FSM lied to me.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Oct 27, 2024.
  1. Prius92
    Prius92 Active Member
    592
    121
    Iowa
    Before I got everything back together I had to put the front sub frame on so it could be towed home as I was going through a divorce.
    Factory service manual made it sound like the sway bar could be installed with the subframe attached, so I neglected to install it to save time.
    I spent 2 hours last night after removing the entire exhaust and steering gear twisting and contorting the damn thing, but it will not go in without removing the subframe.
  2. PriusCamper
    PriusCamper Senior Member
    12,736
    5,152
    Pacific Northwest, USA
    I got a more stiff Corrolla front sway bar that I've been procrastinating on installing on my Gen2. Maybe that's why I've been avoiding it? :) But according to all the posts I've read on here, you just need to disconnect the exhaust at the header, the wheels and all the mounts for it? Is there an additional bracket down there (subframe) that needs to be removed?
  3. Prius92
    592
    121
    Iowa
    With the subframe attached, there is limited clearance to bolt in the sway bar itself. There is also limited clearance to unbolt the steering gear.
    This is a photo of the subframe with the attached parts.
    You have to insert the sway bar and flip it back around. There isn't enough room to insert the sway bar in the correct position.
    There also isn't enough room to flip it around, it hits on the floorpan/firewall area.
  4. PriusCamper
    12,736
    5,152
    Dang... That looks like so much more work than I thought? I wonder why no one has mentioned this? I mean I've read every Gen2 thread on here regarding sway bar upgrades and never once read this?
  5. highmilesgarage
    highmilesgarage Active Member
    473
    175
    Kansas City
    I just don't see the point of upgrading the sway bar on the Prius especially the front.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,620
    775
    Southern California
    It's for track days.
    /s
  7. Mendel Leisk
    41,413
    I just came here to find out FSM stood for, and why it lied. Anyway, attached Repair Manual excerpt attached, just in case it's any different:
  8. highmilesgarage
    473
    175
    Kansas City
    lol, record for embarassment..
  9. Prius92
    592
    121
    Iowa
    I kinda wonder how these manuals are written. Like is there a team of people taking entire cars apart to write these?
    Also in one of the DTC workups for the throttle body, one of the resistance values is incorrect. I know this because it was the same on my old throttle body position sensor and a brand new one.
  10. highmilesgarage
    473
    175
    Kansas City
    there might be an updated version that's not probably out in the internet yet. Same issue with the 8mm triple square head bolt in the FSM, it's actually 9mm.
  11. fuzzy1
    10,439
  12. Mendel Leisk
    41,413
    I'm seeing this:
  13. Goodcitizen
    Goodcitizen Member
    74
    30
    Cali
    The service manual also lies about where the certification ecu aka immobilizer is. That was a huge pain in the butt when I was dealing with an (unknown) corroded wiring issue.
    Took a ton of digging around online, like multiple days going through old posts and finally a russian youtube video showing a prius teardown led me to its actual location.
  14. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Might be worth starting a thread, that way others don't have to go thru similar efforts.
    Is it not located as pictured below?
  15. mr_guy_mann
    mr_guy_mann Senior Member
    4,045
    1,969
    NJ-USA
    Good catch. Germans use "triple square" 12 points that have 90° angles.
    Toyota's "double hex" 12 point has 60° angles.
    Completely different tools. They will not interchange.
  16. mr_guy_mann
    4,045
    1,969
    NJ-USA
    I do not know. It depends on what you mean when you say "immobilizer". It also depends on who does the translations for any given section of the factory service manual.
    There's the "transponder ecu", the "certification ecu", and the "ID code box". Can't keep "which part is what" straight in my head.
