Where’s the aftermarket wheel/tire thread?
Discussion in 'Gen 5 Prius Main Forum' started by Chi_weezy, Feb 14, 2024.
  1. Blackat
    Blackat Active Member
    399
    264
    Colorado
    2023 Prius
    Limited AWD-e
    Looks sweet!
  2. PhoS
    PhoS Active Member
    234
    194
    Nowhere
    2023 Prius
    Limited AWD-e
    You should have plenty of clearance with that setup.
  3. Justin Prius AWD
    Justin Prius AWD Junior Member
    37
    2024 Prius
    Limited AWD-e
    Thanks for the feedback! Looking at visual clearance between tire and fender I was concerned. I’d rather not have to add some negative camber. Surely not tracking the car.
  4. PhoS
    PhoS Active Member
    234
    194
    Nowhere
    2023 Prius
    Limited AWD-e
    I compared it to mine on a size calculator. Obviously different brand tires are gonna have slightly different fitments. I think It'll be close but you shouldn't have to do anything that extreme to get them in there. There is some flexibility to space or trim the black fender on the inside if needed for the front. The rear has tons of space.
  5. Justin Prius AWD
    37
    2024 Prius
    Limited AWD-e
    I went with the Michelin PS All Season 4
    PhoS likes this.
  6. Cc103acs
    Cc103acs New Member
    28
    Connecticut
    2024 Prius Prime
    XSE
    Saw a guy at the parts counter at my local dealership… he had a bent wheel and did not look happy with the answers he was getting… or maybe the price. How much does a 19 inch replacement wheel go for?
  7. Hammersmith
    Hammersmith Senior Member
    1,969
    1,977
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    19" for the Prius Prime: 42611-47381
    MSRP of $606.92. Can be found for $419.61.
    You can pick up a used 19" HEV Prius wheel for $150-$350 from a few salvage yards, but I haven't seen any Primes show up yet on Car-Part(and I'm looking regularly).
  8. Blackat
    399
    264
    Colorado
    2023 Prius
    Limited AWD-e
    I'm selling my OEM 19's
  9. Justin Prius AWD
    37
    2024 Prius
    Limited AWD-e
    Good luck! I will be putting mine up for sale next weekend.
  10. Mendel Leisk
    40,502
    Currently $831.45 CDN. :ROFLMAO::cry:
  11. Justin Prius AWD
    37
    2024 Prius
    Limited AWD-e
    New wheels and tires are on. These are by far the cheapest wheels I’ve ever bought. Wasn’t interested in dumping a bunch of money into wheels for this car though. I achieved my overall goal. Fitment is really close! Zero rubbing thus far.
    Agent337 likes this.
  12. PhoS
    PhoS Active Member
    234
    194
    Nowhere
    2023 Prius
    Limited AWD-e
    Looks great! Post the size details.
  13. Justin Prius AWD
    37
    2024 Prius
    Limited AWD-e
    Agent337 and PhoS like this.
  14. PhoS
    PhoS Active Member
    234
    194
    Nowhere
    2023 Prius
    Limited AWD-e
    Nice (y)
    I know you posted it above in your question just wanted to make it clear since people tend to not read.
    I think you will be very impressed with the handling of the 5th gen with the good tire on there.
  15. Justin Prius AWD
    37
    2024 Prius
    Limited AWD-e
    I am pretty impressed albeit I don’t not intend on doing much spirited driving in a Prius. Aside from the lowering springs I did some other suspension mods for shits and giggles.
  16. longshot
    longshot Junior Member
    71
    Anyone know the size of hub centric rings you need for aftermarket wheels? 2024 LXE
  17. Mendel Leisk
    40,502
    Being Capain Obvious:
    The ring inside diameter you can determine by measuring your hub outside diameter. The ring outside diameter is dependent on the aftermarket rim’s hub opening inside diameter. Caliper is what’s needed to measure.
  18. Hammersmith
    1,969
    1,977
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    60mm or 60.1mm hub.
  19. Blackat
    399
    264
    Colorado
    2023 Prius
    Limited AWD-e
    You don’t really need them.
  20. PhoS
    PhoS Active Member
    234
    194
    Nowhere
    2023 Prius
    Limited AWD-e
    This is bad advise. Like you don't really need all 5 lug nuts?
    The hub centric rings are readily available and cheap.
    daisy555 and purplePriii like this.
