Wheel compatibility
Discussion in 'Gen 5 Prius Accessories and Modifications' started by rschlegel, Mar 30, 2023.
  1. Hammersmith
    Hammersmith Senior Member
    1,969
    1,977
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    That isn't a half bad idea for PandaBOT. Even a single X-Ice could get them by until they can get a replacement all season tire. Then, since they live in Colorado, they could get another 3 X-Ice tires this winter for a snow set.
    otatrant and PandaBOT like this.
  2. PandaBOT
    PandaBOT New Member
    Colorado
    2023 Prius
    XLE AWD-e
    You both are brilliant!
    otatrant likes this.
  3. darkstar3274
    darkstar3274 Junior Member
    46
    2022 Prius Prime
  4. darkstar3274
    46
    2022 Prius Prime
    All due respect and this is an old thread but 55 lbs difference in the SE versus XSE Prime is barely 1.5 percent of curb weight and will not result in a 7.7 percent drop in fuel economy. (the 300+ lb difference in going from standard hybrid to Prime is definitely a factor as that is around 10% of total weight but that is a different comparison) Given that the tire widths are the same (assume contact patches to be similar with the road), the 7.7% difference must be largely if not all from aero (0.5 inch lower on the SE and maybe those wheel covers).
    To draw analogy from under-inflated tires to correctly inflated to over-inflated tires, fuel economy is influenced by that rubber patch (friction)-wonder if someone can put this through its paces (getting errors)
    bndtechsource period ucoz period com fwdslash index fwdslash tire_data_calculator fwdslash 0-20
    bndtechsource period wixsite period com fwdslash home fwdslash tire-data-calculator
    #44 darkstar3274, Aug 31, 2024
  5. padrino
    padrino Junior Member
    Sun Diego
    About to buy (great deal) 17x7 ET 48 rims shod with new 225/60R17 tires. Before i plunk down the money…..WILL THEY FIT my bone stock 2015 Gen 3?.
    #45 padrino, Oct 23, 2024
  6. padrino
    Sun Diego
  7. Zeromus
    Zeromus Active Member
    496
    261
    Ottawa Canada
    2024 Prius Prime
    SE
    This is the gen 5 subforum for 2023/24/25 models, you'll have better luck in one of the subforums specific to your model year.
  8. Eddie F
    Eddie F Junior Member
    Windsor, Canada
    2024 Prius Prime
    SE
    Scion iM 2016, Toyota iM 2017 has 7Jx17ET50 5x114.3 Ø60.1: (with 225/45R17 just to try them on)
    Stock 2024 SE with and without hub cap: 6.5Jx17ET40 5x114.3 Ø60.1
    Weight difference is about 5.5 LBs per wheel.
    Xov’ze likes this.
  9. Mendel Leisk
    40,505
    Just editorial, that looks to be the plug-in. Not that it matters, same wheels.
  10. pparadisom
    pparadisom New Member
    Wisconsin
    2024 Prius Prime
    SE
    Thanks to your idea of trying Scion iM wheels I just confirmed that I like how they look. I'm trying to switch the ugly OEM wheels of my newly purchased Prius Prime SE and I came across these iM wheels on Marketplace but I wasn't sure if I'd like them, now I found this post. I'm planning to keep the OEM 195/60R17 tires for now but I'm not sure if the iM wheels can fit them.
  11. Eddie F
    Windsor, Canada
    2024 Prius Prime
    SE
    Yes, 95/60R17 fit without any problem. TPMS that came with Scion iM's rims however didn't work and had to be replaced.
  12. darkstar3274
    46
    2022 Prius Prime
    ....regarding: "Weight difference is about 5.5 LBs per wheel"
    Which is heavier? 17" Scion IM '16-17 or PP SE/Prius LE OEM 17" without covers?
  13. pparadisom
    Wisconsin
    2024 Prius Prime
    SE
    So you ended up putting those iM Wheels with different tires in the Prime SE?
  14. Eddie F
    Windsor, Canada
    2024 Prius Prime
    SE
    Yes. I put 195/65R17 on Scion iM 2016 rims.
    Also, Scion's wheels with 225/45R17 are heavier, than Prime SE 2024 17" stock wheels.
  15. phase
    phase Member
    105
    40
    Portland
    2023 Prius
    LE AWD-e
    whats the absolute smallest we can go with wheels? apparently 15 inches are impossible? i wish a 185/65/16 existed...
  16. pparadisom
    Wisconsin
    2024 Prius Prime
    SE
    Can you upload a picture to see how the 195/65R17 looks with the iM wheels? I'm also thinking on getting 17 inch Sport Tuning ST7 wheels with a set of 225/55R17 tires because I don't like the Toyo's for winter.
  17. Eddie F
    Windsor, Canada
    2024 Prius Prime
    SE
  18. John Kulp
    John Kulp New Member
    Evergreen Colorado
    2022 Prius
    Hello. I have a 2010 Prius and recently bought a 2022 one. Can I take the wheels on the 2010 one and put them directly on the 2022 one? Thank you.
  19. Hammersmith
    1,969
    1,977
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yes. Gen3(2010-15) and Gen4(2016-22) use the same two wheel/tire sizes. Neither fit on the Gen5(2023-) which is what this sub-forum is about.
