Original battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C Clay, Oct 19, 2024.
  1. C Clay
    C Clay Member
    330
    61
    Lexington, KY
    I believe this to be the original battery, you can see the type below the scanner, it doesn’t look like what they would replace it with at the dealer, but it doesn’t necessarily look like common replacement brand.
    Anyways, 317,000 miles, I’ve driven it six years and over half of that mileage. Have access to all of the service history before me. Could this be a 10-year-old battery, wow.
    iPhone ?
  2. ASRDogman
    ASRDogman Senior Member
    7,592
    3,916
    There should be a date code either etched in the plastic or on a sticker.
    That would tell you...
    Brian1954 likes this.
  3. bisco
    51,937
    Very possible
  4. rjparker
    10,153
    6,310
    If the car is driven daily the 12v battery can Ready the car with very little capacity remaining. Since there is no high current starter load they can last a very long time. Then you have sudden death syndrome - you drive the car to the store only to find a dead battery when you return to the car 15 minutes later. If you are lucky you have a lithium jump pack accessible without opening the dead hatch door and your wife or tow driver knows how to enter the car with the mechanical key, access the jump point under the hood and start the car. Even if all that works, you miss the Toyota battery sale and overpay there or buy an aftermarket version at Autozone.
    PriusPaddler likes this.
  5. Mendel Leisk
    41,457
    104 CCA? Take ANCEL'S advice.
    C Clay likes this.
  6. PriusPaddler
    PriusPaddler Member
    196
    45
    Twin Cities, MN
    I did laugh out loud. That would all be me.
    C Clay likes this.
