IPM Settlement Check??
Discussion in 'Gen 3 Prius Main Forum' started by DogDaze, Oct 4, 2024.
  1. DogDaze
    DogDaze Member
    203
    44
    Bay Village
    Hello All,
    Just curious, we just received an IPM Settlement Check in the mail for my wife's 2011 Liftback.
    Is this legit?
    Sorry if this has already been asked in a previous post..
    TIA
    51,840
    first i've heard of it. is that the result of a class action?
    DogDaze likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,541
    3,893
    Take it to your bank. Ask them....
    They should know, and/or could call and find out before depositing it.
    And then when it doesn't clear, charge YOU!
    DogDaze likes this.
  4. Brian1954
    Brian1954 Senior Member
    2,138
    828
    South Central PA, USA
    Did you have a problem with the inverter and paid to have it fixed and then submitted a claim for reimbursement for the cost to have it fixed? If so, the check is legit.
    Who is the check from?
    DogDaze likes this.
  5. AzusaPrius
    AzusaPrius Senior Member
    2,170
    915
    Besides getting a check for a repaired inverter, there is an IPM check being sent out.
    I searched a little and quickly found that people are getting a $350 check.
    Looks like you would have had to filled out something a while back.
    Not sure if owners who had the two updates, E0E and J0V would be automatically included.
    This is besides anyone getting a check for a repair made to the inverter.
    20 million was to be disbursed.
    DogDaze likes this.
  6. DogDaze
    DogDaze Member
    203
    44
    Bay Village
    Yes, it says a class action
    That's not a bad idea and great advice...
    We did have the inverter fail... Our dealership repaired it for no charge.. even gave us a loaner while it was in the shop.. no out of pocket cost to us otherwise.
    I don't have the check with me at the moment, but it mentioned the Kroll class action..
    Yes, it's like $352.. and I saw something on Reddit.. regarding the same... I was thinking it's legit... But thought best to check here first..
    Thank you for the info you turned up.
    btw, I don't recall filling anything out, but we may have gotten something in the mail if we wanted to 'opt out'.. I never responded to that opt out option since I wasn't sure if it was legit. I have no idea how they knew we had the failure.
    We have a 2012 V.. no issues with that inverter (yet) and about 50k more miles than the 2011 liftback. I've been trying to accelerate lightly on both since the initial failure.. (where I may have been on it a little too hard when it failed.. in the Eco Mode to boot)
    #6 DogDaze, Oct 5, 2024
  7. Mendel Leisk
    41,313
    What does IPM stand for?
  8. AzusaPrius
    2,170
    915
    Intelligent Power Module
    DogDaze and Mendel Leisk like this.
  9. ChapmanF
    18,069
    Or integrated power module, depending on where you look. It is basically a single electronic unit that combines several big IGBTs (insulated-gate bipolar transistors) along with simple driver circuits and some sensors for temperature, maybe current, etc.
    A small one, as you might find in a 3 kW DC to AC inverter, looks sorta like this:
    The connections to the DC power bus are the big terminals at the left, the switched power outputs are the big ones below, and the small gold connector pins in the middle are the control inputs and sensor outputs. The other face not shown in this picture is all metal, and you would bolt it down to a large heat sink to carry the heat away.
    The one inside a gen 3 Prius looks like this:
    You can see the big bolted power connections along the edges, and the small ribbon-cable connector for control and sensors near the middle of the board. From the pipe nipples, you can see that the Prius one even includes its own liquid coolant passages.
    There isn't really much 'intelligence' to it; it just combines some big transistors and associated sensors. The intelligence will be in some ECU that is pulling the strings, like the gen 3 MG ECU that mounts above the IPM and looks like this:
    #9 ChapmanF, Oct 5, 2024
    DogDaze likes this.
  10. fuzzy1
    10,406
    DogDaze likes this.
  11. DogDaze
    DogDaze Member
    203
    44
    Bay Village
  12. PixelRogue
    488
    86
    US
    I just received a class action check. Anyone know if cashing check results in relinquishing rights if something happens in the future to the IPM? Imagine those rights might already be forfeited by simply being part of the class action (?)
    DogDaze likes this.
  13. AzusaPrius
    2,170
    915
    I doubt it, the warranty on it has been extended and will still be covered.
    $350 does not cover the replacement of the inverter.
    Just make sure you have the updates to the inverter to be covered.
    That check is just a settlement for causing problems and affecting owners.
    DogDaze likes this.
  14. fuzzy1
    10,406
    Any restrictions triggered by cashing a check, should be written or referenced somewhere on it.
    #14 fuzzy1, Oct 5, 2024
    DogDaze likes this.
  15. douglasjre
    douglasjre Senior Member
    2,162
    714
    Null, NL
    How do I claim mine?
  16. Brian1954
    2,138
    828
    It's too late. See link in post # 13.
  17. Mendel Leisk
    41,313
    I’ve a vague recollection that Toyota Canada (perhaps USA counterpart too) wouldn’t reimburse owners, in the event of inverter failure, if this component failed, arguing that while it’s within the inverter housing it’s not part of it.
    Seemed a little absurd. @Tideland Prius may have more detail.
  18. ChapmanF
    18,069
    That sounds to me like it could have been misinfo. The docs for the covered repairs have charts showing which components inside the inverter housing are to be replaced depending on the codes and symptoms. The IPM is definitely on the charts. Sometimes the MG ECU and/or current sensor get replaced too, or the whole inverter. Depends on the size of the boom that happened.
    DogDaze, douglasjre and Mendel Leisk like this.
  19. Tideland Prius
    16,547
    I don't recall. But was this part of an inverter recall in 2011 or 2012? I remember smelling burnt electrical stuff when accelerating prior to the recall done.
    I also vaguely remember Toyota USA extending the warranty for something in the Gen 3 but not Toyota Canada.
  20. Flyin Lion
    Flyin Lion Junior Member
    US
    I received my check for $352, researched a bit, checked with my bank and it cleared with no issues. We traded that Prius in when it failed and they had told me at the time it was covered. We then bought our 2015 Prius 4. I think we will always own a Prius. We drive over an hour to work work and the savings alone has paid for both cars.
    It's smart to do the due diligence when you get a random check in the mail, especially these days.
    Sadly, most class actions never pay the victims, only the lawyers. FYI.
    DogDaze likes this.
