile errand. The car has been flawless. I lost trust in the local Toyota dealer.
    Now
    I have a 1000 mile trip I need to take. Should I rent a car or drive it ?
    Thanks
  10. dgm1214
    Wellman, iowa
    If I remember right, all the wires were intake, but one of the bare wires was touching metal from the frame/holder.
  11. Eddie25
    497
    209
    MI
    p0138 is a o2 sensor high voltage code. I'm pretty sure this is what you might get if you had a broken wire or bad ground, so in conjunction with visually damaged wiring I would assume they are related.
    To have a sensor cause that code I think it would need to be open circuit. What is the resistance across the o2 sensor you took out?
    I still think you should either get OEM sensors, or repair the old ones and put them back in, (assuming the resistance checks out). I wouldn't feel comfortable diagnosing a p0420 until then (besides maybe visually looking for an exhaust leak or something).
  12. dgm1214
    Wellman, iowa
    I measure 15 ohms when testing the black wires on o2 sensor.
    Found an OEM o2 sensor, ordered it. Plan to stay home another week.
    I do not smell any unusual odor at exhaust.
    Thanks
