What is this rear suspension component part name / number?
Discussion in 'Gen 2 Prius Main Forum' started by eluo, Oct 19, 2024.
  1. eluo
    eluo Member
    113
    70
    Commack, NY
    Heard some clinking noise. Removed the rear left wheel and found this part broken. What is this part called? I tried searching for diagrams and came up short.
  2. Mendel Leisk
    40,506
    Looks like the auto-leveling sensor, for starters. The elbows seize, and then something has to give.
    eluo likes this.
  3. eluo
    eluo Member
    113
    70
    Commack, NY
    Thanks.
    Found this video that explains it more.
    I'll take it apart when I have time and see if I can make my own rod out off scrap metal.
  4. Mendel Leisk
    40,506
    Or some sort of splint. It's like a broken bone. put 2 or 3 slim metal rods across the break, as long as possible, wrap liberally with wire along the length, butter it all up with 2-part epoxy.
    Checking that the ball joints are free-moving should be in the maintenance schedule; grit and road salt kill these things. Easiest way to check, and distribute the grease, is unbolt one end, work the joints.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,225
    664
    Southern California
  6. eluo
    eluo Member
    113
    70
    Commack, NY
    Great idea. I will take your repair advice when I get a chance to do the repair. Thank you! (y)
    No code. Just occasional clinking sounds in turns or bumps. Not even sure if the sound is from that broken rod.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    3,949
    1,902
    NJ-USA
    It's a link for the headlight leveling sensor. The swivel joints are seized and ruined.
    Toyota sells the link only as part of the sensor. You can find just the link from the aftermarket.
    Or just remove the broken link and zip tie the sensor arm about at half travel and not worry about it.
  8. eluo
    eluo Member
    113
    70
    Commack, NY
    Took off early to vote and used the extra time to tackle this broken link.
    The bottom joint had seized, and the rubber boot had ripped away. Thought about regreasing the joint but will probably seize again without any protection from the elements. I decided to go low tech. Here is my solution with a coat hanger wire. It will probably rust away in a few seasons. I'll keep an eye on this when ever I check my tire pressure, which is quite often with dead TPMS batteries.
  9. Mendel Leisk
    40,506
    The function is to keep the LED headlights aimed properly though.
  10. pasadena_commut
    2,225
    664
    Southern California
    That coat hanger wire is not going to hold long. The bends will open up, change the spacing (before it eventually falls off), and if the spacing is wrong, the sensor is wrong, and the headlights won't do what they are supposed to. It may wear a groove into part of the other pieces before it fails. Not good.
    In this thread:
    Headlight level sensor 'tie rod' broken | PriusChat
    they refer to this part
    (go to Amazon, search for "Febest 0123-GRJ120-KIT LINK, HEIGHT CONTROL SENSOR, REPAIR KIT 48906-35010")
    which is a generic linkage that can be adjusted to 75 mm center to center. Here is the manufacturer's page:
    FEBEST - 0123-GRJ120-KIT - Link, height control sensor, repair kit
    which says that it fits 2004-2009 Prius.
    See that OEM part number? If you search with it other similar parts will be found. However, all the ones I saw were "never heard of that company" Chinese parts. From what I have seen online, Febest seems to be the German equivalent of Dorman, so not so great in quality either. That said, it is just some threaded metal, nuts and bushings, and it isn't doing anything tricky or handling much of a load, so it should be good enough. Just be sure to lube it once and a while.
    The real part is $57 at one of our nearby Toyota dealers:
    Height Control Sensor Link Sub-Assembly Rear #48906-35010 | Autoparts.toyota.com
    Mendel Leisk and eluo like this.
  11. eluo
    eluo Member
    113
    70
    Commack, NY
  12. Mendel Leisk
    40,506
  13. eluo
    eluo Member
    113
    70
    Commack, NY
    Thanks for the part number. Did a search and I found it for under $10 shipped from AliExpress. I appreciate all the help received here! :)
  14. eluo
    eluo Member
    113
    70
    Commack, NY
    Just replaced the linkage that was sitting around all winter. I put off the installation because it was a bit longer than OEM. Finally found time to cut it down with a dremel and matched up the length.
    Linkage installed.
    MAX2 and xliderider like this.
  15. pasadena_commut
    2,225
    664
    Southern California
    That replacement part looks good.
    The rust, not so good.
    In the second picture there are two bolts facing up which look like the nuts have already rusted on. Would be a good idea to treat that rust before it gets worse. At least hit the rustiest areas with some squirts of "Fluid Film", or a similar product.
    I understand that as NE cars go, that one isn't terrible. From a California perspective, that amount of rust would be grounds for not considering that vehicle for purchase.
  16. Has Raf
    Has Raf Member
    180
    42
    Stoke-on-Trent, England
    I’ve also replaced this recently. I’m in the UK so my car failed MOT as this part had snapped. My local Toyota wanted £774 to replace it! I bought the part off eBay and fitted it myself. Use WD40 or similar on the bolts first.
  17. Mendel Leisk
    40,506
    Maybe Toyota should edit the maintenance schedule, replace “check driver’s floor mat”, with “check headlight levelling mechanism”. Seriously, every couple of years:
    Unbolt one end of mechanism, work all elbows, reinstall bolt.
  18. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    There were no LEDs on Gen2. But there is a lever even on my Gen2 with halogen lamps.
  19. dolj
    dolj Senior Member
    8,188
    4,169
    Wellington, New Zealand
    Interesting, perhaps your car came from the factory with HID and somewhere along the way the car was converted to halogen.
  20. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    I may have got it wrong. My Gen2 doesn't have a height sensor. The sensor was for HID, I don't have them.
